4231|5
【求助】大虾们MSP430怎样实现软件串行口 [复制链接]
我用的AD是AD73360,16位串行的,但它不是SPI接口,我怎样用MSP430来实现软件串行口来和AD通信,大虾们有没有源程序?
//****************************************************************************** //  MSP-FET430x110 Demo - Timer_A UART 9600 Echo, HF XTAL ACLK // //  Description: Use timer_A CCR0 hardware output modes and SCCI data latch to //  to implement UART function @ 9600 baud. Software does not directly read and //  write to RX and TX pins, instead proper use of output modes and SCCI data //  latch are demonstrated. Use of these hardware features eliminates ISR //  latency effects as hardware insures that output and input bit latching and //  timing are perfectly synchronised with timer_A regardless of other //  software activity. In the Mainloop the UART function readies the UART to //  receive one character and waits in LPM0 with all activity interrupt driven. //  After a character has been received, the UART receive function forces exit //  from LPM0 in the Mainloop which echo's back the received character. //  ACLK = MCLK = TACLK = HF XTAL = 3.579545MHz    //  //*An external 3.579545Hz XTAL on XIN XOUT is required for ACLK*//          // //                MSP430F1121 //            ----------------- //        /|\|              XIN|-         //         | |                 | 3.58Mhz    //         --|RST          XOUT|-         //           |                 |          //           |   CCI0A/TXD/P1.1|-------->   //           |                 | 9600 8N1 //           |   CCI0B/RXD/P2.2|<-------- // #define RXD   0x04                      // RXD on P2.2 #define TXD   0x02                      // TXD on P1.1 //  Conditions for 9600 Baud HW/SW UART, ACLK = 3.579545MHz #define Bitime_5  0x0BA                 // ~ 0.5 bit length #define Bitime  0x175                   // 104 us ~ 9596 baud unsigned int RXTXData; unsigned char BitCnt; void TX_Byte (void); void RX_Ready (void); //  M.Buccini //  Texas Instruments, Inc //  March 2002 //****************************************************************************** #include <msp430x11x1.h> void main (void) {   unsigned int i;   WDTCTL = WDTPW + WDTHOLD;             // Stop watchdog timer   BCSCTL1 |= XTS;                       // ACLK = LFXT1 = HF XTAL   do   {   IFG1 &= ~OFIFG;                       // Clear OSCFault flag   for (i = 0xFF; i > 0; i--);           // Time for flag to set   }   while ( IFG1 & OFIFG );               // OSCFault flag still set?                  BCSCTL2 |= SELM1+SELM0;               // MCLK = LFXT1 (safe)   CCTL0 = OUT;                          // TXD Idle as Mark   TACTL = TASSEL0+MC1;                  // ACLK, continous mode   P1SEL = TXD;                          // P1.1/TA0 for TXD function   P1DIR = TXD;                          // TXD output on P1   P2SEL = RXD;                          // P2.2/TA0 as RXD input // Mainloop   for (;                                 {   RX_Ready();                           // UART ready to RX one Byte   _BIS_SR(CPUOFF+GIE);                  // Enter LPM0 Until character RXed   TX_Byte();                            // TX Back RXed Byte Received   } } // Function Transmits Character from RXTXData Buffer void TX_Byte (void) {   BitCnt = 0xA;                         // Load Bit counter, 8data + ST/SP   CCR0 = TAR;                           // Current state of TA counter   CCR0 += Bitime;                       // Some time till first bit   RXTXData |= 0x100;                    // Add mark stop bit to RXTXData   RXTXData = RXTXData << 1;             // Add space start bit   CCTL0 = OUTMOD0+CCIE;                 // TXD = mark = idle   while ( CCTL0 & CCIE );               // Wait for TX completion } // Function Readies UART to Receive Character into RXTXData Buffer void RX_Ready (void) {   BitCnt = 0x8;                         // Load Bit counter   CCTL0 = SCS+CCIS0+OUTMOD0+CM1+CAP+CCIE;   // Sync, Neg Edge, Capture          } // Timer A0 interrupt service routine interrupt[TIMERA0_VECTOR] void Timer_A (void) {   CCR0 += Bitime;                       // Add Offset to CCR0 // RX   if (CCTL0 & CCIS0)                    // RX on CCI0B?   {     if( CCTL0 & CAP )                   // Capture mode = start bit edge     {     CCTL0 &= ~ CAP;                     // Switch from capture to compare mode     CCR0 += Bitime_5;     }     else     {     RXTXData = RXTXData >> 1;                  if (CCTL0 & SCCI)                 // Get bit waiting in receive latch       RXTXData |= 0x80;                        BitCnt --;                        // All bits RXed?       if ( BitCnt == 0) //>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<       {       CCTL0 &= ~ CCIE;                  // All bits RXed, disa××e interrupt       _BIC_SR_IRQ(CPUOFF);              // Clear LPM0 bits from 0(SR)       } //>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<     }   } // TX   else   {     if ( BitCnt == 0)     CCTL0 &= ~ CCIE;                    // All bits TXed, disa××e interrupt     else     {       CCTL0 |=  OUTMOD2;                  // TX Space       if (RXTXData & 0x01)                        CCTL0 &= ~ OUTMOD2;                 // TX Mark       RXTXData = RXTXData >> 1;       BitCnt --;     }   } }  详情 回复 发表于 2005-10-17 15:24
用I/O模拟
65
用P6口,另外你用的是哪种430单片机?
我用的是MSP430F149
用timerA 模拟 网上有例程的
89
// MSP430F1121
// /|\| XIN|-
// | | | 3.58Mhz
// --|RST XOUT|-
// | | 9600 8N1
// M.Buccini
// March 2002
void main (void)
unsigned int i;
do
// Mainloop
for (;
void TX_Byte (void)
// RX
CCR0 += Bitime_5;
else
RXTXData |= 0x80;
if ( BitCnt == 0)
// TX
else
if ( BitCnt == 0)
else
BitCnt --;
