4413|1
【MSP430共享】来自ourdev的怀表 [复制链接]
在OURDEV看到一个怀表觉得不错特转来。
原文:http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=3734762&bbs_page_no=1&search_mode=1&search_text=怀表&bbs_id=9999
怀表的靖照
怀表的程序
演示代码:
/* LED_Clock_test_1                           */
/* ATmaga48V-10AU @ 1MHz                      */
/* 2009-11-05                                 */
/* h2feo4                                     */
/* www.ourdev.cn                              */
//================= include ==================//
// winavr-20081124
#include <avr/io.h>
#include <avr/interrupt.h>
//================== define ==================//
volatile unsigned char sec = 0, min = 0, hou = 12;
const unsigned char oring[62] = {12, 1, 9, 11, 8, 1, 2, 10, 12, 9, 2, 3, 11, 1, 10, 3, 4, 12, 2, 11, 4, 5, 1, 3, 12, 5, 6, 2, 4, 1, 6, 7, 3, 5, 2, 7, 8, 4, 6, 3, 8, 9, 5, 7, 4, 9, 10, 6, 8, 5, 10, 11, 7, 9, 6, 11, 12, 8, 10, 7, 12, 1};
const unsigned char iring[14] = {7, 8, 9, 10, 11, 12, 1, 2, 3, 4, 5, 6, 7, 8};
//=================== init ===================//
void t0_init(void)
  TCCR0B |= (1 << CS00);
void t1_init(void)
  TCCR1B |= (1 << WGM12) | (1 << CS11) | (1 << CS10);
  TIMSK1 |= (1 << OCIE1A);
  OCR1A = 15624;
void port_init(void)
  PORTB &= 0xc0;
  PORTC &= 0xc0;
  DDRB  &= 0xc0;
  DDRC  &= 0xc0;
//================ interrupt =================//
ISR(TIMER1_COMPA_vect)
  sec++;
  if (sec >= 60)
    sec = 0;
    min++;
  if (min >=60)
    min = 0;
    hou++;
  if (hou >12)
    hou = 1;
//=================== sub ====================//
void disp_sec(void)
  DDRB  &= 0xc0;
  DDRC  &= 0xc0;
  PORTB &= 0xc0;
  PORTC &= 0xc0;
  if (oring[sec] <= 6)
    PORTB |= (1 << (6 - oring[sec]));
    DDRB  |= (1 << (6 - oring[sec]));
  else
    PORTC |= (1 << (12 - oring[sec]));
    DDRC  |= (1 << (12 - oring[sec]));
  if (oring[sec + 1] <= 6)
    DDRB  |= (1 << (6 - oring[sec + 1]));
  else
    DDRC  |= (1 << (12 - oring[sec + 1]));
void disp_min(void)
  DDRB  &= 0xc0;
  DDRC  &= 0xc0;
  PORTB &= 0xc0;
  PORTC &= 0xc0;
  if (oring[min] <= 6)
    DDRB  |= (1 << (6 - oring[min]));
  else
    DDRC  |= (1 << (12 - oring[min]));
  if (oring[min + 1] <= 6)
    PORTB |= (1 << (6 - oring[min + 1]));
    DDRB  |= (1 << (6 - oring[min + 1]));
  else
    PORTC |= (1 << (12 - oring[min + 1]));
    DDRC  |= (1 << (12 - oring[min + 1]));
void disp_hou(void)
  DDRB  &= 0xc0;
  DDRC  &= 0xc0;
  PORTB &= 0xc0;
  PORTC &= 0xc0;
  if (iring[hou] <= 6)
    PORTC |= (1 << (6 - iring[hou]));
    DDRC  |= (1 << (6 - iring[hou]));
    DDRB  |= (1 << (6 - iring[hou]));
  else
    PORTB |= (1 << (12 - iring[hou]));
    DDRC  |= (1 << (12 - iring[hou]));
    DDRB  |= (1 << (12 - iring[hou]));
//=================== main ===================//
void main(void)
  port_init();
  t0_init();
  t1_init();
  sei ();
  while(1)
    disp_sec();
    while(TIFR0 == 0);
    TIFR0 = 0xff;
    disp_min();
    while(TIFR0 == 0);
    TIFR0 = 0xff;
    disp_hou();
    while(TIFR0 == 0);
    TIFR0 = 0xff;
元件清单:
LED(0603封装)132只,包括秒针60只,分针60只,时针12只,推荐分别使用不同颜色。由于LED在焊接时有一定的死亡率,建议采购零件时数量上留出一定的余量
电容(0603封装)2只,包括 VCC-GND 1只,AREF-GND 1只(选装),推荐容量为0.1uF
电阻(0603封装)12只,LED限流电阻,推荐阻值为 100R-330R
ATmega48PA(或其他x8系列的AVR)1只
32.768K晶振 1只(选装);与晶振匹配的电容 2只(选装)[此二零件在PCB上没有位置,故需要飞在外面,可使用预留的IO引出焊盘]
其余例如表盖检测、环境光检测、调整时间等功能在此版本中尚未涉及,须自行设计,可使用预留的IO引出焊盘
PDF版原理图:
点击此处下载  怀表.pdf (63.53 KB, 下载次数: 40)
以上除特别声明外均为 h2feo4 原创
转载必须注明来自 www.ourdev.cn 及原作者 h2feo4 无机酸
所有的文档资料仅可用于学习研究,如果用于商业用途则必须征得本人同意。
[ 本帖最后由 ddllxxrr 于 2011-9-12 07:22 编辑 ]
不错不错  详情 回复 发表于 2011-9-13 09:40
2639
不错不错
【有奖直播】2025是德科技数字月-数字新品来助阵
直播时间:3月19日(周三)14:00
直播奖励:小米口红充电宝、倍思充电线、是德科技十周年鼠标垫
