4929|6
求助:为什么AD中断进不去呢? [复制链接]
RT                    求高手帮忙
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P6SEL |= 0x10;                            // P6.4 ADC option select
  ADC12CTL0 = ADC12SHT02 + ADC1      ;         // Sampling time, ADC12 on
  ADC12CTL1 = ADC12SHP;                     // Use sampling timer
  ADC12IE = 0x10;                           // Enable interrupt
  ADC12CTL0 |= ADC12ENC;
  P2DIR |= 0x08;                            // P2.3 output
  while (1)
    ADC12CTL0 |= ADC12SC;                   // Start sampling/conversion
    __bis_SR_register(LPM0_bits + GIE);     // LPM0, ADC12_ISR will force exit
    __no_operation();                       // For debugger
#pragma vector = ADC12_VECTOR
__interrupt void ADC12_ISR(void)
  switch(__even_in_range(ADC12IV,34))
  case  0: break;                           // Vector  0:  No interrupt
  case  2: break;                           // Vector  2:  ADC overflow
  case  4: break;                           // Vector  4:  ADC timing overflow
  case  6: break;                           // Vector  6:  ADC12IFG0
  case  8: break;                           // Vector  8:  ADC12IFG1
  case 10: break;                           // Vector 10:  ADC12IFG2
  case 12: break;                           // Vector 12:  ADC12IFG3
  case 14:                         // Vector 14:  ADC12IFG4
            if (ADC12MEM4 >= 0x7ff)                 // ADC12MEM = A4 > 0.5AVcc?
      P2OUT |= BIT3;                        // P2.3 = 1
    else
      P2OUT &= ~BIT3;                       // P2.3 = 0
    __bic_SR_register_on_exit(LPM0_bits);   // Exit active CPU
  case 16: break;                           // Vector 16:  ADC12IFG5
  case 18: break;                           // Vector 18:  ADC12IFG6
  case 20: break;                           // Vector 20:  ADC12IFG7
  case 22: break;                           // Vector 22:  ADC12IFG8
  case 24: break;                           // Vector 24:  ADC12IFG9
  case 26: break;                           // Vector 26:  ADC12IFG10
  case 28: break;                           // Vector 28:  ADC12IFG11
  case 30: break;                           // Vector 30:  ADC12IFG12
  case 32: break;                           // Vector 32:  ADC12IFG13
  case 34: break;                           // Vector 34:  ADC12IFG14
  default: break;
jpp
CSSTARTADD是不是没有配置,你选择ADC12MEM寄存器是要配置的,不然会默认0的。如果发现AD进不了中断,可以在程序中加断点,然后检查ADC12IFG寄存器,看哪一位置位了,这样更容易查找原因!  详情 回复 发表于 2011-11-17 17:14
wait online
5014
裸片初长成(初级)
参考下这个例程
#include
void main(void)
  ADC12CTL0 = SHT0_2 + ADC12ON;             // Set sampling time, turn on ADC12
  ADC12CTL1 = SHP;                          // Use sampling timer
  ADC12IE = 0x01;                           // Enable interrupt
  ADC12CTL0 |= ENC;                         // Conversion enabled
  P6DIR &= 0x01;                            // P6.0, i/p
  P6SEL |= 0x01;                            // P6.0-ADC option select
  P1DIR |= 0x01;                            // P1.0 output-LED
  for (;;)
    ADC12CTL0 |= ADC12SC;                   // Start convn, software controlled
    _BIS_SR(CPUOFF + GIE);                  // LPM0, ADC12_ISR will force exit
// ADC12 interrupt service routine
#pragma vector=ADC12_VECTOR
__interrupt void ADC12_ISR (void)
    if (ADC12MEM0 < 0x7FF)
      P1OUT &= ~0x01;                       // Clear P1.0 LED off
    else
      P1OUT |= 0x01;                        // Set P1.0 LED on
    _BIC_SR_IRQ(CPUOFF);                    // Clear CPUOFF bit from 0(SR)
5014
裸片初长成(初级)
原帖由 wstt 于 2011-11-17 10:57 发表
参考下这个例程
#include
void main(void)
  ADC12CTL1  ...
