#include
#define unt unsigned int
void Delay(void);
int KeyProcess(void);
void Init_Port(void);
void Init_CLK(void);
int KeyScan(void);
void delay1(unt);
void main(void)
int t,i;
int ch[8] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
Init_Port();
t=KeyScan();
i=t;
P5DIR=0xFF;
P5OUT&=0x00;
while(i<8)
P5OUT=ch;
delay1(6000);
i++;
//将P1P6口所有的管脚在初始化的时候设置为输入方式
P1DIR = 0x00;
P6DIR = 0x00;
//将P1P6口所有的管脚设置为一般I/O口
P1SEL = 0x00;
P6SEL = 0x00;
// 将P6.4 P6.5 P6.6 P6.7设置为输出方向
P6DIR |= BIT7;
P6DIR |= BIT6;
P6DIR |= BIT5;
P6DIR |= BIT4;
//先输出低电平
P1OUT = 0x00;
P6OUT = 0X00;
return;
int KeyScan(void)
int nP10,nP11,nP12,nP13;
int nRes = 0;
for(;;)
//读取各个管脚的状态,左移几位,比较当前为的值,判断是否为零
nP10 = P1IN & BIT0;
nP11 = (P1IN & BIT1) >> 1;
nP12 = (P1IN & BIT2) >> 2;
nP13 = (P1IN & BIT3) >> 3;
//是否有键被按下
if(nP10 == 0 || nP11 == 0 || nP12 == 0 || nP13 == 0)
//有键被按下
break;
Delay(); //延时一点时间,消除抖动
//读取各个管脚的状态
nP10 = P1IN & BIT0;
//是否有键被按下
//有键被按下,进行键盘输入分析
nRes = KeyProcess();
else return -1;//没有输入,为干扰
return nRes;
void Delay(void)
int i;
for(i = 100;i > 0;i--) ;//延时一点时间
void delay1(unt z)
unt a;
for(a=0;a
int nRes = 0x00;
int nP10;
int nP11;
int nP12;
int nP13;
//P6.7输出低电平
P6OUT =0x7f;
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 0;
if (nP11 == 0) nRes = 4;
if (nP12 == 0) nRes = 0;
if (nP13 == 0) nRes = 4;
//P6.6输出低电平
P6OUT =0xbf;
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes =1;
if (nP11 == 0) nRes =5;
if (nP12 == 0) nRes = 1;
if (nP13 == 0) nRes = 5;
//P6.5输出低电平
P6OUT =0xdf;
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes =2;
if (nP11 == 0) nRes = 6;
if (nP12 == 0) nRes = 2;
if (nP13 == 0) nRes = 6;
//P6.4输出低电平
P6OUT=0xef;
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 3;
if (nP11 == 0) nRes = 7;
if (nP12 == 0) nRes = 3;
if (nP13 == 0) nRes = 7;
P1OUT = 0x00;
P6OUT = 0X00;//恢复以前值。
//读取各个管脚的状态
nP10 = P1IN & BIT0;
for(;;)
nP10 = P1IN & BIT0;
if(nP10 == 1 && nP11 == 1 && nP12 == 1 && nP13 == 1)
//等待松开按键
break;
return nRes;
void Init_CLK(void)
unsigned int i;
BCSCTL1 = 0X00; //将寄存器的内容清零
//XT2震荡器开启
//LFTX1工作在低频模式
//ACLK的分频因子为1
do
IFG1 &= ~OFIFG; // 清除OSCFault标志
for (i = 0x20; i > 0; i--);
while ((IFG1 & OFIFG) == OFIFG); // 如果OSCFault =1
BCSCTL2 = 0X00; //将寄存器的内容清零
BCSCTL2 += SELM1; //MCLK的时钟源为TX2CLK,分频因子为1
BCSCTL2 += SELS; //SMCLK的时钟源为TX2CLK,分频因子为1
运行的时候主函数的delay老是跑到int KeyScan(void)中去,这是为什么????
