7889|20
5314
453
EKK-LM4F232例程一 PWM外设 [复制链接]
 PWM相关函数原型
void ROM_PWMDeadBandDisable (unsigned long ulBase, unsigned long ulGen)
禁止PWM死区输出
void ROM_PWMDeadBandEnable (unsigned long ulBase, unsigned long ulGen, unsigned short usRise, unsigned short usFall)
使能PWM死区输出,设置死区延时
void ROM_PWMFaultIntClear (unsigned long ulBase)
清除一个PWM模块的故障中断
void ROM_PWMFaultIntClearExt (unsigned long ulBase, unsigned long ulFaultInts)
清除一个PWM模块的故障中断
void ROM_PWMGenConfigure (unsigned long ulBase, unsigned long ulGen, unsigned long ulConfig)
配置一个PWM发生器
void ROM_PWMGenDisable (unsigned long ulBase, unsigned long ulGen)
禁止一个PWM发生器模块的定时器/计数器
void ROM_PWMGenEnable (unsigned long ulBase, unsigned long ulGen)
使能一个PWM发生器模块的定时器/计数器
void ROM_PWMGenFaultClear (unsigned long ulBase, unsigned long ulGen, unsigned long ulGroup, unsigned long ulFaultTriggers)
清除给定的PWM发生器的一个或多个锁存故障触发
void ROM_PWMGenFaultConfigure (unsigned long ulBase, unsigned long ulGen, unsigned long ulMinFaultPeriod, unsigned long ulFaultSenses)
配置给定的PWM发生器的最小故障周期和故障管脚检测
unsigned long ROM_PWMGenFaultStatus (unsigned long ulBase, unsigned long ulGen, unsignedlong ulGroup)
返回到给定的PWM发生器的故障触发的当前状态
unsigned long ROM_PWMGenFaultTriggerGet (unsigned long ulBase, unsigned long ulGen,unsigned long ulGroup)
返回到给定的PWM发生器当前所配置的故障触发设置
void ROM_PWMGenFaultTriggerSet (unsigned long ulBase, unsigned long ulGen, unsigned long ulGroup, unsigned long ulFaultTriggers)
配置给定的PWM发生器的故障触发设置。
void ROM_PWMGenIntClear (unsigned long ulBase, unsigned long ulGen, unsigned long ulInts)
清除特定的PWM发生器模块的特定中断。
查看本帖全部内容,请登录或者注册
还是很感谢  详情 回复 发表于 2011-12-9 16:55
5314
453
unsigned long ROM_PWMGenIntStatus (unsigned long ulBase, unsigned long ulGen,tBoolean bMasked)
获取指定PWM发生器模块的中断状态
void ROM_PWMGenIntTrigDisable (unsigned long ulBase, unsigned long ulGen, unsigned long ulIntTrig)
禁止指定PWM发生器模块的中断
void ROM_PWMGenIntTrigEnable (unsigned long ulBase, unsigned long ulGen, unsigned long ulIntTrig)
使能指定PWM发生器模块的中断和触发
unsigned long ROM_PWMGenPeriodGet (unsigned long ulBase, unsigned long ulGen)
获取一个PWM发生器模块的周期。
void ROM_PWMGenPeriodSet (unsigned long ulBase, unsigned long ulGen, unsigned long ulPeriod)
设置一个PWM发生器的周期
void ROM_PWMIntDisable (unsigned long ulBase, unsigned long ulGenFault)
禁止一个PWM模块的发生器中断和故障中断。
void ROM_PWMIntEnable (unsigned long ulBase, unsigned long ulGenFault)
使能一个PWM模块的发生器中断和故障中断
unsigned long ROM_PWMIntStatus (unsigned long ulBase, tBoolean bMasked)
获取一个PWM模块的中断状态
void ROM_PWMOutputFault (unsigned long ulBase, unsigned long ulPWMOutBits, tBoolean bFaultSuppress)
指定响应一个故障条件的PWM输出的状态。
void ROM_PWMOutputFaultLevel (unsigned long ulBase, unsigned long ulPWMOutBits, tBoolean bDriveHigh)
指定被抑制的PWM输出电平(level),以响应一个故障条件
void ROM_PWMOutputInvert (unsigned long ulBase, unsigned long ulPWMOutBits, tBoolean bInvert)
选择PWM输出的翻转方式。
void ROM_PWMOutputState (unsigned long ulBase, unsigned long ulPWMOutBits, tBoolean bEnable)
使能或禁止PWM输出
unsigned long ROM_PWMPulseWidthGet (unsigned long ulBase, unsigned long ulPWMOut)
获取一个PWM输出的脉宽
void ROM_PWMPulseWidthSet (unsigned long ulBase, unsigned long ulPWMOut, unsigned long ulWidth)
设置指定PWM输出的脉宽
void ROM_PWMSyncTimeBase (unsigned long ulBase, unsigned long ulGenBits)