这个是IAR环境下的例程,跟你的配置基本是一致的。
回复 板凳 wstt 的帖子
这个我知道,你看看我的程序,我也是按例程改的,没有问题,为什么进不了中断,我就是想A0口采换到A4口采而已。为什么啊???????????????
以下是正确的例程:
#include "msp430x54x.h"
void main(void)
  ADC12CTL0 = ADC12SHT02 + ADC12ON;         // Sampling time, ADC12 on
  P6SEL |= 0x01;                            // P6.0 ADC option select
  while (1)
  case  6:                                  // Vector  6:  ADC12IFG0
    if (ADC12MEM0 >= 0x7ff)                 // ADC12MEM = A0 > 0.5AVcc?
      P1OUT |= BIT0;                        // P1.0 = 1
    else
      P1OUT &= ~BIT0;                       // P1.0 = 0
  case 14: break;                           // Vector 14:  ADC12IFG4
  default: break;
[ 本帖最后由 火煞王 于 2011-11-17 12:32 编辑 ]
自己搞懂了~~~哎,
回复 5楼 火煞王 的帖子
闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌熼梻瀵割槮缁炬儳缍婇弻鐔兼⒒鐎靛壊妲紒鐐劤缂嶅﹪寮婚悢鍏尖拻閻庨潧澹婂Σ顔剧磼閹冣挃闁硅櫕鎹囬垾鏃堝礃椤忎礁浜鹃柨婵嗙凹缁ㄥジ鏌熼惂鍝ョМ闁哄矉缍侀、姗€鎮欓幖顓燁棧闂備線娼уΛ娆戞暜閹烘缍栨繝闈涱儐閺呮煡鏌涘☉鍗炲妞ゃ儲鑹鹃埞鎴炲箠闁稿﹥顨嗛幈銊╂倻閽樺锛涢梺缁樺姉閸庛倝宕戠€n喗鐓熸俊顖濆吹濠€浠嬫煃瑜滈崗娑氭濮橆剦鍤曢柟缁㈠枛椤懘鏌eΟ鑽ゅ灩闁搞儯鍔庨崢閬嶆⒑閺傘儲娅呴柛鐔村妽缁傛帡鏁傞崜褏锛滃銈嗘⒒閹虫挻鏅堕幓鎹涘酣宕惰闊剟鏌熼鐣屾噰妞ゃ垺妫冨畷鐔煎Ω閵夈倕顥氶梻浣告惈缁嬩線宕㈤懖鈺冪焼濠㈣泛鏈崰鎰扮叓閸ャ劍绀€闁搞劍绻傞埞鎴︽偐鐎圭姴顥濈紓浣哄缂嶄線寮婚敐鍛傜喖鎮滃Ο閿嬬亞婵犵妲呴崑鍛垝閹炬剚娼栭柧蹇撴贡閻捇鏌涢埄鍐炬當妞ゅ繐鐡ㄧ换娑㈠醇閻斿摜顦伴梺鍝勭焿缂嶄線鐛Ο灏栧亾濞戞瑡缂氭い锔垮嵆濮婃椽宕崟顓犱紘闂佸摜濮甸悧鐘差嚕婵犳艾鐐婃い鎺嶇劍濞呭洭姊洪柅鐐茶嫰婢ф挳鏌熼鏂よ€块柡灞芥椤撳ジ宕卞▎蹇撶疄闂傚倷绶氬ḿ褔鎮ч崱娑樼閻庯綆鍠栫壕鍧楁煛閸愩劎澧涢柣鎾寸洴閹﹢鎮欐0婵嗘闂侀€炲苯澧紒璇插€块、姘舵晲婢跺﹪鍞堕梺鍝勬川閸嬬喖顢欓崶顒佺厵闁兼祴鏅炶棢闂侀€炲苯澧€殿喛娉涜灒濠电姴娲﹂埛鎺楁煕鐏炲墽鎳呮い锔肩畵閺岀喓鍠婇崡鐐板枈閻庢鍠氶弫濠氥€佸Δ鍛<婵犲﹤鎳愰崢顖炴⒒娴d警鏀伴柟娲讳簽缁骞嬮敂钘変簵闂佺偨鍎查崜姘舵偄閸℃稒鍋i柛婵嗗婵炲洭鏌涢鐘插姎闁告垹濞€楠炴牕菐椤掆偓婵′粙鏌i幘瀵告噰婵﹥妞介、姗€濡歌閺嗙娀姊洪崫鍕靛剭闁稿﹥绻堝璇差吋閸ャ劌鐝伴梺鑲┾拡閸撴盯顢欓幒鎴旀斀妞ゆ梻銆嬫Λ姘箾閸滃啰绉鐐茬箻閹晝鎷犻懠顒夊斀闂備礁婀遍崕銈囨崲閸屾稐绻嗛柣鎴eГ閳锋帒霉閿濆懏鎯堥悽顖氬缁辨挸顓奸崪鍐ㄥ缂備緡鍠栭…宄邦嚕娴犲鏁嗗〒姘处閿涘牆鈹戦悩鍨毄闁稿鍋涘玻鍨枎閹惧疇袝闁诲函缍嗘禍鎰磽濮橆厾绠鹃柛鈩兠慨锕傛煛閳ь剚瀵肩€涙ǚ鎷婚梺绋挎湰閻熝囁囬敃鍌涚厵婵炴潙顑傞崑鎾舵惥娴h銇濋柡浣稿暣瀹曟帒顫濋鍌楀亾椤撱垺鈷戦悷娆忓閸熷繘鏌涢悩宕囶暡缂佸顦鍏煎緞鐎n剙骞嶉梻浣筋嚃閸ㄥ崬顭垮Ο娆炬毐闂傚倷鑳剁划顖炲箰鐠囪娲偄閻撳氦鎽曢悗骞垮劚椤︻垶鎮″☉妯忓綊鏁愰崨顔兼殘濠电偛鐖滈崟顓狀啎闁诲海鏁告灙