7592|4
62
大家帮忙看看怎么回事,不会是dsp坏了吧? [复制链接]
用XDS560仿真器,配置CCS Setup,并启动CCS后出现如下错误
Error connecting to the target:
Error 0x80000240/-291
Fatal Error during: Initialization, OCS,
This error was generated by TI\'s USCIF driver.
SC_ERR_TST_MEASURE <-291>
The built-in scan-path length measurement has failed. This indicates
that the JTAG controller cannot reliably communicate with
the target DSP\'s and micro-controllers at that frequency.
Try specifying the scan-path lengths in the board configuration
file because the built-in scan-path reliability tests cannot be
performed without knowledge of the scan-path length.
Sequence ID: 0
Error Code: -291
Error Class: 0x80000240
Board Name: C6455 XDS560 Emulator_1
Cpu Name: C6400PLUS_0
Abort:                Close Code Composer Studio.
Retry:                Try to connect to the target again.
Cancel:                Remain disconnected from the target
Diagnostic:        Run diagnostic utility.
不会是DSP坏了吧?
应该不会的.不过方向和信号是一个寄存器得注意一下吧.   详情 回复 发表于 2008-12-9 14:23
293
仿真器型号告知一下,以及你的ccs版本告知,谢谢!
84
仿真器就是XDS560,CCS版本为3.2
谢谢版主了,帮忙看看怎么回事。
之前仿真器调DSP是没有问题的。
DSP为6455
79
nf9763
引用:
ranran 写道:
Sequence ID: 0
Error Code: -291
不会是DSP坏了吧?
61
