11485|36
82
【重量级新闻】90nm工艺将STM32的性能提高到新的水平 [复制链接]
STMicroelectronics Delivers 90nm STM32 MCU with Unique Flash Accelerator for Extra Performance Boost
STM32 embedded Flash performance gets double boost with 90nm production availability and Adaptive Real-Time accelerator enabling zero-wait program execution up to 120MHz
Geneva, March 01,2010 - STMicroelectronics (NYSE: STM), a world leader in microcontrollers, has announced two significant advances that further improve the performance and power consumption of its successful STM32 family: availability of production devices featuring embedded Flash at 90nm process technology; and the industry’s first Adaptive Real-Time (ART) memory accelerator optimized for the STM32’s industry-standard ARM? Cortex?-M3 processor.
The first production STM32 microcontrollers leveraging ST’s 90nm embedded Flash technology, which is already proven in smart card and automotive ICs, deliver faster operation, increased peripheral integration, lower power consumption, and increased on-chip memory densities. ST announced it was sampling these devices in 2009.
The proprietary ART memory accelerator balances the inherent performance advantage of the ARM Cortex-M3 over Flash memory technologies, which normally requires the processor to wait for the Flash at higher operating frequencies. The CPU can now operate up to 120MHz without waiting, thereby increasing overall system speed and efficiency.
To release the processor’s full 150 DMIPS performance at this frequency the accelerator implements an instruction pre-fetch queue and branch cache, enabling program execution from Flash at up to 120MHz with zero wait states. Competing Cortex-M3 MCUs can now only outperform the STM32 by operating at frequencies above 120MHz, which will increase power consumption and heat dissipation.
With this performance now available, developers can host extra elements of a system on the microcontroller, saving the need to use a more expensive microcontroller or a companion DSP. An example is in ** applications, where customers will be able to implement an audio codec, video processing functions, data encryption, digital filtering, and a multi-protocol gateway, with sufficient remaining resources to manage other tasks.
The latest STM32 variants benefiting from the 90nm process and the ART memory accelerator have been verified according to CoreMark? tests created by the Embedded Microprocessor Benchmark Consortium. CoreMark results verify the STM32 executes 8% faster than Cortex-M competitors at 100MHz clock speed. The performance advantage is greater still at 120MHz. CoreMark analysis also confirms dynamic power consumption of only 188?A/MHz (98?A/CoreMark). This is equivalent to drawing 22.5mA at 120MHz (executing from Flash memory, with ART accelerator enabled and all peripherals off).
The new 90nm devices featuring the ART memory accelerator are sampling at lead customers. Product details will be announced later this year.
About the STM32 family
The enhancements announced today extend the advantages of the industry’s most extensive Cortex-M3 microcontroller portfolio, which now includes over 110 devices. All STM32 family members are pin-to-pin and software compatible, and share from a common pool of peripherals to facilitate design scalability and efficient, platform-based product development.
Available STM32 product lines now include the STM32 Value Line, STM32 Access Line, and STM32 Performance Line. Additional enhancements include the STM32 Access USB Line featuring additional connectivity and the STM32 Connectivity Line supporting USB OTG, Ethernet and dual CAN interfaces. On-chip Flash densities range from 16Kbytes to 1Mbyte, SRAM densities from 4KBytes to 96KBytes, and surface-mount package styles from 36-pin QFN to 144-pin LQFP or BGA packages. High-performance on-chip peripherals span interface, conversion, timing, and supervisory features including watchdog and reset functions.
此帖出自stm32/stm8论坛
jwj
                                 希望早点看到这些芯片的应用产品  详情 回复 发表于 2010-4-29 10:17
                                 传说中的stm32F20x ?
此帖出自stm32/stm8论坛
禁止访问
提示: 作者被禁止或删除 内容自动屏蔽
83
20x要来了?
还是先把现在的货源弄稳定了吧
此帖出自stm32/stm8论坛
                                 STM32F205的USB接口传说中是HS的
此帖出自stm32/stm8论坛
65
                                 120M 不等待。。。。。。
此帖出自stm32/stm8论坛
120MHz零等待,实际性能应该是103系列(72MHz俩等待)的2倍以上。
ST终于承认加等待周期对实际性能的影响不小呵呵,不过改进了还后来居上还是好同志。
此帖出自stm32/stm8论坛
“CoreMark results verify the STM32 executes 8% faster than Cortex-M competitors at 100MHz clock speed. The performance advantage is greater still at 120MHz”
这一段估计是不点名跟NXP的CortexM3对比。
此帖出自stm32/stm8论坛
78
                                 现有的72M 103系列将来会全部升级到120M么?
此帖出自stm32/stm8论坛
62
                                 120M。OK.
此帖出自stm32/stm8论坛
90
ST终于承认加等待周期对实际性能的影响不小呵呵,不过改进了还后来居上还是好同志。 ...
zhjerry 发表于 2010-3-4 08:55
此帖出自stm32/stm8论坛
84
100MHZ吧。 2810早就是了,
150MHZ吧,2812 ..
200HZ....
此帖出自stm32/stm8论坛
                                 支持新品,但速度仅仅是一个方面!
此帖出自stm32/stm8论坛
81
                                 很多时候有了速度,才有大幅度提高其他性能的前提,
此帖出自stm32/stm8论坛
传说中的stm32F20x ?
不再是传说了,Keil 4.1中已经有203,205,207了,估计今年会量产。
看 207ZG
ARM 32-bit Cortex-M3 Microcontroller, 120MHz, 1MB Flash, 128kB SRAM,
PLL, Embedded Internal RC 16MHz and 32kHz, Real-Time Clock,
Nested Interrupt Controller, Power Saving Modes, JTAG and SWD, 16-ch DMA,
up to 12 16-bit & 2 32-bit timers, with up to 4 IC/OC/PWM or pulse counter
and quadrature (incremental) encoder input, 10/100 Ethernet MAC with dedicated DMA, 8- to 14-bit parallel camera interface, cryptographic acceleration,
3 SPI/I2S, 3 I2C, 6 USART, USB 2.0 full-speed & high-speed device/host/OTG,
2 CAN 2.0B Active, 3 12-bit 24-ch A/D Converter, 12-bit 2-ch D/A Converter,
SDIO, Fast I/O Ports
此帖出自stm32/stm8论坛
66
丫丫的,终于等到这一天了
从nxp的lpc21xx开始就不爽访问flash要插等待
多少年了啊~~~
此帖出自stm32/stm8论坛
93
看 207ZG
PLL, Embedded Internal RC 16MHz and 32kHz, Real-Time Cloc ...
看上去207是103、107的集大成。
此帖出自stm32/stm8论坛
79
                                 支持新品
此帖出自stm32/stm8论坛
                                 英文,看了半天
此帖出自stm32/stm8论坛
78
                                 速度是个很关键的指标
此帖出自stm32/stm8论坛
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