妞ゅ孩鎸剧槐鎺楁偐閸愯尙浼岄梺鐐藉劵婵″洭骞戦崟顖毼╅柨鏇楀亾闁哄鍊垮娲川婵犲啫顦╅梺鍛婃尰閻╊垵妫熷銈嗘尵婵澹曢挊澹濆綊鏁愰崟顓犵厯闂佸憡绻冨浠嬪蓟閻斿吋鍋¢柣妤€鐗婇幃娆撴⒑娴兼瑧鎮奸柛蹇旓耿閻涱噣骞掑Δ鈧粻锝夋煛閸愶絽浜鹃梺璇查椤嘲顫忓ú顏呭仭闁规鍠楅幉鑲╃磽娴g瓔鍤欓柛濠傛健閸ㄩ箖寮介妸銉х獮闁诲函绲洪弲婵堢不濮樿埖鈷戠紓浣姑慨锕€霉濠婂嫮鐭掗柛鈹惧亾濡炪倖甯婄粈渚€鎮樼€电硶鍋撶憴鍕缂佽瀚粋鎺楁晜閼恒儱顫¢梺鍦瑰ù鐑藉煡婢舵劖鐓冮悷娆忓閻忊晠鏌嶈閸撱劎绱為崱妯碱洸婵犻潧顑嗛崐鍨亜閹烘垵顏柍閿嬪灴閺屾稑鈽夊鍫濅紣婵犳鍣粻鎾诲蓟濞戙垺鍋愮€规洖娲ら埛宀勬⒑閹稿海绠橀柛瀣ㄥ€曢悾鐑藉Ω瑜夐崑鎾斥槈濞嗗绱伴梺鍛娗瑰Λ鍕煘閹达箑鐓¢柛鈩冾殘娴犳潙鈹戦悙鍙夊珔缂佹彃澧界划瀣箳閹存梹顫嶅┑鐐叉閸ㄥ綊顢欓弴銏♀拺闁告挻褰冩禍鐐烘煕閻樻煡鍙勭€规洘绻堟俊鑸靛緞鐎n剙甯楅梺鑽ゅ枑閻熴儳鈧凹鍓熼幃姗€鏁傜粵瀣啍闂佺粯鍔橀婊堢叕椤掑嫭鐓涢悘鐐插⒔閳洜绱掔紒妯肩疄鐎规洘锕㈤崺锟犲礃閻愵儷褍鈹戞幊閸婃鎱ㄩ悜钘夌;婵炴垯鍨洪弲婵嬫煏婢跺棙娅呯紒鐘冲哺閺岋繝宕橀妸褍顣哄銈庡亜閹虫﹢寮婚敐鍛傜喓鎷犻懠顒傘偡婵$偑鍊ら崑鍕晝椤忓嫷娼栧┑鐘宠壘绾惧吋鎱ㄥ鍡楀幋闁稿鎹囬獮鏍ㄦ媴閸濄儻绱┑锛勫仜椤戝懎霉閻戣姤鍎楅柛鈩冦仠閳ь剚甯掗~婵嬫晲閸涱剙顥氶梻鍌欐祰椤曟牠宕伴弽锌缂氶柍銉ョ-閺嗭箓鏌熼鐐蹭喊婵′勘鍔岄埞鎴︽倷閼碱剚鎲奸梺缁橆殘婵炩偓鐎殿喖顭峰鎾偄閾忚鍟庨柣鐔哥矊缁夊綊鐛繝鍥х疀闁绘鐗嗛埀顒€娼¢弻娑滅疀濮橆兛姹楃紓浣哄█缁犳牕顕i崼鏇為唶婵犻潧妫岄幐鍐磽娴e壊妯堥柛鎾村哺婵$敻宕熼锝嗘櫇闂侀潧绻嗛弲婊堝煝閸儲鍊甸悷娆忓缁岃法绱撳浣镐壕缂傚倷鑳舵慨鐢电矙閹达箑鐓″璺号堥弸搴ㄦ煙鐎涙ḿ绠撳┑鈥虫喘濮婂宕掑▎鎴М婵犮垻鎳撻敃顏勭暦閹达箑宸濇い鏍ㄧ☉鎼村﹪鎮楅獮鍨姎闁瑰弶锕㈤弫鎰板醇濞戞鐫忛梻浣告贡閸庛倝骞愭ィ鍐ㄥ偍濞寸姴顑嗛埛鎴︽偡濞嗗繐顏╃紒鈧崘鈺冪濠㈣泛顑囧ú瀵糕偓娈垮枤鏋柍钘夘樀婵偓闁挎