6426|7
串口不能进中断?但是查询模式正常 [复制链接]
现象:使用查询模式能够实现正常收发,使用串口中断时,没有中断时,在主程序循环中正常运行,如果收到字符,不是跳到USART1_IRQHandler,而是跳到了 HardFaultException中断,可能是哪里的原因,如果说硬件有问题,可查询模式很正常。请高手给指点一下,问题在哪,估计很低级,因为在下是新手。
相关的程序如下:(也是从21ic上下的一个成功的,几乎没有修改)
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
// Enable the USART1 gloabal Interrupt
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
/* USART1 configuration ------------------------------------------------------*/
  /* USART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
void USART1_Configuration(void)
  USART_InitTypeDef USART_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Enable USART1 clocks */
  //RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
  /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART1 Rx (PA.10) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  USART_InitStructure.USART_BaudRate = 19200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* Configure the USART1 */
  USART_Init(USART1, &USART_InitStructure);
/* Enable the USART Receive interrupt: this interrupt is generated when the
   USART1 receive data register is not empty */
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Enable USART1 */
  USART_Cmd(USART1, ENABLE);
  USART_ClearFlag(USART1,USART_FLAG_TXE);
int main(void)
u8 i;
#ifdef DEBUG
  debug();
#endif
   /* Configure the system clocks */
   RCC_Configuration();
   /* NVIC Configuration */
   NVIC_Configuration();
   /* Configure the GPIOs */
   GPIO_Configuration();
   USART1_Configuration();
/* Configure the SPI2 */
//SPI_Configuration();
while(1)
  //串口和GPIO测试
  if(USART_GetFlagStatus(USART1,USART_IT_RXNE)==SET)
   i = USART_ReceiveData(USART1);
   USART_SendData(USART1, i+1);
   //Spk_on(ENABLE);
   Delay(10000);
   //Spk_on(DISABLE);
  i++;
* Function Name  : HardFaultException
* Description    : This function handles Hard Fault exception.
* Input          : None
* Output         : None
* Return         : None
void HardFaultException(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
* Function Name  : USART1_IRQHandler
* Description    : This function handles USART1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART1_IRQHandler(void)
   u8 i;
   if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)
   if(USART_GetITStatus(USART1,USART_IT_RXNE)!= RESET)
      USART_ClearITPendingBit(USART1, USART_IT_RXNE);
      //接收数据在以下地点加代码
此帖出自stm32/stm8论坛
                                 我的能中断,但是程序一开始就进入中断,但是不知道是哪个中断,因为程序运行不了串口中断函数以外的代码!我没有仿真器,郁闷中!  详情 回复 发表于 2010-4-2 21:50
除了串口的中断外,其它中断能用吗?看现象像是中断向量没找到,有可能是楼主的程序把中断向量表映射错了。在flash里运行的程序,中断向量也要映射到flash。函数NVIC_Configuration有这么一段:
#ifdef  VECT_TAB_RAM
#endif
楼主可以搜索一下你的工程里是否定义了VECT_TAB_RAM ,如果定义了,这段程序就会把中断向量映射到RAM, 而RAM里并没有实际的中断向量,发生中断之后就会fault了。
此帖出自stm32/stm8论坛
63
                                 如果查询可以,那肯定是你的中断没有配置好
此帖出自stm32/stm8论坛
66
                                 串口时钟是否打开
此帖出自stm32/stm8论坛
75
注意,不同型号的MCU中断向量地址不同,详细的请参考相应的数据手册。
别人的现成的程序是根据他们的mcu指定的。
切记!
此帖出自stm32/stm8论坛
                                 感谢指点,我得出结果后马上向各位老大回报!
此帖出自stm32/stm8论坛
88
                                 仿真下,首先看能不能进中断再说
此帖出自stm32/stm8论坛
77
此帖出自stm32/stm8论坛
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
