4104|3
64
F2812编译顺利通过,烧写时提示如下错误,为什么呢? [复制链接]
**** Begin Erase/Program/Verify Operation. ***
Erase/Program/Verify Operation in progress...
Erase operation in progress...
Erase operation was successful.
Program operation in progress...
Flash API Error #31:
There was a Zero Bit Error on the Program Operation.
First Fail Address = 0x003d7800
Expected Data = 0x6054
Actual Data = 0x6031
Erase/Program/Verify Operation failed
**** End Erase/Program/Verify Operation.
[ 本贴由 withwindhh 于 2007-3-22 09:31 AM 最后编辑 ]
我曾经发邮件给ti公司反应这个问题,回复说OTP不能用烧写工具写入程序,于是我把OTP从程序段PAGE0挪到PAGE1数据段,就好了,烧写很顺利。  详情 回复 发表于 2008-3-26 02:26
应该是烧写器的版本不够新
下一个新的试试吧
地址长度不够,期望的大于实际的,你可以将映射到OTP段的程序映射到其它段上试试
谢谢大家,这个问题已解决