稑瀚獮鎰版煟鎼粹€冲辅闁稿鎹囬幃妤呮晲鎼粹€愁潻闂佺硶鏅涢懟顖炩€旈崘顔嘉ч幖绮光偓鑼嚬缂傚倷绶¢崰妤呭箲閸パ呮殾婵炲樊浜滈悞鍨亜閹哄秹妾峰ù婊勭矒閺岀喖宕崟顓夈儵鏌涜箛鎾存拱闁靛洤瀚伴崺锟犲磼濠婂啫缁╅梻浣筋嚃閸犳盯锝炴径濞界細妞ゅ繐鐗嗙粻顖溾偓鍏夊亾濠电姴鍊搁煢闂傚倸鍊峰ù鍥敋瑜庨〃銉╁箹娴g懓浜繝闈涘€绘灙闁藉啰鍠栭弻銊モ攽閸♀晜笑缂備胶濯寸紞渚€寮婚妸銉㈡斀闁糕剝锚閺呬粙姊洪悷鏉库挃缂侇噮鍨堕幃锟犳偄閸忚偐鍘甸梺璇″瀻閸涱喗鍠栫紓鍌欒閸嬫捇鎮楅敐搴℃灍闁绘挻绋撻埀顒€鍘滈崑鎾绘倵閿濆骸澧伴柣锕€鐗撻幃妤冩喆閸曨剛顦ㄩ柣銏╁灡鐢繝宕洪悙鍝勭闁挎洍鍋撻柣鎰躬閺屽秹鎮烽幍顔界殤闂佺ǹ顑嗛幐鑽ゆ崲濠靛绀嬫い鎾跺缁卞啿鈹戦悙鑸靛涧缂佽弓绮欓獮鏍敃閵忊剝鐦庣紓鍌氬€搁崐椋庢閿熺姴闂い鏇楀亾鐎规洖缍婇幊婊堝礂閸濄儳鐣鹃梻浣圭湽閸ㄧ粯鐏欑紓浣插亾閻庯綆鍋佹禍婊堟煛瀹ュ啫濡奸柛銈庡墯缁绘盯鎮℃惔顖濆惈濠殿喖锕ュ浠嬬嵁閹邦厽鍎熼柨婵嗗€归~宥夋⒑鐠囨彃顒㈤柛鎴濈秺瀹曪綁宕橀妸褎娈鹃梺瑙勫劶濡嫮鐥閹綊宕堕埡浣峰濠碘槅鍋勯崯鎾嵁閸愵喖鐓涢柛娑卞櫘濡啫鈹戦悙鏉戠仸妞ゃ劌鐗撻獮鎴﹀即閻斿墎绠氶梺缁樺姦娴滄粓鍩€椤掍胶澧电€规洖缍婇幃浠嬪级閸℃鍠樻俊顐㈠暙閳藉宕¢悙鎼悪濠碉紕鍋戦崐鏍礉瑜忕划濠氬箣閻樺樊妫滄繝闈涘€搁幉锟犳偂閻斿吋鐓欓梺顓ㄧ畱楠炴绱撳鍡楃仸缂佺粯鐩畷濂稿閻樺磭浜繝娈垮枛閿曘儱顪冮挊澹╂盯宕橀妸銏☆潔闁哄鐗滈悡鍫ュ焵椤掆偓濡瑧鎹㈠┑鍫濇瀳婵☆垰鍢叉禍楣冩煣韫囷絽浜為柍瑙勭洴濮婃椽妫冨☉娆忣槱闂佸憡姊归悷锔界┍婵犲洤绠瑰ù锝呮憸閸樻悂姊虹粙鎸庢拱妞ゃ劌妫涢埀顒佽壘閵堢ǹ顫忓ú顏呭殥闁靛牆鎲涢姀锛勭閻犲泧鍛殼闂佽鍣换婵嬪极閹剧粯鍋戦柍褜鍓熷顐f媴闁稓绠氶梺闈涚墕閹冲繘宕冲ú顏呯厽闁规儳鐡ㄧ粈鍐ㄇ庨崶褝韬い銏$☉閳规垿宕卞Δ浣稿姃闂傚倷鐒﹀鍧楀储閻e本鏆滈柣鎰惈閻掑灚銇勯幒鎴濇灓婵炲吋鍔栫换娑㈠矗婢舵稖鈧法鈧娲栫紞濠傜暦缁嬭鏃堝礃閵娧佸亰濠电姷顣藉Σ鍛村垂閻㈢ǹ纾婚柟閭﹀枛椤