4559|2
Quartues 2 仿真teshbench竟然出现了问题 [复制链接]
在QUARYUS2 ->TOOL->RUN EDA SIMULATION TOOL 后 运行ModelSim 6.5出现如下报错。希望高手指教。Q385157936
For example, ModelSim may display the following error message:
# ** Error: (vsim-19) Failed to access library 'work' at "work".
这个问题在网上收了下, 按照官网的说法如下:
To find the cause of and resolution to this error, use the following verror command at the ModelSim command prompt:
verror 19;
ModelSim returns the following message:
# common Message # 19:
# The specified library could not be accessed at the specified location.
# Verify that the directory exists, that it contains the ModelSim library,
# and that you have the correct permissions for accessing it.
# Also make sure that the _info file in the library has the correct
# access permissions.
# This message might be followed by another message that gives more information
# about the problem.
# The vlib command creates ModelSim libraries. The vmap command maps
# logical library names to physical library locations. Use the vmap
# command without arguments to find out how all of your libraries are
# mapped.
# One way this problem can occur is if the mapping for the library in
# your modelsim.ini file contains an environment variable that is not set
# in your environment.
还是不懂如何解决。
此帖出自FPGA/CPLD论坛
顶起!这是一个时间换来的经验教训。  详情 回复 发表于 2011-7-28 09:04
安装路径千万别有中文和空格,允许小数点
已经解决问题,大家注意,安装QUARTUS10.0版本后,路径千万不要带空格和中文!避免出现一些意外。
此帖出自FPGA/CPLD论坛
赞赏
查看全部赞赏
6892
顶起!这是一个时间换来的经验教训。
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
