如图所示,在verilog语句中用什么语句来吧几个模块连接起来呢?组装成一个整体大的模块,该大模块包含这些小模块。
就是类似于vhdl中的元件声明语句,最后在组装成一个整体大的模块。vhdl语句如下:
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY DDS IS PORT(K:IN STD_LOGIC_VECTOR(9 DOWNTO 0); EN:IN STD_LOGIC; RESET:IN STD_LOGIC; CLK:IN STD_LOGIC; Q:OUT STD_LOGIC_VECTOR(8 DOWNTO 0)); END ENTITY DDS; ARCHITECTURE ART OF DDS IS COMPONENT SUM99 IS PORT(K:IN STD_LOGIC_VECTOR(9 DOWNTO 0); EN:IN STD_LOGIC; RESET:IN STD_LOGIC; CLK:IN STD_LOGIC; OUT1:OUT STD_LOGIC_VECTOR(9 DOWNTO 0)); END COMPONENT SUM99; COMPONENT REG1 IS PORT(D:IN STD_LOGIC_VECTOR(9 DOWNTO 0); CLK:IN STD_LOGIC; Q:OUT STD_LOGIC_VECTOR(9 DOWNTO 0)); END COMPONENT REG1; COMPONENT ROM IS PORT(CLK:IN STD_LOGIC; ADDR:IN STD_LOGIC_VECTOR(9 DOWNTO 0); OUTP:OUT STD_LOGIC_VECTOR(8 DOWNTO 0)); END COMPONENT ROM; COMPONENT REG2 IS PORT(D:IN STD_LOGIC_VECTOR(8 DOWNTO 0); CLK:IN STD_LOGIC; Q:OUT STD_LOGIC_VECTOR(8 DOWNTO 0)); END COMPONENT REG2; SIGNAL S1:STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL S2:STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL S3:STD_LOGIC_VECTOR(8 DOWNTO 0); BEGIN U0:SUM99 PORT MAP(K=>K,EN=>EN,RESET=>RESET,CLK=>CLK,OUT1=>S1); U1:REG1 PORT MAP(D=>S1,CLK=>CLK,Q=>S2); U2:ROM PORT MAP(ADDR=>S2,CLK=>CLK,OUTP=>S3); U3:REG2 PORT MAP(D=>S3,CLK=>CLK,Q=>Q); END ARCHITECTURE ART;