使一个或多个PWM发生器模块的计数器同步
void ROM_PWMSyncUpdate (unsigned long ulBase, unsigned long ulGenBits)
同步所有挂起的更新
5314
453
要求:  实验对运动控制模块0的PWM输出8路PWM, 不同的占空比信号
说明:程序直接在sine_demo里修改
在原来添加以下头文件
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/pwm.h"
#include "driverlib/rom.h"
#include "driverlib/pin_map.h"
5314
453
在FPUEnable(); FPULazyStackingEnable(); 后添加实验代码
//设置系统时钟
 ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_XTAL_16MHZ |
                        SYSCTL_OSC_MAIN);
 //读系统时钟
 SysClock=ROM_SysCtlClockGet();
 //设置PWM时钟:不分频
 ROM_SysCtlPWMClockSet(SYSCTL_PWMDIV_1);
 //读PWM时钟
 Clock1=ROM_SysCtlPWMClockGet();
 //*************PWM输出实验******************************************
 //配置PWM所在的管脚外设
 ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
 //使能PWM模块:SYSCTL_PERIPH_PWM0 or SYSCTL_PERIPH_PWM1
 ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);
 //设置指定的管脚配置
 ROM_GPIOPadConfigSet( GPIO_PORTH_BASE,
       GPIO_PIN_0|GPIO_PIN_1|
       GPIO_PIN_2|GPIO_PIN_3|
       GPIO_PIN_4|GPIO_PIN_5|
       GPIO_PIN_6|GPIO_PIN_7,
       GPIO_STRENGTH_4MA,
       GPIO_PIN_TYPE_STD);
  //配置GPIO为PWM功能:
  ROM_GPIOPinTypePWM( GPIO_PORTH_BASE,
  //配置一个GPIO引脚的备用功能 要包含 driverlib/pin_map.h头文件
  ROM_GPIOPinConfigure(GPIO_PH0_M0PWM0);
  ROM_GPIOPinConfigure(GPIO_PH1_M0PWM1);
  ROM_GPIOPinConfigure(GPIO_PH2_M0PWM2);
  ROM_GPIOPinConfigure(GPIO_PH3_M0PWM3);
  ROM_GPIOPinConfigure(GPIO_PH4_M0PWM4);
  ROM_GPIOPinConfigure(GPIO_PH5_M0PWM5);
  ROM_GPIOPinConfigure(GPIO_PH6_M0PWM6);
  ROM_GPIOPinConfigure(GPIO_PH7_M0PWM7);
  //配置一个PWM发生器:计数,同步(非)模式
  ROM_PWMGenConfigure(PWM0_BASE,PWM_GEN_0,PWM_GEN_MODE_UP_DOWN|PWM_GEN_MODE_NO_SYNC);
  ROM_PWMGenConfigure(PWM0_BASE,PWM_GEN_1,PWM_GEN_MODE_UP_DOWN|PWM_GEN_MODE_NO_SYNC);
  ROM_PWMGenConfigure(PWM0_BASE,PWM_GEN_2,PWM_GEN_MODE_UP_DOWN|PWM_GEN_MODE_NO_SYNC);
  ROM_PWMGenConfigure(PWM0_BASE,PWM_GEN_3,PWM_GEN_MODE_UP_DOWN|PWM_GEN_MODE_NO_SYNC);
  //设置一个PWM发生器的周期
  ROM_PWMGenPeriodSet(PWM0_BASE,PWM_GEN_0,16000);
  ROM_PWMGenPeriodSet(PWM0_BASE,PWM_GEN_1,16000);
  ROM_PWMGenPeriodSet(PWM0_BASE,PWM_GEN_2,16000);
  ROM_PWMGenPeriodSet(PWM0_BASE,PWM_GEN_3,16000);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_0,16000*0.9);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_1,16000*0.8);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_2,16000*0.7);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_3,16000*0.6);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_4,16000*0.5);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_5,16000*0.4);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_6,16000*0.2);
  //设置指定PWM输出的脉冲宽度
  ROM_PWMPulseWidthSet(PWM0_BASE,PWM_OUT_7,16000*0.1);
  //使能PWM输出
  ROM_PWMOutputState(PWM0_BASE,PWM_OUT_0_BIT|PWM_OUT_1_BIT|
         PWM_OUT_2_BIT|PWM_OUT_3_BIT|
         PWM_OUT_4_BIT|PWM_OUT_5_BIT|
         PWM_OUT_6_BIT|PWM_OUT_7_BIT
         ,true);
  //使能一个PWM发生器模块的定时器
  ROM_PWMGenEnable(PWM0_BASE,PWM_GEN_0);
  ROM_PWMGenEnable(PWM0_BASE,PWM_GEN_1);
  ROM_PWMGenEnable(PWM0_BASE,PWM_GEN_2);
  ROM_PWMGenEnable(PWM0_BASE,PWM_GEN_3);
[ 本帖最后由 蓝雨夜 于 2011-11-9 14:16 编辑 ]
5314
453
注意:
//配置一个GPIO引脚的备用功能 ROM_GPIOPinConfigure(GPIO_PH0_M0PWM0); 不能少哦!
