2869|0
初学DSP,把例程编译时为什么总出现这样的错误?高手指点一下 [复制链接]
Warning: Cannot write the following file(s), it may affect the build.
  G:\Code-Easy5509\EX01_XF\Debug.lkf
[XF.c] "D:\CCS软件\C5500\cgtools\bin\cl55" -g -q -fr"G:/Code-Easy5509/EX01_XF/Debug" -d"_DEBUG" -ml "XF.c"
>>   error: cannot open G:/Code-Easy5509/EX01_XF/Debug/XF.obj for writing:
            Permission denied
"C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\0194410", INTERNAL ERROR!: no description
                                                               available
This may be a serious problem.  Please contact customer support with a
description of the problem and a sample of the sourcefile that caused this
message to appear.
"C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\0194410", ERROR!  : [E1000] Failed to write
        object file :
