int main(void)
#ifdef DEBUG
debug();
#endif
/* System clocks configuration ---------------------------------------------*/
RCC_Configuration();
/* NVIC configuration ------------------------------------------------------*/
NVIC_Configuration();
/* GPIO configuration ------------------------------------------------------*/
GPIO_Configuration();
/* Configure the USART1 */
// USART_Configuration1();
// printf("\r\n USART1 print AD_value -------------------------- \r\n");
/* TIM8 Configuration */
/* Time base configuration */
// TIM_DeInit(TIM6);
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 0x19;
TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
/* TIM8 TRGO selection */
TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
/* DAC channel1 Configuration */
DAC_StructInit(&DAC_InitStructure);
DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
DAC_Init(DAC_Channel_1, &DAC_InitStructure);
/* DAC channel2 Configuration */
DAC_Init(DAC_Channel_2, &DAC_InitStructure);
/* Fill Sine32bit table */
for (Idx= 0; Idx<32; Idx++)
DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);
/* DMA2 channel3 configuration */
DMA_DeInit(DMA2_Channel3);
DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&DualSine12bit;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 32;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA2_Channel3, &DMA_InitStructure);
/* Enable DMA2 Channel3 */
DMA_Cmd(DMA2_Channel3, ENABLE);
/* Enable DAC Channel1: Once the DAC channel1 is enabled, PA.04 is
automatically connected to the DAC converter. */
DAC_Cmd(DAC_Channel_1, ENABLE);
/* Enable DAC Channel2: Once the DAC channel2 is enabled, PA.05 is
DAC_Cmd(DAC_Channel_2, ENABLE);
/* Enable DMA for DAC Channel1 */
DAC_DMACmd(DAC_Channel_1, ENABLE);
/* TIM8 enable counter */
TIM_Cmd(TIM6, ENABLE);
while (1)
/* DMA channel1 configuration ----------------------------------------------/
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; // 外设地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; // 内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; // DMA 传输方向单向
DMA_InitStructure.DMA_BufferSize = 1; // 设置DMA在传输时缓冲区的长度 word
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; // 设置DMA的外设递增模式,一个外设
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; // 设置DMA的内存递增模式
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; // 外设数据字长
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; // 内存数据字长
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; // 设置DMA的传输模式:连续不断的循环模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; // 设置DMA的优先级别
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; // 设置DMA的2个memory中的变量互相访问
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/ Enable DMA channel1 /
DMA_Cmd(DMA1_Channel1, ENABLE);
/ ADC1 configuration ------------------------------------------------------/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; // 独立工作模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE; // 扫描方式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; // 连续转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; // 外部触发禁止
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; // 数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1; // 用于转换的通道数
ADC_Init(ADC1, &ADC_InitStructure);
/ ADC1 regular channel14 configuration /
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
/ Enable ADC1 DMA /
ADC_DMACmd(ADC1, ENABLE);
/ Enable ADC1 /
ADC_Cmd(ADC1, ENABLE);
/ Enable ADC1 reset calibaration register /
ADC_ResetCalibration(ADC1);
/ Check the end of ADC1 reset calibration register /
while(ADC_GetResetCalibrationStatus(ADC1));
/ Start ADC1 calibaration /
ADC_StartCalibration(ADC1);
/ Check the end of ADC1 calibration /
while(ADC_GetCalibrationStatus(ADC1));
/ Start ADC1 Software Conversion /
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
while(1)
AD_value = ADC_GetConversionValue(ADC1);
if (ticks++ >= 900000) { / Set Clock1s to 1 every 1 second /
ticks = 0;
Clock1s = 1;
/ Printf message with AD value to serial port every 1 second /
if (Clock1s) {
Clock1s = 0;
printf("The current AD value = 0x%04X \r\n", AD_value);
main()函数中RCC配置好了
void RCC_Configuration(void)
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* Enable DMA clock */
// RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* Enable ADC1 and GPIOC clock */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
/* Enable USART1 and GPIOA clock */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
/* Enable peripheral clocks --------------------------------------------------*/
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
/* AFIO and GPIOA Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
/* DAC Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
/* TIM6 Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
程序是这样的 上面只是我这样写的
