5352|8
77
请问版主关于149信息存储器的使用问题 [复制链接]
信息存贮器顾名思义是存放数据的,可以当作EEPROM来使用,每段128字节,
代码存贮器每段512字节
这是版主的话,但是信息存储器如何使用,我在书籍上看得segment A和segment B如何解释。
FlASH是不同于EEPROM的,差别在于EEPROM可以单字节任意写(可以把1写成0,也可以把0写成1),而FLASH只能把1写成0,要把0写成1时,只能块或者片擦除!  详情 回复 发表于 2005-1-21 12:33
77
信息存贮器有两段,segment A和segment B,每段128字节,使用方法请见下面例子:
// MSP-FET430x110 Demo - Flash In-System Programming
// Description; This program first erases flash seg A, then it increments all
// values in seg A, then it erases seg B, then copies seg A to seg B.
// Assumed MCLK 550kHz - 900kHz.
// MSP430F1121
// /|\| XIN|-
// --|RST XOUT|-
// M. Mitchell
// Texas Instruments, Inc
// August 2002
// Built with IAR Embedded Workbench Version: 1.25A
// December 2003
// Updated for IAR Embedded Workbench Version: 2.21B
#include <msp430x11x1.h>
char value; // 8-bit value to write to segment A
// Function prototypes
void write_SegA (char value);
void copy_A2B (void);
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
FCTL2 = FWKEY + FSSEL0 + FN0; // MCLK/2 for Flash Timing Generator
value = 0; // initialize value
while(1) // Repeat forever
write_SegA(value++); // Write segment A, increment value
copy_A2B(); // Copy segment A to B
char *Flash_ptr; // Flash pointer
unsigned int i;
Flash_ptr = (char *) 0x1080; // Initialize Flash pointer
FCTL1 = FWKEY + ERASE; // Set Erase bit
FCTL3 = FWKEY; // Clear Lock bit
*Flash_ptr = 0; // Dummy write to erase Flash segment
FCTL1 = FWKEY + WRT; // Set WRT bit for write operation
for (i=0; i<128; i++)
*Flash_ptr++ = value; // Write value to flash
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCK; // Reset LOCK bit
char *Flash_ptrA; // Segment A pointer
char *Flash_ptrB; // Segment B pointer
unsigned int i;
Flash_ptrA = (char *) 0x1080; // Initialize Flash segment A pointer
Flash_ptrB = (char *) 0x1000; // Initialize Flash segment B pointer
*Flash_ptrB = 0; // Dummy write to erase Flash segment B
*Flash_ptrB++ = *Flash_ptrA++; // copy value segment A to segment B
84
segment A和segment B如何解释,是不是430内部的flash都可以作为e2prom使用,segment A和segment B表示什么意思,我不懂。所以看着程序我也头疼。请版主明释!!!
MSP430F149的FLASH空间:存放代码地址为:0x1100~0xffff,按512字节分段;存放信息的地址范围:0x1000~0x10ff,按128字节分段;其中B段(segment B)在前,地址范围为0x1000~0x107f,A段(segment A)地址范围0x1080~0x10ff.
58
说实话,除了扇区大小以外和代码存储器无差别
79
4楼的请解释   是单独重新配置地址还是和代码段统一分配地址。能不能单独编成,编过之后再烧代码。我想把它当e2prom用。谢谢!!
75
一般的编程器都支持
引用:
102
只烧内部的e2prom段或只烧程序代码段,两者互不影响,是吗?
87
