4300|0
PIC单片机中C30编译器中函数中用数组调用常数字符串问题 [复制链接]
关于PIC单片机不能用数组来调用字符串的问题:
函数原型
void Print_5X8(unsigned int y,unsigned int x, unsigned char ch[],unsigned int yn)
  unsigned char wm ,ii = 0;
  unsigned int adder;
  while(ch[ii] != '\0')
    adder = (ch[ii] - 0x20) * 5;
    Set_Ram_Addr(y , x);
    for(wm = 0;wm < 5;wm++)
      if(yn == 0)
        WriteData(~Asc5X8[adder]);
      else
        WriteData(Asc5X8[adder]);
      adder += 1;
    ii += 1;
    x += 5;
调用形式:
Print_5X8(0,10,"FTTx",1);
编译错误;pointer targets in passing argument 3 of 'Print_5X8' differ in signedness
恳请各路大神求助啊,我在c8051f060、以及MSP5419单片机的开发环境中都可以这样调用,在C30编译器就不行~
