6234|13
【请教】G2231的DCO能否设置成8M or 16M [复制链接]
在例程中看到
  BCSCTL1 = CALBC1_1MHZ;                    // Set range
  DCOCTL = CALDCO_1MHZ;
可投文件中为何没有
  CALBC1_8MHZ & CALDCO_8MHZ?
还请教如何设置~
[ 本帖最后由 mavericklx 于 2011-10-16 13:13 编辑 ]
很不错 学习了  详情 回复 发表于 2011-11-4 13:47
139
可以,看用户手册,时钟这块。我不在电脑帮边,手机回复
回复 沙发 xylq0826 的帖子
可否 给个例子··?
我看了一下午还是很迷惑
没调出来。。。。
23
G2**1的只有1MHz的DCO频率有校正(在flash A段里面),其他频率得手动校正。
至于如何矫正,可看MSP430x2xx Family User's Guide (SLAU144H page 279)以及SLAS694C 的23页附近的一些说明,设置寄存器即可。多看看手册,很多东西(应该是所有东西)里面都有
158
给个取巧的办法~其他型号的头文件里面有~~~
回复 4楼 TrueElement 的帖子
多谢!!我去找找~~
2144
回复 楼主 mavericklx 的帖子
2144
#include "msp430x20x1.h"
#define DELTA_1MHZ    244                   // 244 x 4096Hz = 999.4Hz
#define DELTA_8MHZ    1953                  // 1953 x 4096Hz = 7.99MHz
#define DELTA_12MHZ   2930                  // 2930 x 4096Hz = 12.00MHz
#define DELTA_16MHZ   3906                  // 3906 x 4096Hz = 15.99MHz
unsigned char CAL_DATA[8];
volatile unsigned int i;
int j;
char *Flash_ptrA;
void Set_DCO(unsigned int Delta);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;
  for (i = 0; i < 0xfffe; i++);
  P1OUT = 0x00;
  P1SEL = 0x10;
  P1DIR = 0x11;
  j = 0;
  Set_DCO(DELTA_16MHZ);
  CAL_DATA[j++] = DCOCTL;
  CAL_DATA[j++] = BCSCTL1;
  Set_DCO(DELTA_12MHZ);
  Set_DCO(DELTA_8MHZ);
  Set_DCO(DELTA_1MHZ);
  Flash_ptrA = (char *)0x10C0;
  FCTL2 = FWKEY + FSSEL0 + FN1;
  FCTL1 = FWKEY + ERASE;
  FCTL3 = FWKEY + LOCKA;
  *Flash_ptrA = 0x00;
  FCTL1 = FWKEY + WRT;
  Flash_ptrA = (char *)0x10F8;
  for (j = 0; j < 8; j++)
    *Flash_ptrA++ = CAL_DATA[j];            // re-flash DCO calibration data
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCKA + LOCK;             // Set LOCK & LOCKA bit
  while (1)
    P1OUT ^= 0x01;
    for (i = 0; i < 0x4000; i++);
  unsigned int Compare, Oldcapture = 0;
  BCSCTL1 |= DIVA_3;
  TACCTL0 = CM_1 + CCIS_1 + CAP;
  TACTL = TASSEL_2 + MC_2 + TACLR;
  while (1)
    while (!(CCIFG & TACCTL0));
    TACCTL0 &= ~CCIFG;
    Compare = TACCR0;
    Compare = Compare - Oldcapture;
    Oldcapture = TACCR0;
    if (Delta == Compare)
      break;
    else if (Delta < Compare)
      DCOCTL--;
      if (DCOCTL == 0xFF)
        if (BCSCTL1 & 0x0f)
          BCSCTL1--;
    else
      DCOCTL++;
      if (DCOCTL == 0x00)
        if ((BCSCTL1 & 0x0f) != 0x0f)
          BCSCTL1++;
  TACCTL0 = 0;
  TACTL = 0;
  BCSCTL1 &= ~DIVA_3;
全部代码。
赞赏
查看全部赞赏
2144
回复 5楼 error_dan 的帖子
这样是不行的  信息段里面没有 怎么能够呢
回复 9楼 lyzhangxiang 的帖子
(⊙o⊙)…
遇到高手了··
可还是不怎么明白,详细询问下
知道答案了定当分享给大家。
回复 8楼 lyzhangxiang 的帖子
采用8楼的手法,运行了自写flash的程序后,修改头文件,8M DCO的 MClok运行成功~
感谢lyzhangxiang !
2002
24
mark
419
你在P2.6、P2.7脚上接个32768的晶振,用8楼的程序跑一下就都校准好了。在你的程序里声明下8MHz的值就可以了啊!
7230
195
很不错 学习了
