8811|11
75
32768晶振,利用BASIC TIMER,做精确时钟,下面的程序有什么问题? [复制链接]
我是用ACLK/256
然后中断频率选择位IP2,IP1置位,这样中断频率就是
ACLK/256=128
128/128=1
也就是1秒中断一次了?
为什么我测量时间,有15分钟4秒的误差这么大?
请高手指点?如何做高精度的时钟!
引用: 看到上面的问题,我专门做了一次实验,发现晶振为32.773KHZ,当初就是每24小时快15秒,这次加电容调到32.769KHZ,运行24小时后,发现快了2秒,因此晶振必须调整.我使用BT定时器. 程序: RESET mov.w #300h,SP ; Initialize stackpointer StopWDT mov.w #WDTPW+WDTHOLD,&WDTCTL ; Stop WDT MOV.B #SCFQ_4M,&SCFQCTL SetupFLL bis.b #XCAP18PF,&FLL_CTL0 ; Configure load caps bis.b #FLL_DIV_1,&FLL_CTL1 mov.b #20h,&P1SEL ;FACLK OUTPUT MOV.B #0FFH,&P1OUT MOV.B #0FFH,&P1DIR call #lcd_on call #wait_1s BIS.B #BTIE,&IE2 EINT mlp: bis.w #LPM3,SR ; CPU off call #time_lcd jmp mlp lcd_on: ; MOV.B #SCFQ_4M,&SCFQCTL SetupLCD mov.b #LCDON+LCD4MUX+LCDP0+LCDLOWR,&LCDCTL ; STK LCD 4Mux, S0-S15 SetupBT mov.B #BTFRFQ1+BTSSEL+BTDIV+BTIP1+BTIP2,&BTCTL ; STK LCD freq. SetupIO mov.b #0FFh,&P5SEL ; Common and Rxx all selected ret BT_ISR: BIC #CPUOFF,0(SP) RETI 电容的调整是利用这个吗? bis.b #XCAP18PF,&FLL_CTL0 还是其他的方法调整电容?  详情 回复 发表于 2004-12-3 17:01
75
引用:
我是用ACLK/256
ACLK/256=128
128/128=1
也就是1秒中断一次了?
请高手指点?如何做高精度的时钟!
应该没错.不妨把程序贴出来.
75
mov.b #BTFRFQ1+BTDIV+BT_fCLK2_DIV128,&BTCTL
CLR R5
CLR R6
CLR R7
CLR R8
MOV.B #0EBH,LCDM12
MOV.B #0EBH,LCDM11
MOV.B #0EBH,LCDM10
MOV.B #0EBH,LCDM9
MOV.B #0EBH,LCDM8
MOV.B #0EBH,LCDM7
BIS.B #010H,LCDM10
bis.w #BTIE,&IE2
eint ; Ena××e interrupts
bis.w #CPUOFF,SR ; CPU off
BT_ISR
INC R5
CMP #60,R5
JZ KK
MOV R5,R15
CALL #bbs
MOV.B &213H,R4
MOV.B LCD_Tab(R4),LCDM12
MOV.B &212H,R4
MOV.B LCD_Tab(R4),LCDM11
JMP HH
KK CLR R5
INC R6
CMP #60,R6
JZ KK1
MOV R5,R15
CALL #bbs
MOV.B &213H,R4
MOV.B &212H,R4
MOV R6,R15
CALL #bbs
MOV.B &213H,R4
MOV.B LCD_Tab(R4),LCDM10
BIS.B #010H,LCDM10
MOV.B &212H,R4
MOV.B LCD_Tab(R4),LCDM9
JMP HH
KK1 CLR R6
INC R7
CMP #24,R7
JZ KK2
MOV R6,R15
CALL #bbs
MOV.B &213H,R4
BIS.B #010H,LCDM10
MOV.B &212H,R4
MOV R7,R15
CALL #bbs
MOV.B &213H,R4
MOV.B LCD_Tab(R4),LCDM8
MOV.B &212H,R4
MOV.B LCD_Tab(R4),LCDM7
JMP HH
KK2 CLR R5
CLR R6
CLR R7
HH RETI
DIVIDE
clr r14
mov #17,r10
DIV1 cmp r11,r13
jlo DIV2
sub r11,r13
DIV2 rlc r14
jc DIV4
dec r10
jz DIV4
rla r12
rlc r13
jnc DIV1
sub r11,r13
setc
jmp DIV2
DIV4 ret
bbs
mov r15, r12
mov #0, r13
mov #10, r11
call #DIVIDE
mov.b r14,&212h
mov.b r13,&213h
ret
77
62
引用:
CLR R5
CLR R6
CLR R7
CLR R8
MOV.B #0EBH,LCDM12
MOV.B #0EBH,LCDM11
MOV.B #0EBH,LCDM10
MOV.B #0EBH,LCDM9
MOV.B #0EBH,LCDM8
MOV.B #0EBH,LCDM7
BIS.B #010H,LCDM10
bis.w #BTIE,&IE2
BT_ISR
INC R5
CMP #60,R5
HH RETI
你的主程序就这么一句话???
