3790|4
我是初学者,我用LM3s811编的4*4键盘程序哪位好心人帮修改一下,谢谢了 [复制链接]
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_types.h"
#include "gpio.h"
#include "sysctl.h"
#include
#include
unsigned long Sysclk = 12000000UL;
//  防止JTAG失效
void jtagWait(void)
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);          //  使能KEY所在的GPIO端口
GPIOPinTypeGPIOInput(GPIO_PORTC_BASE,GPIO_PIN_4);     //  设置KEY所在管脚为输入
if (GPIOPinRead(GPIO_PORTC_BASE,GPIO_PIN_4) == 0x00)  //  若复位时按下KEY,则进入
       while(1);                             //  死循环,以等待JTAG连接
  SysCtlPeripheralDisable(SYSCTL_PERIPH_GPIOC);   //  禁止KEY所在的GPIO端口
void clockInit(void)
SysCtlLDOSet(SYSCTL_LDO_2_75V);
SysCtlClockSet(SYSCTL_XTAL_6MHZ | SYSCTL_SYSDIV_10 | SYSCTL_USE_PLL  | SYSCTL_OSC_MAIN );
Sysclk=SysCtlClockGet();
int main(void)
jtagWait();
clockInit();
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC |);
//  使能KEY所在的GPIO端口
GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 | GPIO_PIN_4| GPIO_PIN_5 | GPIO_PIN_6|GPIO_PIN_7);
GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE,GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 | GPIO_PIN_4| GPIO_PIN_5 | GPIO_PIN_6|GPIO_PIN_7);
GPIOPinWrite(GPIO_PORTB_BASE,
        (GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 |
        GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6|GPIO_PIN_7), 0xF0);
unsigned char key;
while(1)
  key=kbscan();   //键盘扫描函数
  delay10ms();  //健消除抖动的延时函数
void delay10ms()
  unsigned char i;
for(i=0xff;i>0;i--);
unsigned char kbscan()
unsigned char sccode,recode;
B=0xf0;  //发全“0”行扫描,列线输入
if(B&0xf0)!=0xf0)  //有键按下
    delay10ms();   //延时去抖动
     if((B&0xf0)!=0xf0)
     sccode =0xf0;    //逐行扫描初值
     while((sccodeZ&0x10)!=0)
     B=sccode;     //输出行扫描码
     if((B&0XF0)!=0XF0)  //本行有键按下
      ecode=(B&0xf0)|0xf0;
      return((~sccode)+(~recode);  //返回特征码
      else  sccode=(sccode<<1)|0x01;  //行扫描码左移一位
       return 0;  //无键按下,返回0}
[ 本帖最后由 academic 于 2011-9-18 20:33 编辑 ]
建议楼主把电路图贴上来看看。 应该是行先配置为输出,然后列配置为输出 GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 | GPIO_PIN_4| GPIO_PIN_5 | GPIO_PIN_6|GPIO_PIN_7); GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE,GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 | GPIO_PIN_4| GPIO_PIN_5 | GPIO_PIN_6|GPIO_PIN_7); 这两句啥意思?  详情 回复 发表于 2011-9-19 21:05
2641
没看懂你这个程序和电路,是不是8个脚扫描16个键的?
2751
裸片初长成(初级)
原帖由 荷花 于 2011-9-18 20:14 发表 #include "hw_ints.h" #include "hw_memmap.h" #include "hw_types.h" #include "gpio.h" #include "sysctl.h" #include #include unsigned long Sysclk = 12000000UL; // 防止JTAG失效 void jtagWai ...
程序上看,你用了一个PORTB口来作为4*4键盘行和列,而且都配置成输出。
4*4矩阵键盘接在一个8位的PORT时,应当是4个脚配置成输出模式,用于给出扫描电平。另外四个配置成输入模式,读入引脚电平信号,用于判断按下的按键。
另外,还得注意输出最好配置成带上拉的模式,不要形成悬空。
62
B口的定义没有啊
1412
建议楼主把电路图贴上来看看。
应该是行先配置为输出,然后列配置为输出
这两句啥意思?
个人签名https://bbs.eeworld.com.cn/thread-471646-1-1.html
欢迎加入我的团队
