2829|0
LAN89218网路接口电路图 [复制链接]
LAN89218网路接口电路图
LAN89218AQ,LAN89218AQR,LAN89218
LAN89218AQ,LAN89218AQR,LAN89218  High-Performance, Single-Chip 10/100 Ethernet Controller for Automotive Applications
The LAN89218AQ,LAN89218AQR,LAN89218  is a full-featured, single-chip 10/100 Ethernet controller which incorporates essential protocol requirements for operating an Ethernet/IEEE 802.3 10BASE-T and 802.3u100BASE-TX node. It is specifically designed and tested for 16/32-bit automotive grade applications including diagnostic interface, system test interface, and fast software downloads where performance, flexibility, ease of integration and system cost control are required.
Features  LAN89218AQ,LAN89218AQR,LAN89218
  • LAN89218AQ,LAN89218AQR,LAN89218    Designed, fabricated, tested, characterized and qualified for automotive applications
  • LAN89218AQ,LAN89218AQR,LAN89218     TrueAuto™ design, service and support
  • LAN89218AQ,LAN89218AQR,LAN89218    Single-chip Ethernet controller
  • LAN89218AQ,LAN89218AQR,LAN89218    Conforms with IEEE 802.3/802.3u standards
  • LAN89218AQ,LAN89218AQR,LAN89218    Integrated Ethernet MAC and PHY
  • 1LAN89218AQ,LAN89218AQR,LAN89218    0BASE-T/100BASE-TX and HP Auto-MDIX support
  • LAN89218AQ,LAN89218AQR,LAN89218   Supports reduced power modes
  • LAN89218AQ,LAN89218AQR,LAN89218    Reduces dropped packets
  • LAN89218AQ,LAN89218AQR,LAN89218     Flexible address filtering modes
  • LAN89218AQ,LAN89218AQR,LAN89218     Integrated 1.8 V regulator
  • LAN89218AQ,LAN89218AQR,LAN89218     High-performance 32-bit and 16-bit Host Bus Interface (HBI)
  • LAN89218AQ,LAN89218AQR,LAN89218    Optional EEPROM interface
  • LAN89218AQ,LAN89218AQR,LAN89218    Single 3.3 V power supply with 5.0 V tolerant I/O
  • LAN89218AQ,LAN89218AQR,LAN89218    Low profile, 100-pin TQFP, lead-free RoHS-compliant package
  • -40 °C to +85 °C automotive grade temperature support
  • Diagnostic interface for dealership service bay
  • Fast software download interface (e.g. OBD connector)
  • Gateway service interface for dealership, aftermarket, repair shop
  • In-vehicle engineering development interface
  • Vehicle manufacturing test interface for production plant assembly line
evb89218sch-2011.pdf (185.7 KB, 下载次数: 5)
