4056|7
4152关闭看门狗运行一段时间后为啥还会复位呢 [复制链接]
到底是啥原因啊  详情 回复 发表于 2014-8-7 14:38
楼主能否将全部代码贴上来看看,采用while了吗?堆栈溢出是有可能复位的。
77
我用到了while循环,目前方便起见,我把while部分的代码贴出来了
增加有色字体部分会出现不定时复位的现象
while(1)
flag = 0;
if((key1click == 1)&&(IsKey1Click == false))
delay_NOP(1000);
if ((P1IN&BIT0) == 0)
IsKey1Click = true;
key1click = 0;
gLongKeyTimer = 0;
if(IsKey1Click == true)
if (gLongKeyTimer > 3)
IsKey1Click = false;
ucCurKeyValue = 0;
keyvalue=0x60;
else if ((P1IN&BIT0) != 0)
keyvalue=0x51;
switch(SCREENSTATE)
case 0:
DisplayMeterAddr();
switch(keyvalue)
case 0x51:
SCREENSTATE=1;
break;
case 0x54:
break;
default:
break;
break;
case 1:
DisplayInsFlow(0);
switch(keyvalue)
case 0x51:
SCREENSTATE=2;
break;
case 0x60:
gFlag_StartSetZero=true;
SCREENSTATE=250;
break;
default:
break;
break;
case 2:
DisplayCumFlow2();
switch(keyvalue)
case 0x51:
SCREENSTATE=3;
break;
default:
break;
break;
case 3:
DisplayTemp(0);
switch(keyvalue)
case 0x51:
SCREENSTATE=4;
break;
default:
break;
break;
case 4:
DisplayTemp(1);
switch(keyvalue)
case 0x51:
SCREENSTATE=5;
break;
default:
break;
break;
case 5:
DisplayTemp(2);
switch(keyvalue)
case 0x51:
SCREENSTATE=6;
break;
default:
break;
break;
case 6:
DisplaySysTime(0);
switch(keyvalue)
case 0x51:
SCREENSTATE=7;
break;
default:
break;
break;
case 7:
DisplaySysTime(1);
switch(keyvalue)
case 0x51:
SCREENSTATE=0;
break;
default:
break;
break;
case 101:
break;
case 250:
DisplayCalib();
switch(keyvalue)
case 0x51:
SCREENSTATE=1;
break;
default:
break;
break;
default:
break;
keyvalue=0;
CurTimer_1s = Timer_1s;
CurTimer_500ms = Timer_500ms;
if(Timer_1s%5==0)
testtempfunc();
GP2_init();
fire_flag=0;
timer500ms_flag=0;
VCC_OFF;
VCA_OFF;
VCB_OFF;
flag =MeasDeltaTime(&lTOF,IsFirstDownFlow);
#if CALCULATETIME
if (flag == RET_OK)
if (CaculateDeltaTime(lTOF,&SampleBufLen) != 1)
counter_overflow++;
else
counter_overflow = 0;
CalibAndCorrect();
#if 0
gInsFlow = (float)glCurSampleData*23120.57; gInsFlow /=ulTOF_counterflow0 ; gInsFlow *=224 ; gInsFlow /=ulTOF_downflow0 ; gInsFlow*=3600 ;
if (CurTimer_500ms != oldCacuTimer_500ms) {
if (CurTimer_500ms > oldCacuTimer_500ms)
t = 0.5 * (CurTimer_500ms - oldCacuTimer_500ms);
else
t = 0.5 * (CurTimer_500ms + 120 - oldCacuTimer_500ms);
oldCacuTimer_500ms = CurTimer_500ms;
fmid = gInsFlow*t;
fmid *=277.7778;
glCumFlow +=fmid;
#endif
gSensorFault = false;
else if (flag != 0)
if (counter_overflow > 10)
gSensorFault = true;
if (flag == TDC_FAULT)
GP2_init();
delay_NOP(1000); //10ms
else
counter_overflow++;
#endif
81
4152有堆栈溢出自动复位机制啊!
65
问下是否堆栈溢出 会自动复位啊
堆栈溢出了,那中断返回,或者调用子函数返回后的PC就可能出错,不知道飞哪里去了呢
78
仿真时查看程序运行到哪里复位。
21
到底是啥原因啊
个人签名高温热感染人人人共同
