4509|4
61
【求助】请问msp430芯片是否有温度传感器 [复制链接]
请问msp430芯片是否有温度传感器
给你个例子程序参考参考吧,呵呵。 //****************************************************************************** //  MSP-FET430P120 Demo - ADC10 Sample A10 Temp and Convert to oC and oF   // //  Description; A single sample is made on A10 with reference to internal //  1.5V Vref. Software sets ADC10SC to start sample and conversion - ADC10SC //  automatically cleared at EOC. ADC10 internal oscillator/4 times sample //  (64x) and conversion. In Mainloop MSP430 waits in LPM0 to s××e power until //  ADC10 conversion complete, ADC10_ISR will force exit from any LPMx in //  Mainloop on reti. Temperaure in oC stored in IntDegC, oF in IntDegF. // //  Uncalibrated temperature measured from device to device will vary with //  slope and offset - please see datasheet. //  //*MSP430F1232 or MSP430F1132 Device Required*// // //                MSP430F1232 //             ----------------- //         /|\|              XIN|-   //          | |                 | //          --|RST          XOUT|- //            |                 | //            |A10              | // //  M.Buccini //  Texas Instruments, Inc //  January 2004 //  Updated for IAR Embedded Workbench Version: 2.21B //****************************************************************************** #include  <msp430x12x2.h> int long temp; int long IntDegF; int long IntDegC; void main(void) {   WDTCTL = WDTPW + WDTHOLD;             // Stop WDT   ADC10CTL1 = INCH_10+ADC10DIV_3;       // Temp Sensor ADC10CLK/4      ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;      while(1)   {     ADC10CTL0 |= ENC + ADC10SC;         // Sampling and conversion start     _BIS_SR(CPUOFF + GIE);              // LPM0 with interrupts ena××ed    //  oF = ((A10/1024)*1500mV)-923mV)*1/1.97mV = A10*761/1024 - 468     temp = ADC10MEM;     IntDegF = ((temp - 630) * 761) / 1024;          //  oC = ((A10/1024)*1500mV)-986mV)*1/3.55mV = A10*423/1024 - 278     temp = ADC10MEM;     IntDegC = ((temp - 673) * 423) / 1024;              _NOP();                             // SET BREAKPOINT HERE   } } // ADC10 interrupt service routine #pragma vector=ADC10_VECTOR __interrupt void ADC10_ISR (void) {     _BIC_SR_IRQ(CPUOFF);                // Clear CPUOFF bit from 0(SR) }  详情 回复 发表于 2006-1-23 14:36
有吧
MSP430FX14X可以采集温度,但是我觉得精度不怎么样,受场合限制。
n多芯片都有,不过都不是十分精确的那种,毛估估的还可以
给你个例子程序参考参考吧,呵呵。
// MSP430F1232
// /|\| XIN|-
// --|RST XOUT|-
// |A10 |
// M.Buccini
// January 2004
int long temp;
int long IntDegF;
int long IntDegC;
void main(void)
while(1)
temp = ADC10MEM;
temp = ADC10MEM;
