5510|7
tcp通信遇到的问题 [复制链接]
不好意思,小弟刚接触LWIP,在做TCP收发通信的时候遇到,电脑是客户端,目标板是服务端,电脑发送一个TCP数据包,目标板解析,如果符合约定,则回复相应格式的帧,但是发现电脑接到数据所要等待的时间比较长,大约有2S的样子。后来用TCP抓包工具看到下面那样,会出现红色的重发数据。由于是新手,不知道怎么解决它,有高手帮忙分析下这个是什么原因造成的?小弟万分感谢
#include #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "inc/hw_nvic.h" #include "inc/hw_types.h" #include "inc/hw_sysctl.h" #include "driverlib/ethernet.h" #include "driverlib/gpio.h" #include "driverlib/interrupt.h" #include "driverlib/sysctl.h" #include "driverlib/systick.h" #include "driverlib/gpio.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "drivers/rit128x96x4.h" #include "utils/lwiplib.h" #include "utils/ustdlib.h" #include "lwip/tcp.h" #define My_Mac_ID         {0X00,0x14,0x97,0x0F,0x1D,0xE3}  //存储以太网控制器的物理地址,即MAC地址 #define MY_IP_ID               {192,168,14,210}                   //以太网通信的IP地址 #define IP_MARK_ID           {255,255,255,0}                           //255.255.255.0,子网掩码 #define MY_GATEWAY_ID   {192,168,14,254}                     //以太网通信的网关地址 static const unsigned char pucMACAddress[]=My_Mac_ID; static const unsigned char IPAddress[] = MY_IP_ID; static const unsigned char NetMaskAddr[] = IP_MARK_ID; static const unsigned char GwWayAddr[] = MY_GATEWAY_ID; #define SYSTICKHZ                100 #define SYSTICKMS               (1000 / SYSTICKHZ) #define SYSTICKUS               (1000000 / SYSTICKHZ) #define SYSTICKNS               (1000000000 / SYSTICKHZ) static struct tcp_pcb *g_psPCB = NULL; typedef struct {     unsigned long ulRetryCount;                    tBoolean bCONTROLSent;                } tAPPState; struct pbuf *fp=NULL; tAPPState *fpState=NULL;        void SysTickIntHandler(void) {              lwIPTimer(SYSTICKMS); } void UARTSend(const unsigned char *pucBuffer, unsigned long ulCount) {     //     // Loop while there are more characters to send.     //     while(ulCount--)     {         //         // Write the next character to the UART.         //         UARTCharPutNonBlocking(UART0_BASE, *pucBuffer++);     } } //当数据被正确发送到远程主机后(收到ACK),该函数会被调用。 static err_t App_sent(void *arg, struct tcp_pcb *pcb, u16_t len) {    LWIP_UNUSED_ARG(len);   if(!arg) {     return ERR_OK;   }     tcp_arg(pcb, NULL);     tcp_sent(pcb, NULL);     tcp_recv(pcb, NULL);     mem_free(arg);     tcp_close(pcb);         return ERR_OK; } static err_t APP_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) {         tAPPState *pState;         char *q;         unsigned int i;         q=(char*) malloc(p->len);         for(i=0;ilen;i++)                 *(q+i)=*((char*)p->payload+i);         pState = arg;         fp=p;         if((err == ERR_OK) && (p != NULL))         {                 tcp_recved(pcb, p->tot_len);                                   if(strncmp(p->payload, "LED ON", 6) == 0)                 {                          GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_0, GPIO_PIN_0);                          pbuf_free(p);                          tcp_sent(pcb, App_sent);                 }                 if(strncmp(p->payload, "LED OFF", 7) == 0)                 {                          GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_0, 0);                          pbuf_free(p);                          tcp_sent(pcb, App_sent);                 }                 //处理接收部分。         UARTSend((unsigned char *)p->payload,p->len);         RIT128x96x4Enable(1000000);         RIT128x96x4StringDraw("                          ",0,16,15);         RIT128x96x4StringDraw(q,0,16, 15);         RIT128x96x4Disable();         //发送数据         //send_data();         free(q);                 }          if((err == ERR_OK) && (p == NULL))     {         //         // Close the connection.         //         tcp_arg(pcb, NULL);         tcp_sent(pcb, NULL);         tcp_recv(pcb, NULL);         mem_free(pState);         tcp_close(pcb);     }     return ERR_OK;   } //static void //APP_error(void *arg, err_t err) //{ //   //处理错误 //    if(arg != NULL) //    { //        mem_free(arg); //    } //} //static err_t //APP_poll(void *arg, struct tcp_pcb *pcb) //{ //    tAPPState *pState; // //    //    pState = arg; // //   //    pState->ulRetryCount++; // //    //    if(pState->ulRetryCount++ >= 120) //    {        //约120s之后无数据发送就会断开就断开连接。 //        tcp_abort(pcb); //        return(ERR_ABRT); //    } // //   //    return ERR_OK; //} static err_t APP_accept(void *arg, struct tcp_pcb *pcb, err_t err) { tAPPState *pState; tcp_setprio(pcb, TCP_PRIO_MIN); pState = mem_malloc(sizeof(tAPPState)); fpState=pState; if(pState == NULL)     {         return(ERR_MEM);     }     pState->ulRetryCount = 0;     pState->bCONTROLSent = false;         tcp_arg(pcb, pState);         tcp_recv(pcb, APP_recv); //        tcp_err(pcb, APP_error);         //这里设置2每500ms就调用一次。4就是1s         //注意其中的APP_poll只有当协议栈中没有数据进出时,才会被调用。         //我们可以用它来发送某些数据。         // //        tcp_poll(pcb, APP_poll, 4);         RIT128x96x4Enable(1000000);         RIT128x96x4StringDraw("connect succeed        ",0,8, 15);         RIT128x96x4Disable();                   tcp_write(pcb,"hello!\n",6,TCP_WRITE_FLAG_COPY);         tcp_output(pcb);                 return(ERR_OK); } void io_init(void) { SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE,GPIO_PIN_0); GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_0,1); } //***************************************************************************** // // Send a string to the UART. // //***************************************************************************** int main(void) {            struct ip_addr ulIPAddr,ulNetMask,ulGWAddr;    struct tcp_pcb *Pcb1; //   struct pbuf *p;       if(REVISION_IS_A2)     {         SysCtlLDOSet(SYSCTL_LDO_2_75V);     }     SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |                    SYSCTL_XTAL_8MHZ);                SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);     SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);     GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3);         io_init();            SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ);     SysTickEnable();     SysTickIntEnable();         SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);     //     // Enable processor interrupts.     //     IntMasterEnable();     //     // Set GPIO A0 and A1 as UART pins.     //     GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);     //     // Configure the UART for 115,200, 8-N-1 operation.     //     UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,                         (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |                          UART_CONFIG_PAR_NONE));     //     // Enable the UART interrupt.     //     IntEnable(INT_UART0);     UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);     //                 IP4_ADDR(&ulIPAddr,IPAddress[3],IPAddress[2],IPAddress[1],IPAddress[0]);     IP4_ADDR(&ulNetMask,NetMaskAddr[3],NetMaskAddr[2],NetMaskAddr[1],NetMaskAddr[0]);     IP4_ADDR(&ulGWAddr,GwWayAddr[3],GwWayAddr[2],GwWayAddr[1],GwWayAddr[0]);     lwIPInit(pucMACAddress,ulIPAddr.addr, ulNetMask.addr, ulGWAddr.addr, IPADDR_USE_STATIC);     g_psPCB=Pcb1 = tcp_new();     tcp_bind(Pcb1, IP_ADDR_ANY,1027);  //1027     Pcb1 = tcp_listen(Pcb1);     tcp_accept(Pcb1, APP_accept);  //         //tcp_send(Pcb1, send_data);         RIT128x96x4Init(1000000);     RIT128x96x4StringDraw("host,wellcome", 0, 0, 15);         RIT128x96x4StringDraw("waiting for connect", 0, 8, 15);         RIT128x96x4Disable();                while(1)         {         } }  详情 回复 发表于 2011-4-18 22:30
希望高手帮帮忙~~~~
以下是我接受—解析—发送部分源码
static err_t TCP_SER_Receive(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
   tTCPSessionData *pState;
   pState=&g_sTCPSession;
   unsigned char ProtID[2]={0x00,0x00};
   unsigned short regLen;
   unsigned short regLen_tmp;         // ether_cmd register calculate tmp.
