3789|12
252
请教高手 [复制链接]
本人做了个光源,遇到疑问请各位高手不吝赐教。此光源采用PWM调光,采用STC12CLE5A48S2单片机,LCD显示LED光源的亮度,定时器1作为串口波特率发生器,定时器0用来产生PWM方波。程序在不加EEPROM读写子程序,光源能正常通过按键进行调光,但是在加了EEPROM读写子程序,在有调光按键按下时,光源都会产生闪烁。听别人说,是EEPROM子程序和其他程序在占用硬件上有冲突,但是还是不懂,不知道哪边有冲突。麻烦高手指点一下,谢谢喽。如果需要程序我可以把程序附上,如果我有什么说不清楚的地方,请指出了,我可以详细再说下。再谢。
此帖出自51单片机论坛
可有软件手段回避或者减轻?  详情 回复 发表于 2011-10-19 11:01
535
拿程序过来看看撒!没有程序不好说啊!
此帖出自51单片机论坛
252
回复 沙发 小小白 的帖子
C语言写的  我分几部分给您检查下  谢谢
先一些变量的定义
#define uchar unsigned char
#define uint unsigned int
#define CTRL  0x2F
#define databus  P0
#define DATA_FLASH_START_ADDRESS 0x00
#define ENABLE_ISP 0x82
sbit  CS1 = P2^3;
sbit  RES = P2^4;
sbit  A0 = P2^5;
sbit  WR = P2^6;
sbit  RD = P2^7;
sbit key1 = P1^5;
sbit key2 = P1^6;
sbit DIM = P1^3;
bit flag1 = 0;
bit flag2 = 0;
uchar power;
uint y=1;
uint count_up ; //增按键计数值
uint count_down ; //减按键计数值
uchar contrast;
uint eeprom_address;
uchar code fenhao[]=
0x0F,0x10,0x0F,0x00,0x07,0x18,0x00,0x00,0x00,0x84,0x38,0xC0,0x78,0x84,0x78,0x00,//%
uchar code digit[]=
0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00,//0
0x00,0x08,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0xFC,0x04,0x04,0x00,0x00,//1
0x00,0x0E,0x10,0x10,0x10,0x11,0x0E,0x00,0x00,0x0C,0x14,0x24,0x44,0x84,0x0C,0x00,//2
0x00,0x0C,0x10,0x11,0x11,0x12,0x0C,0x00,0x00,0x18,0x04,0x04,0x04,0x88,0x70,0x00,//3
0x00,0x00,0x03,0x04,0x08,0x1F,0x00,0x00,0x00,0xE0,0x20,0x24,0x24,0xFC,0x24,0x00,//4
0x00,0x1F,0x10,0x11,0x11,0x10,0x10,0x00,0x00,0x98,0x84,0x04,0x04,0x88,0x70,0x00,//5
0x00,0x07,0x08,0x11,0x11,0x18,0x00,0x00,0x00,0xF0,0x88,0x04,0x04,0x88,0x70,0x00,//6
0x00,0x1C,0x10,0x10,0x13,0x1C,0x10,0x00,0x00,0x00,0x00,0xFC,0x00,0x00,0x00,0x00,//7
0x00,0x0E,0x11,0x10,0x10,0x11,0x0E,0x00,0x00,0x38,0x44,0x84,0x84,0x44,0x38,0x00,//8
0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,0x00,0x00,0x8C,0x44,0x44,0x88,0xF0,0x00,//9
uchar code bangtu[]=              //柱状图 15*30
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x01,0x01,0x03,0x03,0x07,0x07,0x0F,0x0F,0x1F,0x1F,0x3F,0x3F,0x7F,0x7F,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
uchar code off[]=
0x07,0x08,0x10,0x10,0x10,0x08,0x07,0x00,0xF0,0x08,0x04,0x04,0x04,0x08,0xF0,0x00,//O
uchar code gong[]=
0x00,0x20,0x20,0x20,0x3F,0x20,0x28,0x28,0x08,0x09,0xFE,0x08,0x08,0x0F,0x00,0x00,
0x20,0x30,0x20,0x20,0xC0,0x42,0x44,0x88,0x30,0xC4,0x04,0x06,0x04,0xF8,0x00,0x00,//功
uchar code lv[]=
0x00,0x30,0x28,0x25,0x20,0x26,0xAC,0x75,0x26,0x24,0x28,0x25,0x28,0x20,0x20,0x00,
0x10,0x50,0x90,0x10,0x10,0x50,0xD0,0x7F,0x50,0xD0,0x30,0x10,0x90,0x50,0x10,0x00,//率
//******** Initial System ********
void InitialSystem();
void InitialIO();
void Initial_timer0();
void Initial_Serial();
//******** Initial System  End********
//******** Key1_scan ******************************
void Key1_scan();
//******** Key1_scan End******************************
//******** Key2_scan ******************************
void Key2_scan();
//******** Key2_scan End******************************
//*********Upkey***************************************
void Upkey();
//*********Upkey End************************************
//*********Downkey***************************************
void Downkey();
//*********Downkey End************************************
//******** PWM_P13 ******************************
uchar  duty ;
uchar PWM_P13();
//******** PWM_P13 End******************************
//******** Delay ******************************
void Delay(uint time);
//******** Delay End******************************
此帖出自51单片机论坛
139
STC的“EEPROM”其实是程序FLASH,通过IAP实现,Flash的擦除和写入的时间比较长,如果数据量大或者程序调度的效率不够,那么自然会影响程序循环的时间,具体需要进行合理的工艺设计来改善。
此帖出自51单片机论坛
252
EEPROM读写子程序部分
void IAP_Disable()
         IAP_CONTR = 0;
