5551|6
STM8I/O口模拟I2C所读数据不正确 [复制链接]
STM8 I/O口模拟I2C
#define I2C_ERR   0
#define I2C_CRR   1
#define  I2CDataIn  1
#define  I2CDataOut 0
#define I2C_PORT  (GPIOC)
#define I2CSCL   (GPIO_PIN_7)
#define I2CSDA   (GPIO_PIN_6)
// I2C Data input/output
// 0-Output, 1-Input
void I2CDataInOut(bool InOut)
if(InOut)
  GPIO_Init(I2C_PORT,I2CSDA,GPIO_MODE_IN_FL_NO_IT);
else
  GPIO_Init(I2C_PORT,I2CSDA,GPIO_MODE_OUT_OD_LOW_FAST);
//  Send start condition
//  ensure data is high then issue a start condition
//  see also i2c_Start() macro
void I2C_Start (void)
GPIO_WriteHigh(I2C_PORT, I2CSDA);
_delay_5us(5);
GPIO_WriteHigh(I2C_PORT, I2CSCL);
_delay_5us(5);
GPIO_WriteLow(I2C_PORT, I2CSDA);
_delay_5us(5);
//   Send stop condition
//   data low-high while clock high
void I2C_Stop (void)
_delay_5us(5);
_delay_5us(5);
//ROUTINE NAME : I2C_Ack
//INPUT/OUTPUT : None.
//DESCRIPTION  : Acknoledge generation from now.
//COMMENTS     : Transfer sequence = DATA, ACK.
void I2C_Rack(void)
_delay_5us(5);
_delay_5us(5);
GPIO_WriteLow(I2C_PORT, I2CSCL);
_delay_5us(5);
//ROUTINE NAME : I2C_nAck
//DESCRIPTION  : Non acknoledge generation from now.
//COMMENTS     : Transfer sequence = DATA, NACK.
void I2C_nAck (void)
_delay_5us(5);
_delay_5us(5);
_delay_5us(5);
//  Send a byte to the slave 写一个数据没有应答
//  return I2C_ERR OR I2C_CRR
bool SendByte(UCHAR I2cData)
UCHAR i;
bool I2CStatus;
for(i=0; i<8; i++)
  _delay_5us(5);
  if(I2cData & 0x80)
   {GPIO_WriteHigh(I2C_PORT, I2CSDA);}
  else
   {GPIO_WriteLow(I2C_PORT, I2CSDA);}
  _delay_5us(5);
  I2cData <<= 1;
  GPIO_WriteHigh(I2C_PORT, I2CSDA);//发送完一字节,接收应答
  I2CDataInOut(I2CDataIn);
  _delay_5us(5);
  if(GPIO_ReadInputPin(I2C_PORT,I2CSDA) == 0)
   I2CStatus = I2C_CRR;
  else
   I2CStatus = I2C_ERR;
  I2CDataInOut(I2CDataOut);
  return I2CStatus;
//ROUTINE NAME : I2Cm_RxData
//INPUT/OUTPUT : Last byte to receive flag (active high)/Received data byte.
//DESCRIPTION  : Receive a data byte.
//COMMENTS     : Transfer sequence = DATA, ACK, EV7...
UCHAR RcvByte(void)
    UCHAR i;
    UCHAR ReadByte=0;
_delay_5us(10);
for(i=0; i<8; i++)
   ReadByte <<= 1;
   _delay_5us(5);
   _delay_5us(5);
   if(GPIO_ReadInputPin(I2C_PORT,I2CSDA) == 1)
    {ReadByte |= 0x01;}
   _delay_5us(5);
_delay_5us(10);
   return ReadByte;
  读N个数据,参数:?
   wrDAdr: write device-address 写器件地址??
   wordAdr: word address 读数据的寄存器地址??
   rdDAdr: read device-address 读器件地址
   *pRdDat: p->read data 读数据指针
   num: number 需要读数据的个数
bool I2C_Read(UCHAR wrDAdr,UCHAR wordAdr,UCHAR *pRdDat,UCHAR num)
bool I2CAck;
UCHAR i=0;
UCHAR rdDAdr;
rdDAdr = wrDAdr+1; //读器件地址为写地址加1
I2C_Start();  /*启动I2C*/
_delay_5us(5);
I2CAck = SendByte(wrDAdr); /*发写器件地址*/
if(!I2CAck)
   return I2C_ERR;
I2CAck = SendByte(wordAdr); /*发寄存器地址*/
if(!I2CAck)
   return I2C_ERR;
I2C_Start();   /*重启I2C*/
  I2CAck = SendByte(rdDAdr); /*发读器件地址*/
if(!I2CAck)
   return I2C_ERR;
_delay_5us(5);
for(i=0;i<num-1;i++)
  *(pRdDat+i) = RcvByte();
  I2C_Rack();
if(i==num-1)
  I2C_nAck();
I2C_Stop();
return I2C_CRR;
写N个数据,前N-1个要应答,最后一个不要应答
  wordAdr: word address 写数据的寄存器地址?
  *pWrDat: p->write data 写数据指针
  num: number  需要写入的数据个数
bool I2C_Write(UCHAR wrDAdr,UCHAR wordAdr,UCHAR *pWrDat,UCHAR num)
bool I2CAck;
unsigned char i;
_delay_5us(5);
if(!I2CAck)
   return I2C_ERR;
I2CAck = SendByte(wordAdr);  /*发要写的寄存器地址*/
if(!I2CAck)
   return I2C_ERR;
  I2CAck = SendByte(*(pWrDat+i));
  if(!I2CAck)
   {return I2C_ERR;}
if(i==num-1)
  I2CAck = SendByte(*(pWrDat+num-1));
  if(!I2CAck)
   {return I2C_ERR;}
I2C_Stop();
return I2CAck;
以上代码不知为何读出数据不正确,用示波器看我发送的器件地址,寄存器地址这些都对,器件输出的数据是0xFF,程序中读出返回的数据是0x00,弄了一天没对相当郁闷,同志们指点下
此帖出自stm32/stm8论坛
                                 你去看看GPIO_ReadInputPin这个程序你就知道为什么不能这样写了,想当然的想法 是的,不看、不调试,而想当然,这种做法不太好  详情 回复 发表于 2010-5-12 09:05
                                 终于搞定了, 应该跟我的器件有关,另外if(GPIO_ReadInputPin(I2C_PORT,I2CSDA) == 1)这种不能写成==1,要直接写成if(GPIO_ReadInputPin(I2C_PORT,I2CSDA)),太郁闷了
此帖出自stm32/stm8论坛
                                 呵呵
此帖出自stm32/stm8论坛
                                 还会有2楼所说的问题。两种写法应该是一样的呀
此帖出自stm32/stm8论坛
67
                                 有些编译器是这样的,奇怪的问题
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
75
此帖出自stm32/stm8论坛
