程序利用上升沿捕获功能,在1ms内记录捕捉到的脉冲个数,并通过串口助手显示: /****************************************************************************** 频率采集:时基为1ms,采用Timer0捕捉比较,记录时基内捕捉到的上升沿个数 P1.2-->Timer0_CCI1A 捕获输入 ******************************************************************************/ #include"msp430x21x2.h" volatile unsigned long int fCounter; volatile char tCounter,mark=0; unsigned char pcString []="当前频率:"; #define delay10us _NOP(),_NOP(),_NOP(),_NOP(),_NOP()
void Usart_PutChar(unsigned char cTXData) //字节发送函数 { while (!(IFG2&UCA0TXIFG)); UCA0TXBUF = cTXData; // TX -> RXed character }
void Usart_PutString(unsigned char *pcString) { while (*pcString) { Usart_PutChar(*pcString++); } //Usart_PutChar(0x0D); //Usart_PutChar(0x0A); //结尾发送回车换行 }
void main() { WDTCTL =WDTPW +WDTHOLD;//Stop Watch dog if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF) { while(1); // If calibration constants erased do not load, trap CPU!! } BCSCTL1 =CALBC1_1MHZ; //设定DCO为1MHZ DCOCTL = CALDCO_1MHZ; //设定DCO 为1MHZ
unsigned int counter; P1DIR |=BIT0; P1SEL |=BIT2; P1DIR &=~BIT2;//Timer0_A3, capture: CCI1A input P1SEL2 &=~BIT2;
P3SEL= BIT5+BIT4;
TAR =0XFC18; //初装值65536-64536=1000us TACCTL1 =CAP; TACCTL1|=CM_1+CCIS_0+SCS+CCIE; //上升沿捕获,CCI0A输入,同步捕获,捕获中断使能 TACTL =TASSEL_2+TAIE+MC_0;//定时器时钟源SMCLK,连续模式,
UCA0CTL1 |= UCSWRST; UCA0CTL1 |=UCSSEL_2; //SMCLK UCA0BR0 = 104; //9600波特率 UCA0BR1 = 0; UCA0MCTL =UCBRS_1; UCA0CTL1 &=~UCSWRST; IE2 |=UCA0RXIE; //接收中断使能*/
__bis_SR_register(GIE); TACTL |=MC_2; //开启定时器 while(1) { while(mark==0); mark=0; counter=fCounter/1000; fCounter=0; //if(counter>1) // { Usart_PutString(pcString); Usart_PutChar(counter/1000+0x30); Usart_PutChar(counter%1000/100+0x30); Usart_PutChar(counter%1000%100/10+0x30); Usart_PutChar(counter%1000%100%10+0x30); Usart_PutString("KHZ"); Usart_PutChar(0x0D); Usart_PutChar(0x0A); //结尾发送回车换行 // } counter=0; for(int i=0;i<1000;i++) for(int k=0;k<100;k++) delay10us; // __bis_SR_register(GIE); TACTL |=MC_2; //再开定时器
#pragma vector=TIMER0_A1_VECTOR __interrupt void Timer0_A1(void) { switch (__even_in_range(TA0IV, 10)) // Efficient switch-implementation { case 2: fCounter++; //捕获计数 TACCTL1 &=~CCIFG; //P1OUT^=BIT0; break; // TA0CCR1 used case 4:
break; // TA0CCR2 not used case 10:
TACTL &=~MC_2;//Stop timer0 P1OUT^=BIT0; //LED指示 TAR =0xFC18;//重装计数值 mark=1; //1ms定时到标记 break; } }
问题:1、1ms溢出中断中停止计数器一句TACTL &=~MC_2;加上后为什么我的1ms定时成为1s了? 2、测量误差很大,20K以内还好,频率越高则也大,有何改良方法? 串口显示无问题。