ユ岸鏌涜箛娑欙紵缂佽妫欓妵鍕冀閵娧呯厐闁汇埄鍨甸崺鏍€冮妷鈺傚€烽柤纰卞墮閳潧鈹戦纭峰姛缂侇噮鍨堕獮蹇涘川閺夋垳绱堕梺闈涱樈閻忔繈濡搁埡鍌楁嫼缂備礁顑嗛娆撳磿韫囨稒鐓ラ柡鍥ュ妺缁ㄥ鏌i敐鍥у幋濠殿喒鍋撻梺鎸庣☉鐎氭澘顬婇鍓х=濞达絽澹婇崕鎾寸箾婢跺绀嬮挊婵囥亜閺囨浜惧┑顔硷攻濡炶棄螞閸愩劉妲堟慨姗嗗墻閺嗩偅绻濈喊妯活潑闁稿鎳愮划娆撳箻鐠哄搫鐏婄紓鍌欑劍鑿ч柛瀣嚇閺屾盯骞囬妸锔界彇闂佸憡锚瀹曨剟鈥旈崘顔嘉ч柛鈩冾殔琚濋梻浣呵归鍛偓姘煎弮瀵煡宕奸弴銊︽櫖闂佺粯鍔栧ḿ娆撳焵椤掆偓閻忔岸骞堥妸銉庣喖鎮℃惔婵嗩棜闂佽瀛╅悢顒勫箯閿燂拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌熼梻瀵割槮缁炬儳缍婇弻鐔兼⒒鐎靛壊妲紒鐐劤缂嶅﹪寮婚悢鍏尖拻閻庨潧澹婂Σ顔剧磼閻愵剙鍔ゆ繝鈧柆宥呯劦妞ゆ帒鍊归崵鈧柣搴㈠嚬閸欏啫鐣峰畷鍥ь棜閻庯絻鍔嬪Ч妤呮⒑閸︻厼鍔嬮柛銊ョ秺瀹曟劙鎮欏顔藉瘜闂侀潧鐗嗗Λ妤冪箔閸屾粎纾奸柍褜鍓氱粭鐔煎焵椤掆偓閻e嘲饪伴崼顐f櫍闂佺粯鍨靛Λ娆戔偓闈涚焸濮婃椽妫冨☉姘暫濠碘槅鍋呴〃鍡涘箞閵婎煈妲剧紓浣介哺鐢繝骞冮埡鍛闁肩⒈鍏涚槐婵嬫⒒娴h櫣甯涘〒姘殜瀹曟娊鏁愰崱妯哄伎闂侀€炲苯澧撮柡灞炬礋瀹曠厧鈹戦崶鑸碉骏闂備礁鎲¤摫闁圭懓娲濠氬焺閸愩劎绐為柣蹇曞仦閸ㄦ繂鈻介鍛瘈闁靛繈鍨洪崵鈧┑鈽嗗亝缁诲倿鎮惧畡鎵虫斀闁糕檧鏅涢幃鎴︽⒑缁洖澧查柛鏃€甯為懞杈ㄧ節濮橆厸鎷洪梺鍛婄箓鐎氼剟鍩€椤掍焦鍊愰柟顔矫埞鎴犫偓锝呯仛閺呮粌顪冮妶鍡楀闁稿﹥顨堟竟鏇熺附缁嬭法楠囬梺鍓插亝缁嬫垶淇婇悾灞稿亾鐟欏嫭绀€闁活剙銈搁崺鈧い鎺戝枤濞兼劖绻涢崣澶呯細闁轰緡鍣i獮鎺懳旂€n剛鈼ゆ繝鐢靛█濞佳囶敄閹版澘鏋侀柛鏇ㄥ灡閻撱垺淇婇娆掝劅婵℃彃鍢查…璺ㄦ喆閸曨剛顦板┑顔硷攻濡炶棄鐣烽妸锔剧瘈闁告洦鍘剧粣妤呮⒒娴e懙鍦偓娑掓櫆缁绘稒绻濋崶褏鐣鹃柣蹇曞仩琚欓柡瀣叄閺岀喖骞嗚閸ょ喖鏌涘鈧禍璺侯潖濞差亜浼犻柛鏇ㄥ墮閸嬪秹姊洪崨濠冪叆闁活厼鍊块獮鍐潨閳ь剟骞