3311|0
proteus+tlc1543仿真不能显示 [复制链接]
#include "reg51.h"
#include "intrins.h"
#define uchar unsigned char
#define uint unsigned int
uchar code dispcode[]={0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f,0x40,0x48};
uchar code dispwei[]={0xe0,0xd0,0xb0,0x70};
sbit EOC=P1^4;
sbit CLK=P1^5;
sbit ADDR=P1^6;
sbit CS=P1^7;
sbit SD0=P3^3;
void delay(uint m)
{while(m--);
void display(uchar shi,uchar ge)
{ uchar i;
  for(i=0;i<2;i++)
    P2=0xff;
    P0=dispcode[shi]|0x80;
    P2=0xfe;
    delay(10);
    P2=0xff;
    P0=dispcode[ge];
    P2=0xfd;
    delay(10);
float read1543(uchar port)
  float ad;
  uint adl,i;
  uchar al=0;uchar ah=0;
  CS=1;
  CLK=0;
  CS=0;
  port<<=4;
  for(i=0;i<4;i++)
      ADDR=(bit)(port&0x80);
  CLK=1;
      delay(10);
      CLK=0;
       port<<=1;
   for(i=0;i<6;i++)
    CLK=1;
    CLK=0;
  CS=1;
 _nop_();_nop_(); _nop_();_nop_(); _nop_();_nop_();
 _nop_();_nop_(); _nop_();_nop_(); _nop_();_nop_(); _nop_();_nop_();
 CS=0;
for(i=0;i<2;i++)
{ SD0=1;
  CLK=1;
  ah<<=1;
  if(SD0) al|=0x01;
  CLK=0;
for(i=0;i<8;i++)
{ SD0=1;
  CLK=1;
  ah<<=1;
  if(SD0) al|=0x01;
  CLK=0;
 CS=1;
 adl=ah;
 adl<<=8;
 adl|=al;
ad=(float)((float)5*adl/(float)1024);
return(ad);
void main(void)
{ float i;
uchar r,k,e;
  while(1)
{ i=read1543(0);
k=i*10;
   e=k/10;
  r=k%10;
  display(e,r);
此帖出自单片机论坛
