3664|2
请教编译出错! [复制链接]
out文件出不来,提示的错误是symbol referencing errors
编译提示:
--------------------------  carrier64161.pjt - Debug  --------------------------
\"d:\\ti\\c6000\\cgtools\\bin\\cl6x\" -g -q -fr\"D:/ti/myprojects/carrier/carrier64161/Debug\" -d\"_DEBUG\" -mv6400 -@\"Debug.lkf\" \"init.c\"
\"d:\\ti\\c6000\\cgtools\\bin\\cl6x\" -g -q -fr\"D:/ti/myprojects/carrier/carrier64161/Debug\" -d\"_DEBUG\" -mv6400 -@\"Debug.lkf\" \"main.c\"
\"d:\\ti\\c6000\\cgtools\\bin\\cl6x\" -g -q -fr\"D:/ti/myprojects/carrier/carrier64161/Debug\" -d\"_DEBUG\" -mv6400 -@\"Debug.lkf\" \"start.asm\"
\"d:\\ti\\c6000\\cgtools\\bin\\cl6x\" -@\"Debug.lkf\"
undefined                        first referenced
symbol                              in file
_load                            D:\\ti\\myprojects\\carrier\\carrier64161\\Debug\\main.obj
>>   error: symbol referencing errors - \'sine.out\' not built
Build Complete,
  1 Errors, 0 Warnings, 0 Remarks.
高手解决下
本帖最后由 dontium 于 2015-1-23 11:13 编辑 我看此load函数的说明,它什么都不做的,只是增加DSP的计算负担,可能是用来模拟负载的。   详情 回复 发表于 2007-6-28 09:19
引用:
写道:
替换库文件
我的函数没有定义~不过没看懂load函数干什么的
后来把load.asm添加以后就好了
附_load.sam
        .global _load
        .text
N       .set    1000
;  ======== _load ========
;  This function simulates a load on the DSP by executing N * loopCount
;  instructions, where loopCount is the input parameter to load().
;      void _load(int loopCount)
;  The loop is using 8 instructions. One instruction for sub, nop and
;  b, plus nop 5. The extra nop added after sub is to make the number
;  of instructions in the loop a power of 2.
_load:
        mv a4, b0               ; use b0 as loop counter
  [!b0] b lend
        mvk N,b1
        mpy b1,b0,b0
        nop
        shru b0,3,b0            ; (loop counter)= (# loops)/8
loop:
        sub b0,1,b0
78
