2625|0
下载问题 [复制链接]
stm32f103vct     程序用j-flash下到板上怎么都跑不起来??比如IO口实验:程序如下,pa.1还是低电平?为什么?用的是最小板...
                            LED灯闪烁实验
 实验现象: 每隔一段时间闪烁
#include "stm32f10x_lib.h"
/******************************** 变量定义 ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
ErrorStatus HSEStartUpStatus;
/*********************************声明函数 -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
                                  主函数
int main(void)
#ifdef DEBUG
  debug();
#endif
  RCC_Configuration(); //系统时钟配置函数
  NVIC_Configuration();  //NVIC配置函数
  //使能APB2总线外设时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;  // 选择所有脚
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //配置成推挽式输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //输出模式下 I/O输出速度 50M HZ
  GPIO_Init(GPIOA, &GPIO_InitStructure);  //初始化PA口
  while (1)
   GPIO_SetBits(GPIOA, GPIO_Pin_1);
 Delay(0x8FFFFF); // 延时
 GPIO_ResetBits(GPIOA, GPIO_Pin_1);
*                           配置RCC
 //复位RCC外部设备寄存器到默认值
  RCC_DeInit();
  //打开外部高速晶振
  RCC_HSEConfig(RCC_HSE_ON);
   //等待外部高速时钟准备好
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)   //外部高速时钟已经准别好
    //开启FLASH的预取功能
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    //FLASH延迟2个周期
    FLASH_SetLatency(FLASH_Latency_2);
  //配置AHB(HCLK)时钟=SYSCLK
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
   //配置APB2(PCLK2)钟=AHB时钟
    RCC_PCLK2Config(RCC_HCLK_Div1);
    //配置APB1(PCLK1)钟=AHB 1/2时钟
    RCC_PCLK1Config(RCC_HCLK_Div2);
     //配置PLL时钟 == 外部高速晶体时钟*9  PLLCLK = 8MHz * 9 = 72 MHz
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    //使能PLL时钟
    RCC_PLLCmd(ENABLE);
   //等待PLL时钟就绪
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  //配置系统时钟 = PLL时钟
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
   //检查PLL时钟是否作为系统时钟
    while(RCC_GetSYSCLKSource() != 0x08)
*                             NVIC配置函数
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
*                              延时函数
  for(; nCount != 0; nCount--);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
此帖出自stm32/stm8论坛
