if ((RecivePcBuf[0]=='l')&&(RecivePcBuf[1]=='s'))
//tcp_write(pcb,RecivePcBuf,strlen(RecivePcBuf),0);
fresult = f_opendir(&g_sDirObject, g_cCwdBuf);
// Check for error and return if there is a problem.
if(fresult != FR_OK)
UARTprintf("openirfail!");
return(fresult);
for(;;)
// Read an entry from the directory.
fresult = f_readdir(&g_sDirObject, &g_sFileInfo);
UARTprintf("readdirfail!");
return(fresult);
// If the file name is blank, then this is the end of the
// listing.
if(!g_sFileInfo.fname[0])
UARTprintf("blankname!");
break;
// If the attribue is directory, then increment the directory count.
if(g_sFileInfo.fattrib & AM_DIR)
strcat(SendPc,"D---- ");
else
if (g_sFileInfo.fattrib & AM_ARC)
strcat(SendPc,"----A ");
strcat(SendPc,g_sFileInfo.fname);
strcat(SendPc,"\r\n");
FROK=tcp_write(pcb,SendPc,strlen(SendPc),0);
if (FROK!=ERR_OK)
UARTprintf("lstcpfail");
return 0;
FROK=tcp_output(pcb);
if (FROK!=ERR_OK)
return 0;
// Copy the current path to the temporary buffer so it can be manipulated.
// strcpy(g_cTmpBuf, g_cCwdBuf);
// If not already at the root level, then append a separator.
// if(strcmp("/", g_cCwdBuf))
// strcat(g_cTmpBuf, "/");
strcpy(g_cTmpBuf,"/");
// strcat(g_cTmpBuf,"/");
strcat(g_cTmpBuf, File_Name);
strcat(g_cTmpBuf, ".txt");
// Now finally, append the file name to result in a fully specified file.
// Open the file for reading.
fresult = f_open(&g_sFileObject, g_cTmpBuf, FA_READ);
// If there was some problem opening the file, then return
// an error.
UARTprintf("fileopenfail!");
FROK=tcp_write(pcb,i,strlen(i),0);
if (FROK!=ERR_OK)
return 0;
if (FROK!=ERR_OK)
return 0;
return(fresult);
//f_lseek(&g_sFileObject,0);
// Enter a loop to repeatedly read data from the file and display it,
// until the end of the file is reached.
do
// Read a block of data from the file. Read as much as can fit
// in the temporary buffer, including a space for the trailing null.
// If there was an error reading, then print a newline and
// return the error to the user.
UARTprintf("filereadfail");
FROK=tcp_write(pcb,"fail to read!\r\n",strlen("fail to read!\r\n"),0);
if (FROK!=ERR_OK)
return 0;
if (FROK!=ERR_OK)
return 0;
return(fresult);
// Null terminate the last block that was read to make it a
// null terminated string that can be used with printf.
temp_data[usBytesRead] = 0;
FROK=tcp_write(pcb,temp_data,strlen(temp_data),0);
if (FROK!=ERR_OK)
UARTprintf("cattcpfail!");
return 0;
if (FROK!=ERR_OK)
return 0;
// Continue reading until less than the full number of bytes are
// read. That means the end of the buffer was reached.
