我这是用单片机普通I/O模拟IIC,向E2PROM中写1个字节的,然后读出来校验,可以就是出错,我不知道是读错误,还是根本没有写进去,下面是我的程序,帮忙看看,谢谢了
#define CSI24WC02 0xA0 /* 定义从要地址,忽略通用地址 */ #define SCL (1<<2) #define SDA (1<<3) #define LED1 (1<<22) void i2c_start(void)//发送开始信号 { IO0SET = SDA; IO0SET = SCL; IO0CLR = SDA; IO0CLR = SCL; return; } //**************************************************************************** void i2c_stop(void)//发送停止信号 { IO0CLR = SDA; IO0SET = SCL; IO0SET = SDA; return; } //**************************************************************************** uint8 i2c_ack(void)//确认信号 { uint8 ack; IO0SET = SDA; IO0SET = SCL; if(SDA==1) ack = 1; else ack = 0; IO0CLR = SCL; return (ack); } //**************************************************************************** void i2c_send8bit(uint8 b) { uint8 a; for(a=0;a<8;a++) { if (b&0x80==1) IO0SET = SDA; else IO0CLR = SDA; IO0SET = SCL; IO0CLR = SCL; } return; } //**************************************************************************** uint8 i2c_receive8bit(void) { uint8 a; uint8 b=0; for(a=0;a<8;a++) { IO0SET = SCL; b=b<<1; if(SDA==1) b=b|0x01; //按位或 IO0CLR = SCL; } return(b); } //**************************************************************************** //i2c_write(地址,数据),写一个字节 void i2c_write(uint8 Address,uint8 Data) { i2c_start(); i2c_send8bit(CSI24WC02); do{ i2c_send8bit(Address); }while(i2c_ack()); do{ i2c_send8bit(Data); }while(i2c_ack()); i2c_stop(); return; } //**************************************************************************** //i2c_read(地址,数据),写一个字节 uint8 i2c_read(uint8 Address) { uint8 c; i2c_start(); i2c_send8bit(CSI24WC02); do{ i2c_send8bit(Address); }while(i2c_ack()); do{ i2c_start(); i2c_send8bit(0xA1); }while(i2c_ack()); do{ c=i2c_receive8bit(); }while(i2c_ack()); i2c_stop(); return(c); int main(void) { uint8 dd; PINSEL0 = 0x00000000; // 设置I2C口连接 PINSEL1 = 0x00000000; i2c_write(0x02,0x06); DelayNS(5); dd=i2c_read(0x02); for(;;) {} return(0); }
