5387|7
6483
管理员
OPA2209:36V RRO 精密运算放大器datasheet&应用手册 [复制链接]
器件介绍:
The OPA209 series of precision operational amplifiers achieve very low voltage noise density (2.2nV/√Hz) with a supply current of only 2.5mA (max). This series also offers rail-to-rail output swing, which helps to maximize dynamic range.
In precision data acquisition applications, the OPA209 provides fast settling time to 16-bit accuracy, even for 10V output swings. This excellent ac performance, combined with only 150µV (max) of offset and low drift over temperature, makes the OPA209 very suitable for fast, high-precision applications.
The OPA209 is specified over a wide dual power-supply range of ±2.25 to ±18V, or single-supply operation from +4.5V to +36V.
The OPA209 is available in the SOT23-5, MSOP-8 and the standard SO-8 packages.
DataSheet:
OPA2209.pdf (835.63 KB, 下载次数: 777)
应用手册:
所选封装材料的热学和电学性质.pdf (645.09 KB, 下载次数: 176)
高速数据转换.pdf (1.92 MB, 下载次数: 241)
运算放大器的单电源操作.pdf (2.12 MB, 下载次数: 335)
Tuning in Amplifiers.pdf (44.08 KB, 下载次数: 145)
Op Amp Performance Analysis.pdf (76.56 KB, 下载次数: 32)
Shelf-Life Evaluation of Lead-Free Component Finishes.pdf (1.28 MB, 下载次数: 276)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
好东西哦  详情 回复 发表于 2012-3-15 11:11
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
89
真给力这次活动.OPA芯片这真给力这次活动.adc芯片这个用上去,应该效果很好的.谢谢
几个运放各有千秋啊
很不错的芯片
63
期待中啊!
一样期待中
29
好宝贝,期待
好东西哦
