4119|2
85
突然connect不上了?help me [复制链接]
刚开始还用着挺好的,新建了一个工程后,连了好多次,怎么也connect不上。
挺急的,还请大家多帮忙,非常感谢。
Error connecting to the target: Error 0x80001240/-1072 Fatal Error during: Initialization, OCS, Target,  Device driver: Power Loss Detected on Target CPU. This could also result from disconnecting the emulator from the target. It is recommended to RESET EMULATOR.  This will disconnect each  target from the emulator.  The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target.   Sequence ID: 0 Error Code: -1072 Error Class: 0x80001240
换一个USB口,或者将USB线拔掉再插上试试  详情 回复 发表于 2007-8-4 09:08
75
断电,再试试看
呵呵
