4479|5
79
#####哪位大侠有SHT11(瑞士盛世瑞恩温湿度传感器)的MSP430程序呢???#### [复制链接]
最近找这个找疯了,求求哪位大侠帮个忙!
小弟邮箱:zhanliang198109@126.com
先谢谢了!
有51的源码 改改就可以的  详情 回复 发表于 2008-5-25 18:15
拿C51的改吧!
Project: SHTxx demo program (V2.1)
Filename: SHTxx_Sample_Code.c
Prozessor: 80C51 family
Compiler: Keil Version 6.14
Autor: MST
Copyrigth: (c) Sensirion AG
#include <AT89s53.h> //Microcontroller specific library, e.g. port definitions
#include <intrins.h> //Keil library (is used for _nop()_ operation)
#include <math.h> //Keil library
#include <stdio.h> //Keil library
typedef union
{ unsigned int i;
float f;
} value;
// modul-var
enum {TEMP,HUMI};
#define DATA P1_1
#define SCK P1_0
#define noACK 0
#define ACK 1
//adr command r/w
#define STATUS_REG_W 0x06 //000 0011 0
#define STATUS_REG_R 0x07 //000 0011 1
#define MEASURE_TEMP 0x03 //000 0001 1
#define MEASURE_HUMI 0x05 //000 0010 1
#define RESET 0x1e //000 1111 0
char s_write_byte(unsigned char value)
// writes a byte on the Sensibus and checks the acknowledge
unsigned char i,error=0;
for (i=0x80;i>0;i/=2) //shift bit for masking
{ if (i & value) DATA=1; //masking value with i , write to SENSI-BUS
else DATA=0;
SCK=1; //clk for SENSI-BUS
_nop_();_nop_();_nop_(); //pulswith approx. 5 us
SCK=0;
DATA=1; //release DATA-line
SCK=1; //clk #9 for ack
error=DATA; //check ack (DATA will be pulled down by SHT11)
SCK=0;
return error; //error=1 in case of no acknowledge
char s_read_byte(unsigned char ack)
// reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
unsigned char i,val=0;
{ SCK=1; //clk for SENSI-BUS
if (DATA) val=(val | i); //read bit
SCK=0;
DATA=!ack; //in case of "ack==1" pull down DATA-Line
SCK=0;
return val;
void s_transstart(void)
// generates a transmission start
// _____ ________
// DATA: |_______|
// ___ ___
// SCK : ___| |___| |______
DATA=1; SCK=0; //Initial state
_nop_();
SCK=1;
_nop_();
DATA=0;
_nop_();
SCK=0;
SCK=1;
_nop_();
DATA=1;
_nop_();
SCK=0;
void s_connectionreset(void)
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
// _____________________________________________________ ________
// DATA: |_______|
// _ _ _ _ _ _ _ _ _ ___ ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
unsigned char i;
for(i=0;i<9;i++) //9 SCK cycles
{ SCK=1;
SCK=0;
s_transstart(); //transmission start
char s_softreset(void)
// resets the sensor by a softreset
unsigned char error=0;
s_connectionreset(); //reset communication
error+=s_write_byte(RESET); //send RESET-command to sensor
return error; //error=1 in case of no response form the sensor
char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
// reads the status register with checksum (8-bit)
error=s_write_byte(STATUS_REG_R); //send command to sensor
*p_value=s_read_byte(ACK); //read status register (8-bit)
*p_checksum=s_read_byte(noACK); //read checksum (8-bit)
84
char s_write_statusreg(unsigned char *p_value)
// writes the status register with checksum (8-bit)
error+=s_write_byte(STATUS_REG_W);//send command to sensor
error+=s_write_byte(*p_value); //send value of status register
return error; //error>=1 in case of no response form the sensor
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
// makes a measurement (humidity/temperature) with checksum
unsigned error=0;
unsigned int i;
switch(mode){ //send command to sensor
case TEMP : error+=s_write_byte(MEASURE_TEMP); break;
case HUMI : error+=s_write_byte(MEASURE_HUMI); break;
default : break;
for (i=0;i<65535;i++) if(DATA==0) break; //wait until sensor has finished the measurement
if(DATA) error+=1; // or timeout (~2 sec.) is reached
*(p_value) =s_read_byte(ACK); //read the first byte (MSB)
*(p_value+1)=s_read_byte(ACK); //read the second byte (LSB)
*p_checksum =s_read_byte(noACK); //read checksum
return error;
void init_uart()
//9600 bps @ 11.059 MHz
{SCON = 0x52;
TMOD = 0x20;
TCON = 0x69;
TH1 = 0xfd;
void calc_sth11(float *p_humidity ,float *p_temperature)
// calculates temperature [癈] and humidity [%RH]
// input : humi [Ticks] (12 bit)
// temp [Ticks] (14 bit)
// output: humi [%RH]
// temp [癈]
{ const float C1=-4.0; // for 12 Bit
const float C2=+0.0405; // for 12 Bit
const float C3=-0.0000028; // for 12 Bit
const float T1=+0.01; // for 14 Bit @ 5V
const float T2=+0.00008; // for 14 Bit @ 5V
float rh=*p_humidity; // rh: Humidity [Ticks] 12 Bit
float t=*p_temperature; // t: Temperature [Ticks] 14 Bit
float rh_lin; // rh_lin: Humidity linear
float rh_true; // rh_true: Temperature compensated humidity
float t_C; // t_C : Temperature [癈]
t_C=t*0.01 - 40; //calc. temperature from ticks to [癈]
rh_lin=C3*rh*rh + C2*rh + C1; //calc. humidity from ticks to [%RH]
rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //calc. temperature compensated humidity [%RH]
if(rh_true>100)rh_true=100; //cut if the value is outside of
if(rh_true<0.1)rh_true=0.1; //the physical possi××e range
*p_temperature=t_C; //return temperature [癈]
*p_humidity=rh_true; //return humidity[%RH]
float calc_dewpoint(float h,float t)
// calculates dew point
// input: humidity [%RH], temperature [癈]
// output: dew point [癈]
{ float logEx,dew_point;
logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);
dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
return dew_point;
void main()
// sample program that shows how to use SHT11 functions
// 1. connection reset
// 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
// 3. calculate humidity [%RH] and temperature [癈]
// 4. calculate dew point [癈]
// 5. print temperature, humidity, dew point
{ value humi_val,temp_val;
float dew_point;
unsigned char error,checksum;
unsigned int i;
init_uart();
while(1)
{ error=0;
error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI); //measure humidity
error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP); //measure temperature
if(error!=0) s_connectionreset(); //in case of an error: connection reset
else
{ humi_val.f=(float)humi_val.i; //converts integer to float
temp_val.f=(float)temp_val.i; //converts integer to float
calc_sth11(&humi_val.f,&temp_val.f); //calculate humidity, temperature
dew_point=calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
printf("temp:%5.1fC humi:%5.1f%% dew point:%5.1fC\n",temp_val.f,humi_val.f,dew_point);
//----------wait approx. 0.8s to ××oid heating up SHTxx------------------------------
for (i=0;i<40000;i++); //(be sure that the compiler doesn't eliminate this line!)
67
广告是说可以免费申请样品,可是打电话后却说不可以。
引用:
最近找这个找疯了,求求哪位大侠帮个忙!
先谢谢了!
广告是说可以免费申请样品,可是打电话后却说不可以。这样的公司不可以信,产品也最好不要用他们的元件。
呵呵,我拿到了样品
67
有51的源码
改改就可以的
