4353|3
79
请教牛人:如何使用stm32的两路ADC [复制链接]
stm32中有3个ADC模块,我们使用ADC1的设置如下:
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐,最大为4095
  ADC_InitStructure.ADC_NbrOfChannel = 8;
  ADC_Init(ADC1, &ADC_InitStructure);
  //使能温度和参考
  ADC_TempSensorVrefintCmd(ENABLE);
  /* ADC1 regular channel14 configuration *///对应图上#33
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_7Cycles5);//ADC_Channel_14
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 2, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 3, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 4, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 6, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 7, ADC_SampleTime_7Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 8, ADC_SampleTime_7Cycles5);
想请教的是:这块设置因为功能需要不能改动,可不可以在使用上述设置的同时,用stm32的另外的ADC模块实现对其他4路模拟信号的循环监测?
此帖出自stm32/stm8论坛
                                 DMA-ADC配置如下: DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;   DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;   DMA_InitStructure.DMA_BufferSize = 80;//40sample为1半   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;   DMA_InitStructure.DMA_Priority = DMA_Priority_High;   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;   DMA_Init(DMA1_Channel1, &DMA_InitStructure);   DMA_ITConfig(DMA1_Channel1,DMA_IT_TE,DISABLE);   DMA_ITConfig(DMA1_Channel1,DMA_IT_HT|DMA_IT_TC,ENABLE);      /* 允许DMA1------------------------------------------*/   DMA_Cmd(DMA1_Channel1,ENABLE);         //ADC clock 8MHz   ADC_InitTypeDef ADC_InitStructure;//stm_adc.h   ADC_InitTypeDef ADC_InitStructure1;   ADC_DeInit(ADC1);   /* ADC1 configuration ------------------------------------------------------*/   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;   ADC_InitStructure.ADC_ScanConvMode = ENABLE;   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右对齐,最大为4095   ADC_InitStructure.ADC_NbrOfChannel = 8;   ADC_Init(ADC1, &ADC_InitStructure);   //使能温度和参考   ADC_TempSensorVrefintCmd(ENABLE);   /* ADC1 regular channel14 configuration *///对应图上#33   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_7Cycles5);//ADC_Channel_14   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 2, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 3, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 4, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 6, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 7, ADC_SampleTime_7Cycles5);   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 8, ADC_SampleTime_7Cycles5);   /* Enable ADC1 DMA */   ADC_DMACmd(ADC1, ENABLE);//stm_adc.c   /* Enable ADC1 */   ADC_Cmd(ADC1, ENABLE);   /* Enable ADC1 reset calibaration register */   ADC_ResetCalibration(ADC1);   /* Check the end of ADC1 reset calibration register */   while(ADC_GetResetCalibrationStatus(ADC1));   /* Start ADC1 calibaration */   ADC_StartCalibration(ADC1);   /* Check the end of ADC1 calibration */   while(ADC_GetCalibrationStatus(ADC1));   /* Enable DMA1 channel1 */   DMA_Cmd(DMA1_Channel1, ENABLE);   /* Start ADC1 Software Conversion */   ADC_SoftwareStartConvCmd(ADC1, ENABLE);  详情 回复 发表于 2010-3-5 11:15
83
                                 意思就是可不可以使用stm32的两块ADC,一块用于上述功能,而另一块用于别的功能?他们之间不能有干扰
此帖出自stm32/stm8论坛
                                 不知道你DMA那是怎么配置的
此帖出自stm32/stm8论坛
62
DMA-ADC配置如下:
  //ADC clock 8MHz
  ADC_DeInit(ADC1);
  //使能温度和参考
  /* Enable ADC1 */
此帖出自stm32/stm8论坛
