3781|2
【原创】JTAG的问题 [复制链接]
用网上找的图纸作了JTAG的下载电缆(
1: TDI/TDO. 2:VCC
3:TDI 4:NC
5:TMS 6:XOUT
7:TCK 8:TEST
8:GND 10:NC
11:RST 12:NC
13:NC 14:NC
在IAR3.10里面下程序无法连接,显示
Tue Oct 26 11:47:37 2004: MSP430.DLL version 1.15
Tue Oct 26 11:47:46 2004: Failed to get target information.
Tue Oct 26 11:47:51 2004: Failed to esta××ish communication with hardware.
Please make sure that the hardware is properly connected.
Tue Oct 26 11:47:52 2004: Load module failed
DEMO板子上没有XOUT 和TEST信号引出.是什么问题呢??
他的仿真器有漏洞,我看好多人都发这样的帖子了  详情 回复 发表于 2004-10-28 09:22
64
搞定了!哈哈。有进步!鼓励一下~
81
