3688|7
31
CC1101 无线模块应用案子/天气预报测量产品 [复制链接]
Features:
1) USB port for easy connectio to your PC
2) All the weather data from the base station and weather history data with user
adjustable measuring intervals can be recorded and uploaded to your PC
3) Free PC software for transfer weather data to PC
4) Rainfall data (inches or millimeters): 1-hour, 24-hour,one week,one month and
total since last reset.
5) Wind chill and Dew point temperature display (°F or °C)
6)Records min. and max. wind chill and Dew point with time and date stamp
7) Wind speed (mph, m/s, km/h, knots, Beaufort)
8) Wind direction display with LCD compass
9) Weather forecast tendency arrow
10) Weather alarm modes for:
     a) Temperature
     b) Humidity
     c) Wind chill
     d) Dew point
     e) Rainfall
      f) Wind speed
     g) Air pressure
     h) Storm warning
11) Forecast icons based on changing barometric pressure
12) Barometric pressure (inHg or hPa) with 0.1hPa resolution
13) Wireless outdoor and indoor humidity (% RH)
14) Records min. and max. humidity with time and date stamp
15) Wireless outdoor and indoor temperature (° for °C)
16) Records min. and max. temperature with time and date stamp
17) Time and date manual setting
18) 12 or 24-hour time display
19) Perpetual calendar
20) Time zone setting
21) Time alarm
22) High light LED backlight
23) Wall hanging or free standing
24) Synchronized instant reception
25) Low power consumption (over 2 years battery life for transmitter)
Set includes:
1) Receiver
2) Four outdoor sensors: thermo-hydro transmitter, wind speed sensor, wind direction sensor and rain sensor
Specifications:
1) Outdoor temperature range: -40.0°C to + 65.0°C (-40°F to +149°F)
2) Indoor temperature range: 0°C to + 50.0°C (32°F to +122°F)
3) Humidity range: 10% to 99% (1% resolution)
4) Rain volume display: 0 - 9999mm (show OFL if outside range)
    Resolution : 0.3mm (if rain volume < 1000mm)
    1mm (if rain volume > 1000mm)
5) Wind speed: 0~100mph (show OFL if outside range)
6) Measuring range air pressure: 27.13inHg - 31.89inHg
   Resolution : 0.01inHg
7) Alarm duration : 120 sec
8) Transmission range up to 100m (330 feet)
9) Power consumption:
  a) Receiver: 3 x AA alkaline batteries (not included)
  b) Sensor WH7: 2 x AA alkaline batteries (not included)
10) Transmission frequency: 433MHz
很帅气的东西来顶顶哈哈哈赞一个  详情 回复 发表于 2011-3-18 17:57
这个应该就是无线温度计吧
顶顶顶
楼主看看,加上这款模块,这个无线温度表可实现1500-2000米哟
978
和我做的湿度计很像嘛。。。。
186
液晶挺好看的,不错不错,气象站级别的
186
相当厉害啊
4138
很帅气的东西来顶顶哈哈哈赞一个
31
本产品采用CC1101+PA+LNA无线模块,测试距离有1KM以上,接收数据问题。