         IAP_CMD = 0;
         IAP_TRIG = 0;
         IAP_ADDRH = 0;
         IAP_ADDRL = 0;
uint Byte_Read(uint add)
         IAP_DATA = 0x00;
         IAP_CONTR = ENABLE_ISP;
         IAP_CMD = 0x01;
         my_unTemp16.un_temp16 = add;
         IAP_ADDRH = my_unTemp16.un_temp8[0];
         IAP_ADDRL = my_unTemp16.un_temp8[1];
         EA = 0;                                         //???????????????
         IAP_TRIG = 0x5A;
         IAP_TRIG = 0xA5;
         _nop_();                                         //头文件中已包含这个函数,产生一个NOP指令
         EA = 1;                                         //??????????????
         IAP_Disable();
         return(IAP_DATA);
void Byte_Program(uint add, uchar ch)
         IAP_CMD = 0x02;
     IAP_DATA = ch;
         EA = 0;
         IAP_TRIG = 0x5A;
         IAP_TRIG = 0xA5;
         _nop_();
         EA = 1;
         IAP_Disable();
void Sector_Erase(uint add)
         IAP_CMD = 0x03;
         EA = 0;
         IAP_TRIG = 0x5A;
         IAP_TRIG = 0xA5;
         _nop_();
         EA = 1;
         IAP_Disable();
void EEPROM_read()
         eeprom_address = DATA_FLASH_START_ADDRESS;
         count_up = Byte_Read(eeprom_address);
         count_down = Byte_Read(eeprom_address+512);
void EEPROM_program()
         Sector_Erase(eeprom_address);
         Byte_Program(eeprom_address,count_up);
         Sector_Erase(eeprom_address+512);
         Byte_Program(eeprom_address+512,count_down);
此帖出自51单片机论坛
252
初始化及一些函数
//************I/O初始化*****************************************
void InitialIO()
        P1M0 = 0x08;        //P1.3推挽输出 ,P1.5,P1.6紧为输入
        P1M1 = 0x60;
        DIM = 0;
//************ 定时器0初始化 ***************************************
void Initial_timer0(void)
    AUXR = 0x80;   //T0为1T模式
        TMOD = 0x01;   // T0为模式1
    TH0 = (65536 - 26) / 256;;    //1KHzPWM波
    TL0 = (65536 - 26) % 256;;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
//************ 串口初始化 ***************************************
            AUXR|=0x40;    //Time1 1T
                SCON=0x50;          //串口模式设置
                TMOD=0x21;         //设置定时器1为8位自动重装计数器
                TH1=0xFD;        //波特率:115200
                TL1=0xFD;
                TR1=1;         //开定时器1
                ES=1;
                EA=1;
//************ PWM输出 ***************************************
uchar PWM_P13(duty)
        CMOD = 0x04;   //T0溢出作为PCA时钟输入源
    CL = 0x00;
    CH = 0x00;
          CCAP0H = duty;
        CCAP0L = duty;
        CCAPM0 = 0x42;   //8位PWM
    CR = 1;
//************ 定时0中断 ***************************************
void timer0_int (void) interrupt 1 using 1
//************ 串口接收中断 ***************************************
void Serial_isr() interrupt 4
                  uint temp;
            if(RI)
                         RI=0;
             temp  = SBUF;
                          SBUF = key1;
                     while(!TI);
                     TI = 0;
                         RI = 0;
                         temp = SBUF;
                     SBUF = count_up;
                     while(!TI);
                     TI = 0;
                         RI = 0;
                         temp = SBUF;
                         SBUF = count_down;
                     while(!TI);
                     TI = 0;
            else
                RI=0;
//************ 上按键判断 ***************************************
void Key1_scan()
           if(key1 == 0)
                  Delay(6);          //20ms
                  if(key1 == 0)
                           flag1 = 1;
                //         count_up ++;
                         Delay(300);
                         PCA_PWM0=0x00;
           else