冮埡鍛仺闁汇垻顣槐鏌ユ⒒娴h櫣甯涢柣鐔村灲瀹曟垿骞樼紒妯煎幈闂侀潧枪閸庢娊宕洪敐鍥e亾濞堝灝鏋涙い顓㈡敱娣囧﹪骞栨担鍝ュ幐闂佺ǹ鏈惌顔捐姳娴犲鈷掑ù锝呮嚈瑜版帒瀚夋い鎺戝€婚惌娆撴煙鏉堟儳鐦滈柡浣稿€块弻銊╂偆閸屾稑顏�闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌熼梻瀵割槮缁炬儳缍婇弻鐔兼⒒鐎靛壊妲紒鐐劤缂嶅﹪寮婚悢鍏尖拻閻庨潧澹婂Σ顔剧磼閻愵剙鍔ょ紓宥咃躬瀵鏁愭径濠勵吅闂佹寧绻傞幉娑㈠箻缂佹ḿ鍘遍梺闈涚墕閹冲酣顢旈銏$厸閻忕偛澧藉ú瀛樸亜閵忊剝绀嬮柡浣瑰姍瀹曞崬鈻庡Ο鎭嶆氨绱撻崒姘偓鐑芥嚄閼稿灚鍙忛梺鍨儑缁犻箖鏌嶈閸撶喖寮婚垾宕囨殕闁逞屽墴瀹曚即寮借閺嗭附绻濇繝鍌涳紞婵℃煡绠栭弻锝夊閳轰胶浠梺鐑╂櫓閸ㄨ泛顕g拠娴嬫婵﹫绲芥禍楣冩煥濠靛棗鏆欏┑鈥炽偢閺屽秷顧侀柛鎾存皑閹广垽宕煎┑鎰婵犵數濮甸懝楣冨础閹惰姤鐓熼柡鍐ㄦ处椤忕姵銇勯弮鈧ú鐔奉潖閾忓湱纾兼俊顖氭惈琚濋梻浣告啞閹歌鐣濋幖浣哥畺闁汇垻枪閸楁娊鏌曡箛濠冾€嗛柟鐤缁辨挻鎷呴崜鎻掑壉濡炪倖鍨堕悷鈺佺暦閺囷紕鐤€闁哄倽顔婄花濠氭⒑閻熸壆鎽犵紒璇茬Т铻i柍褜鍓熼幃妤€鈻撻崹顔界亪濡炪値鍘鹃崗妯侯嚕椤愶箑绠涙い鎾跺仧缁愮偞绻濋悽闈浶㈤悗姘煎櫍瀵爼宕ㄦ繝浣虹畾闂佺粯鍔︽禍婊堝焵椤掍胶澧遍柡渚囧枟缁绘繈宕堕妸銉㈠亾閸ф鐓ラ柡鍥╁仜閳ь剙鎽滄竟鏇㈠锤濡や胶鍘甸梺鍛婃寙閸涱厾顐奸梻浣瑰▕閺€閬嶅垂閸︻厽顫曢柟鎯х摠婵潙鈹戦钘夌劸濞存粎鍋熼崚鎺楊敇閵忕姷顔婂┑掳鍊撻懗鍫曞储娴犲顥婃い鎰╁灪婢跺嫰鏌$仦璇插鐎规洦鍋婂畷顐﹀礋閵婏附鏉搁梻浣瑰缁嬫垹鈧凹鍙冨鎶筋敆閸屾浜鹃悷娆忓缁€鍫ユ煕閻樺磭澧甸柕鍡曠閳藉顫滈崱妯哄厞濠碘剝褰冮張顒勬偋閺囥垹鏋佸ù鐘差儐閳锋帡鏌涚仦鍓ф噭缂佷胶澧楅妵鍕敃閵忊晜鈻堝Δ鐘靛仜濡鎮惧┑瀣妞ゆ劑鍨婚埀顒夊弮濮婄粯绗熼崶褍顫╃紓浣割槹閹稿啿顕i崨濠冨闁煎弶绻冨Λ鍐极閹版澘宸濇い鎾跺枑椤斿姊绘担铏瑰笡闁规悂绠栧畷浼村冀椤撶姴绁﹂梺鍝勭▉閻忔梹鎯旈…鎴