   unsigned char  eth_send_data[256];  //ethernet send byte ptr.
   unsigned short uslen;              //send byte length.
   unsigned short usaddr,byte_addr=0;  //inqire byte frist address.
   unsigned char byte_len,ucCunt;
/* Inform TCP that we have taken the data. */
           tcp_recved(pcb,p->tot_len);
           eth_cmd= (unsigned char*)p->payload;
           if((*(eth_cmd+2)==ProtID[0])&&(*(eth_cmd+3)==ProtID[1]))
          if((*(eth_cmd+6)==s_psComData->ucMeterAddr)&&((*(eth_cmd+7)==0x03)||(*(eth_cmd+7)==0x04)))
         regLen=((unsigned short)s_psComData->ucREGnumH)|s_psComData->ucREGnumL;    //计算表里面的寄存器数目
         usaddr = (unsigned short)*(eth_cmd+8)|(*(eth_cmd+9));
                 uslen = (unsigned short)*(eth_cmd+10)|(*(eth_cmd+11));
                 regLen_tmp = usaddr+uslen; // 计算命令帧中的寄存器数
                 //判断寄存器是不是越界,因为表内寄存器有限
                 if((regLen_tmp<=regLen)&&((*(eth_cmd+10)==0x00)&&(*(eth_cmd+11)<0x80)))
           byte_addr = usaddr*2;
                   byte_len = (*(eth_cmd+11))*2;
                   eth_send_data[0] = *eth_cmd;
                   eth_send_data[1] = *(eth_cmd+1);
                   eth_send_data[2] = ProtID[0];
                   eth_send_data[3] = ProtID[1];
                   eth_send_data[4] = (unsigned char)(((byte_len+3)>>8)&0xFF);
                   eth_send_data[5] = (unsigned char)((byte_len+3)&0xFF);
                   eth_send_data[6] = s_psComData->ucMeterAddr;
                   eth_send_data[7] = *(eth_cmd+7);
                   eth_send_data[8] = byte_len;
                   for(ucCunt=0;ucCunt                    eth_send_data[9+ucCunt]=g_psMBdataReps->ucData[byte_addr+ucCunt];
                   lCount=byte_len+9;
                   if(tcp_sndbuf(tpcb) < lCount)
                           lCount = tcp_sndbuf(tpcb);
           // Write the local buffer into the TCP buffer
                   tcp_write(tpcb,eth_send_data,(byte_len+9),0);
           pbuf_free(p);                            // 释放缓冲区数据
131
回复 楼主 qwertyer2010 的帖子
请问楼主,你说的重发是电脑给目标板发,还是目标板向电脑重发?
目标板对主机重发
2641
加tcp_output(pcb);试试
加过了,没用,但是发现如果字节少就不会重发!
苦恼中~~
楼主,接收部分的代码呢,我觉得是在接收部分代码有问题
422
解决了吗?我给个你参考
#include
typedef struct
tAPPState;
void
void
    while(ulCount--)
static err_t
  if(!arg) {
    return ERR_OK;
    tcp_arg(pcb, NULL);
    mem_free(arg);
    tcp_close(pcb);
    return ERR_OK;
static err_t
        tAPPState *pState;
        char *q;
        unsigned int i;
        for(i=0;i<=p->len;i++)
        pState = arg;
        fp=p;
                         pbuf_free(p);
                         pbuf_free(p);
        //处理接收部分。
        //发送数据
        //send_data();
        free(q);
        tcp_arg(pcb, NULL);
        mem_free(pState);
        tcp_close(pcb);
    return ERR_OK;
//static void
//   //处理错误
//    if(arg != NULL)
//        mem_free(arg);
//static err_t
//    pState = arg;
//        tcp_abort(pcb);
//    return ERR_OK;
static err_t
tAPPState *pState;
fpState=pState;
if(pState == NULL)
        return(ERR_MEM);
        //我们可以用它来发送某些数据。
        tcp_output(pcb);
        return(ERR_OK);
void
io_init(void)
int
main(void)
//   struct pbuf *p;
      if(REVISION_IS_A2)
                   SYSCTL_XTAL_8MHZ);
        io_init();
    SysTickEnable();
    SysTickIntEnable();
    IntMasterEnable();
        while(1)