同时要添加 driverlib/pin_map.h头文件 不然会没有输出 了
1803
回复 5楼 蓝雨夜 的帖子
请教一个问题:
同步所有挂起的更新
这两个 API 具体要怎么使用?
我一直分得不太明白。
是可以单独用呢?还是要配合使用。
5314
453
这几个我还没实践过
5314
453
到时看下里面的寄存器
这两个应该在同步模式下工作的吧
1803
回复 8楼 蓝雨夜 的帖子
是的,必须在同步模式下,不在同步模式下,这两个是无效的。
5314
453
这2个函数分别是对 PWMSYNC 时基同步寄存器和
PWMCTL 主控寄存器的操作
5314
453
同步:发生器和他的两个输出信号通过共用的统一时钟与其它PWM发生器保持联系。如果多个PWM发生器配置使用相同的计时器装载值,同步可以保证他们有相同的计数值(在同步之前必须配置PWM发生器)。由于这个特性,可以在那些信号边沿之间产生2个以上的关系已知的PWM n信号,因为计数器总是保持着相同的值。单位中的其他状态提供了一种机制维持共用时基和相互同步。
5314
453
PWM中断
一、添加相关中断头文件
//Macros that define the interrupt assignment on Stellaris
#include "inc/hw_ints.h"
//Prototypes for the NVIC Interrupt Controller Driver
#include "driverlib/interrupt.h"
二、在基本PWM配置基础上
//使能PWM发生器1归零触发中断
  ROM_PWMGenIntTrigEnable(PWM0_BASE,   //宏hw_memmap.h
        PWM_GEN_0,
        PWM_INT_CNT_ZERO);
  //使能PWM发生器1中断
  ROM_PWMIntEnable(PWM0_BASE,PWM_INT_GEN_0); //宏pwm.h
  // 使能PWM1中断
  ROM_IntEnable(INT_PWM0_0);     //宏hw_ints.h
  //使能总中断
  ROM_IntMasterEnable();
三、运动模块0的PWM0中断函数
//M0PWM0中断
void PWM0_Generator_0_ISR(void)
 static unsigned long n=0;
 ROM_PWMGenIntClear( PWM0_BASE,
      PWM_GEN_0,
      PWM_INT_CNT_ZERO);
 //设置PWM输出的脉宽
 if(n==0)
 PWMPulseWidthSet( PWM0_BASE,
      PWM_OUT_0,
      16000*0.5);
      n=1;
 else
      PWM_OUT_0,
      16000*0.9);
      n=0;
四、在startup_rvmdk.s里对中断函数声明
1、EXPORT  __Vectors上面增加:EXTERN  PWM0_Generator_0_ISR
2、修改 DCD     PWM0_Generator_0_ISR           ; PWM Generator 0
[ 本帖最后由 蓝雨夜 于 2011-11-9 22:13 编辑 ]
1727
学习一下!
1180
看来楼主很强嘛
初学M4
//设置系统时钟
                        SYSCTL_OSC_MAIN);
刚学arm看不明白,这儿为什么是设置时钟。而且后面是四个或的选择设置
5314
453
刚进入MAIN就要对系统时钟进行一系列的初始化,首先系统时钟是必须配置起来的
哦 这个问题问的有点傻 还请您多多谅解
SYSCTL_OSC_MAIN)
第一个是分频,第二个是锁相环时钟,第三个是外部时钟 ……
难道这个设置是表示系统同时设置这四个项吗?而不是单单设置某一个项呢
5314
453
你看他们之间是什么关系
你可以深入了解下它的函数原形是对那些寄存器操作,你对应PDF就知道为什么这么设置了!
还请问下
M4里面怎么去实现定时器控制PWM脉冲频率
有相关的例程可以参考下吗?
5314
453
这个要自己写了!
电源解决方案和技术 | DigiKey 应用探索站