炴櫌闂侀€炲苯澧撮柟顔斤耿椤㈡岸鍩€椤掑嫬钃熸繛鎴欏灪閸嬪嫰鏌涘┑鍕姎鐎殿喓鍔戝娲传閸曨厾浼囬梺鍝ュУ閻楁洟鎮惧畡鎵虫瀻闁圭偓绶炶閺屾盯鍩勯崘鐐吂婵炲銆嬮幏锟�濠电姷鏁告慨鐑藉极閸涘﹥鍙忛柣鎴f閺嬩線鏌涘☉姗堟敾闁告瑥绻橀弻锝夊箣閿濆棭妫勯梺鍝勵儎缁舵岸寮诲☉妯锋婵鐗婇弫楣冩⒑閸涘﹦鎳冪紒缁橈耿瀵鏁愭径濠勵吅闂佹寧绻傚Λ顓炍涢崟顖涒拺闁告繂瀚烽崕搴g磼閼搁潧鍝虹€殿喖顭烽幃銏ゅ礂鐏忔牗瀚介梺璇查叄濞佳勭珶婵犲伣锝夘敊閸撗咃紲闂佽鍨庨崘锝嗗瘱缂傚倷绶¢崳顕€宕归幎钘夌闁靛繒濮Σ鍫ユ煏韫囨洖啸妞ゆ挻妞藉娲传閸曨偅娈滈梺绋款儐閹瑰洭寮诲☉銏犖ч柛娑卞瀺瑜旈弻锛勪沪閸撗勫垱婵犵绱曢崗姗€銆佸▎鎾村亗閹煎瓨蓱鐎氫粙姊婚崒娆愮グ婵℃ぜ鍔庣划鍫熸媴鐠囥儲妞介、姗€濮€閻樼儤鎲伴梻浣告惈濞村嫮妲愰弴銏″仾闁逞屽墴濮婃椽宕崟顒€绐涢梺绋库看閸嬪﹥淇婇悜鑺ユ櫆閺夌偞澹嗛惄搴ㄦ⒒娴g懓顕滄俊顐$窔椤㈡俺顦查柍璇茬Т椤撳吋寰勭€n剙骞嶆俊鐐€栧濠氭偤閺傚簱鏋旀繝濠傛噳閸嬫挾鎲撮崟顒傤槰濡炪們鍔屽Λ妤咁敋閵夆晛绀嬫い鎺戝€婚惁鍫熺箾鏉堝墽鍒板鐟帮工铻炴繝濠傜墛閳锋帡鏌涚仦鎹愬闁逞屽墴椤ユ挾鍒掗崼鐔虹懝闁逞屽墴閻涱喗寰勯幇顒備紜闁烩剝甯婇悞锕€顪冩禒瀣瀬闁告劦鍠栫壕鍏兼叏濡鏁剧紒鍗炲船閳规垿鎮╅鑲╀紘闂佺硶鏅滈悧鐘茬暦濠靛鍗抽柕蹇曞Т瀵兘姊洪棃娑辨Т闁哄懏绮撻幃锟犳偄閸忚偐鍘甸梻渚囧弿缁犳垿寮稿☉銏$厱闁哄倹顑欓崕鏃堟煛鐏炵晫效闁哄被鍔庨埀顒婄秵娴滅偞瀵煎畝鍕拺閻犲洠鈧櫕鐏堢紓鍌氱Т閿曨亪鎮伴鐣岀懝闁逞屽墴閻涱噣骞掑Δ鈧粻锝嗙節閸偄濮夐柍褜鍓濆▍鏇犳崲濠靛鍋ㄩ梻鍫熺◥缁爼姊洪悷鏉挎毐缂佺粯锚閻e嘲鈹戦崱蹇旂€婚梺瑙勫劤閻ゅ洭骞楅弴銏♀拺缂備焦蓱閳锋帡鏌涘Ο鐘叉噽閻棝鏌涢弴銊ョ仭闁绘挸绻橀弻娑㈩敃閿濆洨鐣哄銈冨劜缁秹濡甸崟顔剧杸闁靛绠戦锟�
【有奖直播】2025是德科技数字月-数字新品来助阵
直播时间:3月19日(周三)14:00
直播奖励:小米口红充电宝、倍思充电线、是德科技十周年鼠标垫
