#include<reg52.h>
#define uint unsigned int #define uchar unsigned char
uchar code shumaguan[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; uchar code table[] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar key = 0;
void delays(int ms) { int i; int j; for(i = 0;i<ms;i++) for(j = 0; j<124;j++); }
void matrixkeyscan() { uchar temp;
P0 = 0xfe; temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { delays(10); temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { temp = P0; switch(temp) { case 0xee: key = 0; break; case 0xde: key = 1; break; case 0xbe: key = 2; break; case 0x7e: key = 3; break; } while(temp != 0xf0) { temp = P0 ; temp = temp & 0xf0; } //display() ; } }
P0 = 0xfd; temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { delays(10); temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { temp = P0; switch(temp) { case 0xed: key = 4; break; case 0xdd: key = 5; break; case 0xbd: key = 6; break; case 0x7d: key = 7; break; } while(temp != 0xf0) { temp = P0 ; temp = temp & 0xf0; } //display() ; } }
P0 = 0xfb; temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { delays(10); temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { temp = P0; switch(temp) { case 0xeb: key = 8; break; case 0xdb: key = 9; break; case 0xbb: key = 10; break; case 0x7b: key = 11; break; } while(temp != 0xf0) { temp = P0 ; temp = temp & 0xf0; } //display() ; } }
P0 = 0xf7; temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { delays(10); temp = P0; temp = temp & 0xf0; if(temp != 0xf0) { temp = P0; switch(temp) { case 0xe7: key = 12; break; case 0xd7: key = 13; break; case 0xb7: key = 14; break; case 0x77: key = 15; break; } while(temp != 0xf0) { temp = P0 ; temp = temp & 0xf0; } //display() ; } } }
void main() { while(1) { matrixkeyscan(); P2 = table[0]; P1 = shumaguan[key]; } }
今天,新讲的扫描,没有搞懂。 知道如何控制行,但,对于列的控制,很是不明白、。
期待,详细解释、
