我设计的无限温度传感网络由一个路由设备和两个温度测量节点组成。两个测温节点的程序应该是一样的吧?我是通过长地址(IEEE地址)来在路由设备上区分两个节点的数据的,部分原代码如下: unsigned int current_temperature1 = 0; unsigned int current_temperature2 = 0; unsigned char get_long_addr[8]; unsigned char get_dat[2]; unsigned char Is_node1 = 0; float f_temper = 0; static void LocDongle_ProcessMSGCmd( afIncomingMSGPacket_t *pkt ) { UART_SendMsg.start_frame = 0xff; UART_SendMsg.cmd = (uint8)(pkt->clusterId); get_dat[0] = *(pkt->cmd.Data++); get_dat[1] = *(pkt->cmd.Data++);
// osal_memcpy (UART_SendMsg.dat, pkt->cmd.Data, 10); osal_memcpy (get_long_addr, pkt->cmd.Data, 8);
if(get_long_addr[0] == 0xff && get_long_addr[1] == 0xff && get_long_addr[2] == 0xff && get_long_addr[3] == 0xff && get_long_addr[4] == 0xff && get_long_addr[5] == 0xff && get_long_addr[6] == 0xff && get_long_addr[7] == 0x00) Is_node1 = 1; else Is_node1 = 0;
if(UART_SendMsg.cmd == TAS_READ_TEMPERATURE) { if(Is_node1) { current_temperature1 = get_dat[1]; current_temperature1 = current_temperature1 << 8; current_temperature1 += get_dat[0]; if(current_temperature1 > 0x0800)//负数 { current_temperature1 = 0xfff - current_temperature1 +1; Print8(HAL_LCD_LINE_2,50,"-",1); } else Print8(HAL_LCD_LINE_2,50,"+",1); f_temper =current_temperature1 * 0.0625; current_temperature1 = f_temper; Printn8(HAL_LCD_LINE_2,60,current_temperature1,1,4); Print16(HAL_LCD_LINE_2,95,"℃",1); } else { current_temperature2 = UART_SendMsg.dat[1];
current_temperature2 = current_temperature2 << 8; current_temperature2 += UART_SendMsg.dat[0]; if(current_temperature2 > 0x0800)//负数 { current_temperature2 = 0xfff - current_temperature2 +1; Print8(HAL_LCD_LINE_2,50,"-",1); } else Print8(HAL_LCD_LINE_3,50,"+",1); f_temper =current_temperature2 * 0.0625; current_temperature2 = f_temper; Printn8(HAL_LCD_LINE_3,60,current_temperature2,1,4); Print16(HAL_LCD_LINE_3,95,"℃",1); }
程序中 if(get_long_addr[0] == 0xff && get_long_addr[1] == 0xff && get_long_addr[2] == 0xff && get_long_addr[3] == 0xff && get_long_addr[4] == 0xff && get_long_addr[5] == 0xff && get_long_addr[6] == 0xff && get_long_addr[7] == 0x00 ) 是判断数据包来自哪个节点,判断条件中的地址是第一个节点的IEEE地址,另一个差不多,只是get_long_addr[7] == 0x01,。两个节点的程序是一样的。但是运行时,就只有get_long_addr[7] == 0x00,也就是第一个节点的温度能正常显示在路由设备的液晶屏上,为“+0027℃”(也能随环境温度而变化),另一个则总是显示“+0000℃”。而如果我把上面那个判断地址的if语句的条件改成 if(get_long_addr[0] == 0xff && get_long_addr[1] == 0xff && get_long_addr[2] == 0xff && get_long_addr[3] == 0xff && get_long_addr[4] == 0xff && get_long_addr[5] == 0xff && get_long_addr[6] == 0xff && get_long_addr[7] == 0x01 ) 就变成第二个节点的温度正常显示,第一个节点总是显示“+0000℃”了! 请大家帮帮忙,看看问题在哪儿。要要是觉得我描述的不够清楚,麻烦回帖指出。谢谢!