                    flag1 = 0;
//************ 下按键判断 ***************************************
void Key2_scan()
           if(key2 == 0)
                     Delay(6); //20ms
                  if(key2 == 0)
                           flag2 = 1;
                        // count_down ++;
                         Delay(300);
           else
                    flag2 = 0;
//************ 上按键处理 ***************************************
void Upkey()
                if(flag1 == 1)
                    if(y!=0)
                        count_up ++;
                        y=256-(count_up-count_down)*256/100;
                        //y= (int)(t+5/10);
                        PWM_P13(y);
                    EEPROM_program() ;
//************ 下按键处理 ***************************************
void Downkey()
                if(flag2 == 1)
                        count_down ++;
                        //y= (int)(t+5/10);
                        if(y==256)
                        PCA_PWM0=0x03;
                        if(y>256)
                            //if(y>257)
                            count_down --;
                                PCA_PWM0=0x03;
                        PWM_P13(y);
                    EEPROM_program();
//************ 延时  ***************************************
    uchar i;
        while(time--)
                for(i = 0; i < 80; i ++)
此帖出自51单片机论坛
252
LCD显示屏初始化及其所要用的一些函数
uchar reverse(figure)   //反转P0口
        uchar a=0;
        uchar j,b;
        for(j=0;j<8;j++)
                  a=a>>1;
                  b=figure&0x80;
                  if(b!=0)
                            a=a|0x80;
                  figure=figure<<1;
   return a;
void CmdWrite(uchar cam_data)                  //写地址
  uchar CAMDATA;
  CAMDATA=reverse(cam_data);
  CS1=1;
  A0=0;
  CS1=0;
  RD=1;
  WR=0;
  databus=CAMDATA;
  WR=1;
  CS1=1;
void DataWrite(uchar data_data)                  //写数据
  CS1=1;
  A0=1;
  CS1=0;
  RD=1;
  WR=0;
  databus=data_data;
  WR=1;
  CS1=1;
void NT75451_INIT(void)          //128*64液晶屏初始化
    Delay(100);
        CmdWrite(0xE2);  //STANDBY MODE OFF
        Delay(40);
        //CmdWrite(0x34);
        CmdWrite(0xA2);  //bias set 1/9,1/65 DUTY  ,亮度设置
        CmdWrite(0xA0);  //ADC select SEG0 to SEG127 normal
        CmdWrite(0xC8);  //COM Reverse
        CmdWrite(0x40);  //Display Start Line Set =0
        Delay(20);
        CmdWrite(0x25);  //V0 Voltage Regulator Internal Resistor Ratio Set
        CmdWrite(0x2f);  //power control(VC,VR,VF=1,1,1)(028--02FH)--2f
        Delay(20);
        CmdWrite(0x81);  //Regulator resistor select 100(020H--027H)
        CmdWrite(CTRL);  //contrast
        Delay(20);
        //CmdWrite(0x00); //Initial Display Line/Number of Start Line Set-63-3F
        CmdWrite(0xA6);
        CmdWrite(0x89);  //Select DC-DC converter circuit
        CmdWrite(0x01);  //4 times boosting circuit
        CmdWrite(0xE5);  //Oscillation Frequency Select-31.4KHZ
        CmdWrite(0xA4);  //Entire Display ON
        CmdWrite(0xAf);  //turns the display ON
        Delay(100);
        contrast = CTRL;
void LCD_Reset(void)
//  RES=1;
//  DelayXms(2);
  RES=0;
  Delay(200);
  RES=1;
  Delay(200);//more than 150ms
void clear(void)                           //清屏
        uint i,j;
        for(i=0;i<8;i++)
            CmdWrite(i+0xb0);       //行地址
            CmdWrite(0x10);         //列地址
            CmdWrite(0x00);        //此指令是为了列地址能够自动递加
            for(j=0;j<128;j++)
                    DataWrite(0x00);
void display_WORD(uchar row,uchar line,uchar *character)  //写汉字
        uchar j;
        CmdWrite(0xb0+row);     //行
        CmdWrite(0x10+line);    //列
        CmdWrite(0x00);
