5362|7
58
2812的CAN通信问题,急啊! [复制链接]
各位老师:
   我测试2812片子CAN通信时,用的是从TI网站下的ECAN通信源代码,但无论如何CAN通信都调试不通,查看寄存器的时候是TA无法置1,请教各位老师、前辈能否告诉我原因,谢谢!
急啊!!!!!!!都测试一周了!
#include \"DSP28_Device.h\"
#define TXCOUNT  10000  // Transmission will take place (TXCOUNT) times..
long      i;
long           loopcount = 0;
void InitECan(void);
main()
/* Create a shadow register structure for the CAN control registers. This is
needed, since, only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents. This is
especially true while writing to a bit (or group of bits) among bits 16 - 31 */
struct ECAN_REGS ECanaShadow;
/* Initialize the CAN module */
        InitECan();
/* Write to the MSGID field  */
    ECanaMboxes.MBOX5.MSGID.all = 0x9FFFFFFF; // Extended Identifier
/* Configure Mailbox under test as a Transmit mailbox */
        ECanaShadow.CANMD.all = ECanaRegs.CANMD.all;
        ECanaShadow.CANMD.bit.MD5 = 0;
        ECanaRegs.CANMD.all = ECanaShadow.CANMD.all;
/* Enable Mailbox under test */
        ECanaShadow.CANME.all = ECanaRegs.CANME.all;
        ECanaShadow.CANME.bit.ME5 = 1;
        ECanaRegs.CANME.all = ECanaShadow.CANME.all;
/* Write to DLC field in Master Control reg */
        ECanaMboxes.MBOX5.MCF.bit.DLC = 8;
/* Write to the mailbox RAM field */
     ECanaMboxes.MBOX5.MDRL.all = 0x01234567;
         ECanaMboxes.MBOX5.MDRH.all = 0x89ABCDEF;
/* Begin transmitting */
    // while(1)                                                         // Uncomment this line for infinite transmissions
    for(i=0; i < TXCOUNT; i++)                                // Uncomment this line for finite transmissions
     ECanaShadow.CANTRS.all = 0;
     ECanaShadow.CANTRS.bit.TRS5 = 1;     // Set TRS for mailbox under test
     ECanaRegs.CANTRS.all = ECanaShadow.CANTRS.all;
     while(ECanaRegs.CANTA.bit.TA5 == 0 ) {}  // Wait for TA5 bit to be set..
//***问题就出在这里,TA5无法置1所以CAN通信怎么也不通*****************
     ECanaShadow.CANTA.all = 0;
     ECanaShadow.CANTA.bit.TA5 = 1;              // Clear TA5
     ECanaRegs.CANTA.all = ECanaShadow.CANTA.all;
     loopcount ++;
恳请各位指教,多谢了啊!!!!!!!
看来是没解决了  详情 回复 发表于 2018-1-15 15:22
92
同问,有高手赶快指点一下吧!
总线上要有对应的接受节点才能够发送成功,不能像232那样调试Can
58
遇到相同问题,感觉板子无反应。用示波器测量2812CAN的两脚,始终为3。3V高电平,没有波形输出。请问是怎么回事啊?谢谢!
对,我也是同样问题。开发板跟别人的CAN-USB连起来同样无法正常通信,始终是隐形位。  详情 回复 发表于 2014-2-25 15:52
77
必须两个板子连接起来才能调试。。
jackylam 发表于 2009-8-15 03:23
遇到相同问题,感觉板子无反应。用示波器测量2812CAN的两脚,始终为3。3V高电平,没有波形输出。请问是怎么 ...
您好楼主,您的问题解决了吗,我也是现在一直遇到这个问题,求解决方案,非常感谢,调了两周了
看来是没解决了
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
