开发板是EasyARM8962,仿真器是LM LINK,开发环境是IAR5.11用了一段时间都是没问题的,但忽然出了这个问题: The debugging session could not be started. Either the debugger initialization failed, or else the file “F:\****\BitBand.out” was corrupt or of an unsuported format. There might be more information in the Debug Log Window. Debug Log如下: Wed Oct 12 23:50:56 2011: Loaded macro file: D:\ProgramFiles\IAR Systems\Embedded Workbench 5.0 Kickstart\ARM\config\flashloader\Luminary\FlashLM3Sxxxx64k.mac Wed Oct 12 23:50:57 2011: JTAG Speed is set to: 100 kHz Wed Oct 12 23:50:57 2011: Warning: Identity check failed, target returned unknown AHB-AP ROM/ENTRY: 0xE00FF003/0xFDFF3F3F Wed Oct 12 23:50:57 2011: JTAG IDCODE = 0x3BA00477 Wed Oct 12 23:50:57 2011: AHB-AP ID = 0x14770011 Wed Oct 12 23:50:57 2011: AHB-AP ROM = 0xE00FF003 Wed Oct 12 23:50:57 2011: ROM Component ID = 0xFDFF3F3F Wed Oct 12 23:50:57 2011: Device ID = 0x00000000 () Wed Oct 12 23:51:03 2011: Software reset was performed Wed Oct 12 23:51:03 2011: Initial reset was performed Wed Oct 12 23:51:03 2011: Turning off watchdog Wed Oct 12 23:51:06 2011: 3820 bytes downloaded and verified (1.18 Kbytes/sec) Wed Oct 12 23:51:06 2011: Warning: Verify error at address 0x20000000, target byte: 0xE0, byte in file: 0x80 Wed Oct 12 23:51:06 2011: Warning: Verify error at address 0x20000001, target byte: 0x25, byte in file: 0x01 Wed Oct 12 23:51:06 2011: Warning: Verify error at address 0x20000002, target byte: 0x0B, byte in file: 0x00 Wed Oct 12 23:51:06 2011: Warning:
这种情况是用着用着忽然出现的,之前都是正常的!很郁闷。。。谷歌了一下,没有解决我这个问题的答案。 有没有高人给我指点一下呢?先谢过了!
