6886|13
154
学习心得:最近采用的键盘扫描,采用键反转方法,大家可以贴出其他方法 [复制链接]
#include "hw_memmap.h"                // hw_memmap.h - Macros defining the memory map of Stellaris.
#include "hw_types.h"                // hw_types.h - Common types and macros.
#include "hw_sysctl.h"
#include "sysctl.h"
#include "rom.h"
#include"hw_gpio.h"
#include "gpio.h"
#include "hw_ints.h"
//#include"key316.h"
#define uchar  unsigned char
#define uint   unsigned int
#define ulong  unsigned long
//extern void Delay(ulong ulVal)
//#ifndef KEYBOARD_H
//#define KEYBOARD_H
//定义长标识符成较短的形式
#define SysCtlPeriEnable        SysCtlPeripheralEnable
#define SysCtlPeriDisable       SysCtlPeripheralDisable
#define GPIOPinTypeIn           GPIOPinTypeGPIOInput
#define GPIOPinTypeOutOD        GPIOPinTypeGPIOOutputOD
//行线使用GPIOF(0-3)
#define KEYBOARD_LIN_PERIPH        SYSCTL_PERIPH_GPIOF
#define KEYBOARD_LIN_BASE          GPIO_PORTF_BASE
#define KEYBOARD_LIN_PIN       0x0F
//列线使用GPIOH(0-3)
#define KEYBOARD_COL_PERIPH        SYSCTL_PERIPH_GPIOH
#define KEYBOARD_COL_BASE          GPIO_PORTH_BASE
#define KEYBOARD_COL_PIN       0x0F
////读取按键的函数
//extern uchar scankeyboard(void);
////键盘初始化函数
//extern uchar KeyInit(void);
////将获取的按键转化为相应的指令,0xFF代表非法指令或者未按键
//extern void keyProcess(void);
#endif
uchar scanKeyboard(void)
ulong scanValue[20]={0xEE,0xDE,0xBE,0x7E,
                            0xED,0xDD,0xBD,0x7D,
                            0xEB,0xDB,0xBB,0x7B,
                            0xE7,0xD7,0xB7,0x77,
const ulong keyASC[20]={'1','2','3','4',
                            '5','6','7','8',
                            '9','10','11','12',
                            '13','14','15','16',
//定义变量及使能GPIOE和GPIOB
ulong key,temp,temp1,temp2,temp3;
SysCtlPeripheralEnable(KEYBOARD_LIN_PERIPH);
SysCtlPeripheralEnable(KEYBOARD_COL_PERIPH);
//9个引脚全部上拉电阻有效
GPIOPadConfigSet(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN,GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_OD_WPU);
GPIOPadConfigSet(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN,GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_OD_WPU);
GPIOPinTypeOutOD(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN);
GPIOPinTypeIn(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN);
GPIOPinWrite(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN,0x00);
temp1=GPIOPinRead(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN)& KEYBOARD_COL_PIN;
temp1=temp1<<4;
GPIOPinTypeIn(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN);
GPIOPinTypeOutOD(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN);
GPIOPinWrite(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN,0x00);
temp2=GPIOPinRead(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN)& KEYBOARD_LIN_PIN;
temp=temp1 | temp2;
if(temp!=0xFF)
//    Delay(13*SysCtlClockGet()/4000);                            //延时去抖动
    SysCtlDelay(13*(SysCtlClockGet()/3000));
    temp1=temp1<<4;
        temp3=temp1 | temp2;
          if(temp3==temp)
                     for(key=0;key<20;key++)
                       if(temp==scanValue[key])
                                  return(keyASC[key]);
return ('N');
void KeyInit(void)
   SysCtlPeriEnable(KEYBOARD_LIN_PERIPH);
   SysCtlPeriEnable(KEYBOARD_COL_PERIPH);
void keyProcess(uchar KeyValue)
//  完成按键的功能;
[ 本帖最后由 zyc1 于 2011-4-7 22:59 编辑 ]
key.rar
1.23 KB, 下载次数: 38
不知道为什么会有这么长的延时  SysCtlDelay(13*(SysCtlClockGet()/3000)); cpu白白等待13mS,这个时间内,可以运行上万条指令了  详情 回复 发表于 2012-4-14 18:22
7228
192
如果贴出思路比较好吧 光看 感觉比较麻烦
31
看得我云里雾里~
学习了
154
注释了下
#include "hw_types.h"  // hw_types.h - Common types and macros. 定义了一个tBoolean(unsigned char),定义位带
#include "sysctl.h"  // sysctl.h - Prototypes for the system control driver.
#include "rom.h"   // rom.h - Macros to facilitate calling functions in the ROM.
#include"hw_gpio.h"
#include "gpio.h"   // gpio.h - Defines and Macros for GPIO API.
#include "hw_ints.h"    // hw_ints.h - Macros that define the interrupt assignment on Stellaris.
//#include"key.h"    //原来下面的宏定义是在头文件里面的,为了方便看就放负复制到key.C来了一样用
//定义长标识符成较短的形式
//行线使用GPIOF
#define KEYBOARD_LIN_PIN      GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4      //  0x0F
//列线使用GPIOH
#define KEYBOARD_COL_PIN       GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4      // 0x0F
////读取按键的函数
//extern uchar scanKeyboard(void);
////键盘初始化函数
//extern uchar KeyboardInit(void);
////将获取的按键转化为相应的指令,0x1E1F代表非法指令或者未按键
////#endif
 ulong scanValue[16]={0xEE,0xDE,0xBE,0x7E,     //定义键值
 const uchar keyASC[20]={1,2,3,4,       //返回键号
                         5,6,7,8,
                         9,10,11,12,
       13,14,15,16
//定义变量及使能GPIO
//8个引脚全部上拉电阻有效
GPIOPinTypeOutOD(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN);          //设置为输出(行线)GPIOF(0-3)
GPIOPinTypeIn(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN);              //设置为输入(列线)GPIOH(0-3)
GPIOPinWrite(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN,0x00);              //行线输出0
temp1=GPIOPinRead(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN)& KEYBOARD_COL_PIN; //读列线的值
temp1=temp1<<4;
GPIOPinTypeIn(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN);                //设置为输入(行线)
GPIOPinTypeOutOD(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN);             //设置为输出(列线)
GPIOPinWrite(KEYBOARD_COL_BASE,KEYBOARD_COL_PIN,0x00);                //列线输出0
temp2=GPIOPinRead(KEYBOARD_LIN_BASE,KEYBOARD_LIN_PIN)& KEYBOARD_LIN_PIN;   //读行线的值
temp=temp1 | temp2;
if(temp!=0xFF)                                            //有键按下
    temp1=temp1<<4;
   if(temp3==temp)
return ('N');
[ 本帖最后由 zyc1 于 2011-4-16 23:26 编辑 ]
154
把有的语句注释了下,大家就好明白了 其实也很简单的啊
管理员
辛苦啦
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
373
现在有一种检测按键的方法是---基于“状态机”的,你可以试一下
2130
这么长的代码,合用,在实际应用中有何好处?
4138
ti彻底火了哈哈哈
2130
回复 10楼 鑫海宝贝 的帖子
LS的话说的好莫名其妙
4138
回复 11楼 leang521 的帖子
嘿嘿
thank u............