        for(j=0;j<16;j++)
                  DataWrite(character[j]);
        CmdWrite(0xb1+row);     //行
        CmdWrite(0x00);
        for(j=16;j<32;j++)
void display_digit(uchar value)  //写数字
        uchar j,l,m,n;
        if(value>=100)
            value=100;
        l=value/100;
        m=value%100/10;
        n=value%100%10;
        if(l==0)
                 if(m==0)
                           CmdWrite(0xb3);
              CmdWrite(0x13);
              CmdWrite(0x00);
                           for(j=0;j<8;j++) {DataWrite(0x00);}
                           for(j=0;j<8;j++) {DataWrite(digit[n*16+j]);}
                        for(j=0;j<8;j++) {DataWrite(fenhao[j]);}
                           CmdWrite(0xb4);
              CmdWrite(0x13);
              CmdWrite(0x00);
                           for(j=8;j<16;j++) {DataWrite(0x00);}
                           for(j=8;j<16;j++) {DataWrite(digit[n*16+j]);}
                        for(j=8;j<16;j++) {DataWrite(fenhao[j]);}
                 else
                           CmdWrite(0xb3);
              CmdWrite(0x13);
              CmdWrite(0x00);
                           for(j=0;j<8;j++) {DataWrite(digit[m*16+j]);}
                           CmdWrite(0xb4);
              CmdWrite(0x13);
              CmdWrite(0x00);
                           for(j=8;j<16;j++) {DataWrite(digit[m*16+j]);}
         else
                  CmdWrite(0xb3);
            CmdWrite(0x13);
            CmdWrite(0x00);
                   for(j=0;j<8;j++) {DataWrite(digit[16+j]);}
                  CmdWrite(0xb4);
            CmdWrite(0x13);
            CmdWrite(0x00);
                   for(j=8;j<16;j++) {DataWrite(digit[16+j]);}
void guangzhu (uchar value)    //显示柱状图
        uchar j;
          CmdWrite(0xb2);
            CmdWrite(0x15);
            CmdWrite(0x02);
            for(j=0;j<(value/3);j++)
               DataWrite(bangtu[j]);
           for(j=(value/3);j<33;j++)
                           DataWrite(0x00);
      CmdWrite(0xb3);
            CmdWrite(0x15);
            CmdWrite(0x02);
            for(j=33;j<33+(value/3);j++)
           for(j=33+(value/3);j<66;j++)
                           DataWrite(0x00);
     CmdWrite(0xb4);
           CmdWrite(0x15);
           CmdWrite(0x02);
           for(j=66;j<66+(value/3);j++)
           for(j=66+(value/3);j<99;j++)
                           DataWrite(0x00);
此帖出自51单片机论坛
252
主函数部分
#include
#include
#include
#include"./INC/foreal.h"
#include"./SRC/FOREAL.c"
         InitialIO();
         Initial_timer0();
         Initial_Serial();
void display ()
        display_WORD(3,1,gong);
                  display_WORD(3,2,lv);
                power=count_up-count_down;
                  display_digit(power);
                guangzhu (power);
void main()
         InitialSystem();
         LCD_Reset();
         NT75451_INIT();
         clear();
         Delay(600);
         EEPROM_read();
         if(count_up-count_down)
         else
         {PCA_PWM0=0x03;}
         PWM_P13(256-(count_up-count_down)*256/100);
         while(1)
           Key1_scan();
           Key2_scan();
           Upkey();
           Downkey();
           display ();
此帖出自51单片机论坛
252
P1.3口实PWM输出口,输出PWM信号给LED驱动,通过按键P1.5和P1.6调节PWM的占空比对LED调光。LCD显示LED的亮度,显示的字符为“功率 50%  光柱”(像手机信号一样的光柱),在整个程序中,我把下按键处理子程序和上按键处理子程序中的EEPROM_program();给屏蔽掉,则LED能正常进行上下调节亮度,但是如果不屏蔽,则在每次调节时LED都会有闪烁,好像有了冲突,不知道为什么,麻烦讲解下,谢谢。
此帖出自51单片机论坛
139
这不叫冲突而是时间占用问题,看4楼的解释。
此帖出自51单片机论坛
535
前面的大侠说的有道理啊!哈哈!自己体会下啊
此帖出自51单片机论坛
252
回复 10楼 chunyang 的帖子
谢谢,chunyang老师,您能帮我再详细分析下吗?我不懂具体应该怎么解决。是精简程序吗,还是怎么办?谢谢。
此帖出自51单片机论坛
7815
56
裸片初长成(中级)
回复 4楼 chunyang 的帖子
可有软件手段回避或者减轻?
此帖出自51单片机论坛
强者为尊,弱者,死无葬身之地
