3819|3
memory 的错误报告 [复制链接]
Error:   Memory Map Error: WRITE access by CPU to address 0xfffff5a0, which is RESERVED in Hardware.
不知道怎么修改啊
如果是cmd文件错误,为什么运行别的程序的时候没有问题,一但我们运行下面这一段随机数产生程序时候就有问题了呢 #include<stdio.h> #include\"stdlib.h\" #include\"volume.h\" #include   \"math.h\" #include <time.h>    float   gaussian_random(void); float   uniform_random(void); void main() { int   N=0; float   number[10000]; srand( (unsigned)time( NULL ) );   for(N=0;N<10000;N++)      {         number[N]=gaussian_random();       printf(\"%f  \",number[N]);          } } float gaussian_random(void) {     static   int   next_gaussian=0;     static   float   saved_gaussian_value;     float   fac,rsq,v1,v2;     if(next_gaussian==0)         {         do   {             v1 = 2.0*uniform_random()-1.0;             v2 = 2.0*uniform_random()-1.0;             rsq = v1*v1+v2*v2;              }           while(rsq>= 1.0||rsq==0.0);         fac=sqrt(-2.0*log(rsq)/rsq);         saved_gaussian_value=v1*fac;         next_gaussian=1;         return   v2*fac;      }        else       {         next_gaussian=0;         return (saved_gaussian_value);     } } float  uniform_random(void) {     return((float)rand()/(float)RAND_MAX); } 网上下载的程序  详情 回复 发表于 2009-7-23 02:15
79
被这个问题卡了很久了
79
MEMORY
   ISRAM       : origin = 0x0,         len = 0x100000
SECTIONS
        .vectors > ISRAM
        .text    > ISRAM
        .bss     > ISRAM
        .cinit   > ISRAM
        .const   > ISRAM
        .far     > ISRAM
        .stack   > ISRAM
        .cio     > ISRAM
        .sysmem  > ISRAM
我的cmd文件在这里啊,
是在不知道怎么回事,我刚刚改变了以下那个地址,结果现在就出现这样的错误
Loader: One or more sections of your program falls into a memory region that is not writable.  These regions will not actually be written to the target.  Check your linker configuration and/or memory map.
我gel文件
StartUp()
    /* C64xx sim specific memory mapping */
    GEL_MapOn();
    GEL_MapReset();
    GEL_MapAdd(0x000F0000,0,0x10000000,1,1); /* flat memory */
    /* uncomment the following line to initialize the
       EMIF registers on the C6x when Code Composer starts up */
    emif_init();
/* OnReset callback function called after the target processor has been reset */
OnReset(int nErrorCode)
    if (nErrorCode)
       GEL_TextOut(\"An error occured while resetting -%d-\\n\",nErrorCode);
    else
       emif_init();
* Menuitem creates a selection available beneath the GEL
* menu selection in Code Composer Studio.
menuitem \"Resets\";
hotmenu Reset_and_EMIF_Setup()
    GEL_Reset();
    emif_init();
hotmenu ClearBreakPts_Reset_EMIFset()
  GEL_BreakPtReset();
  GEL_Reset();
  emif_init();
emif_init()
    #define EMIFA_GCTL       0x01800000
    #define EMIFA_CE1        0x01800004
    #define EMIFA_CE0        0x01800008
    #define EMIFA_CE2        0x01800010
    #define EMIFA_CE3        0x01800014
    #define EMIFA_SDRAMCTL   0x01800018
    #define EMIFA_SDRAMTIM   0x0180001c
    #define EMIFA_SDRAMEXT   0x01800020
    #define EMIFA_CE1SECCTL  0x01800044
    #define EMIFA_CE0SECCTL  0x01800048
    #define EMIFA_CE2SECCTL  0x01800050
    #define EMIFA_CE3SECCTL  0x01800054
    #define EMIFB_GCTL       0x01A80000
    #define EMIFB_CE1        0x01A80004
    #define EMIFB_CE0        0x01A80008
    #define EMIFB_CE2        0x01A80010
    #define EMIFB_CE3        0x01A80014
    #define EMIFB_SDRAMCTL   0x01A80018
    #define EMIFB_SDRAMTIM   0x01A8001c
    #define EMIFB_SDRAMEXT   0x01A80020
    #define EMIFB_CE1SECCTL  0x01A80044
    #define EMIFB_CE0SECCTL  0x01A80048
    #define EMIFB_CE2SECCTL  0x01A80050
    #define EMIFB_CE3SECCTL  0x01A80054
    /* EMIFA */
    *(int *)EMIFA_GCTL     = 0x00012070;
    *(int *)EMIFA_CE0      = 0xffffffd3;  /* CE0 SDRAM                     */
    *(int *)EMIFA_CE2      = 0x22a28a22;  /* CE2 Daughtercard 32-bit async */
    *(int *)EMIFA_CE3      = 0x22a28a22;  /* CE3 Daughtercard 32-bit async */
    *(int *)EMIFA_SDRAMCTL = 0x47115000;  /* SDRAM control                 */
    *(int *)EMIFA_SDRAMTIM = 0x00000618;  /* SDRAM timing (refresh)        */
    *(int *)EMIFA_SDRAMEXT = 0x000a8529;  /* SDRAM extended control        */
    /* EMIFB */
    *(int *)EMIFB_GCTL     = 0x00002070;
    *(int *)EMIFB_CE0      = 0x22008800;  /* CE0 CPLD 8-bit                */
    *(int *)EMIFB_CE1      = 0x22008800;  /* CE1 Flash 8-bit               */
77
#include<stdio.h>
#include   \"math.h\"
#include <time.h>
void main()
int   N=0;
        do   {
            rsq = v1*v1+v2*v2;
        next_gaussian=1;
        return   v2*fac;
    else
        next_gaussian=0;
网上下载的程序