你应该让他无限循环阿。
main
bis.w #CPUOFF,SR
jmp main
引用:
你的主程序就这么一句话???
你应该让他无限循环阿。
main
bis.w #CPUOFF,SR
jmp main
不是的,bis.w #CPUOFF,SR
以后,单片机的CPU关闭,进入低功耗了
中断处理完成以后,还会回到原来的状态中的(低功耗)。
所以不用写循环的。
检测以下32.768kHZ
编一段小程序,通过TACLK口把ACLK发送出来,用频率仪检测一下,调整震荡电容的值,对晶振频率微调。
129
bc007
引用:
我是用ACLK/256
ACLK/256=128
128/128=1
也就是1秒中断一次了?
请高手指点?如何做高精度的时钟!
说举实话,我也这么做的,一天慢几十秒,俺也不知道咋会事。
54
我的问题解决了,看看对你是否有提醒。
我做的时钟一天慢几十秒,我曾经换过晶体,结果一样,就是说,好与差的晶体不会有这么大的误差。
后来仔细检查程序,发现一个问题:
我在初始设定完成以后,由于键盘调整的需要,暂时关闭了中断,调试时很随意在主循环里又加了一个中断使能,看起来运行没有问题,实际上可能在关闭中断时丢了一些时钟周期,所以整体运行就慢了,到底DINT后,CCR0数是继续走还是清零,我还不清楚,不过我看是停了。我重新调整一下程序,一天误差在1~2秒内,可以接受。
你的程序里没有用DINT,但可能在某个位置使能关闭(这是我猜测),丢失了一些晶体的周期,看起来就慢了。就是说,你要一直确保TIME-A能在中断使能状态。
63
引用:
我的问题解决了,看看对你是否有提醒。
后来仔细检查程序,发现一个问题:
非常感谢
我的程序里面并没有用的其他的东西,我只让它做时钟。过程大致就是这个样子的:
定时1S,中断处理,处理好以后,进入CPUOFF状态,再次中断以后,在处理,然后就是这样一个循环过程。
我没有换别的晶振,不知道是不是我的晶振有问题,我可以先看看晶阵有没有问题,用示波器看看是不是32768。
你给我看看你的程序,只要看看时钟程序就可以了。
65
晶振问题!
程序:
MOV.B #0FFH,&P1OUT
MOV.B #0FFH,&P1DIR
call #lcd_on
call #wait_1s
BIS.B #BTIE,&IE2
EINT
call #time_lcd
jmp mlp
ret
BT_ISR:
BIC #CPUOFF,0(SP)
RETI
引用:
程序:
MOV.B #0FFH,&P1OUT
MOV.B #0FFH,&P1DIR
call #lcd_on
call #wait_1s
BIS.B #BTIE,&IE2
EINT
call #time_lcd
jmp mlp
ret
BT_ISR:
BIC #CPUOFF,0(SP)
RETI
电容的调整是利用这个吗?
还是其他的方法调整电容?
