8002|13
61
等时间间隔采样问题 [复制链接]
这是我想的一个方法来实现等时间进行采样。希望高手指点更好的方法
AD设置()
频率设置
转化结束产生中断
单次转换
单通道
定时器设置()
定时19.531 us//1024个点
定时中断开
定时中断()
启动AD转换;
等待转换结束;
将转换结果保存起来;
N+1// 记录转换次数
AD采样函数()
启动定时器TIM2
等待1024次定时中断;
IfN=1024
关闭定时器2
N=0
此帖出自stm32/stm8论坛
                                 /**   ******************************************************************************   * @file    ADC/TIMTrigger_AutoInjection/main.c   * @author  MCD Application Team   * @version V3.1.2   * @date    09/28/2009   * @brief   Main program body   ******************************************************************************   * @copy   *   * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS   * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE   * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY   * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING   * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE   * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.   *   * <h2><center>&copy; COPYRIGHT 2009 STMicroelectronics</center></h2>   */ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" /** @addtogroup STM32F10x_StdPeriph_Examples   * @{   */ /** @addtogroup ADC_TIMTrigger_AutoInjection   * @{   */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ #define ADC1_DR_Address    ((uint32_t)0x4001244C) /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ ADC_InitTypeDef           ADC_InitStructure; DMA_InitTypeDef           DMA_InitStructure; TIM_TimeBaseInitTypeDef   TIM_TimeBaseStructure; TIM_OCInitTypeDef         TIM_OCInitStructure; __IO uint16_t ADC_RegularConvertedValueTab[32], ADC_InjectedConvertedValueTab[32]; ErrorStatus HSEStartUpStatus;     /* Private function prototypes -----------------------------------------------*/ void RCC_Configuration(void); void GPIO_Configuration(void); void NVIC_Configuration(void);    /* Private functions ---------------------------------------------------------*/ /**   * @brief   Main program   * @param  None   * @retval None   */ int main(void) {   /* System clocks configuration ---------------------------------------------*/   RCC_Configuration();   /* NVIC configuration ------------------------------------------------------*/   NVIC_Configuration();   /* GPIO configuration ------------------------------------------------------*/   GPIO_Configuration();   /* TIM1 configuration ------------------------------------------------------*/   /* Time Base configuration */   TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);   TIM_TimeBaseStructure.TIM_Period = 0xFF;            TIM_TimeBaseStructure.TIM_Prescaler = 0x4;         TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;      TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;     TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);   /* TIM1 channel1 configuration in PWM mode */   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;                  TIM_OCInitStructure.TIM_Pulse = 0x7F;   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;            TIM_OC1Init(TIM1, &TIM_OCInitStructure);   /* DMA1 Channel1 Configuration ----------------------------------------------*/   DMA_DeInit(DMA1_Channel1);   DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_RegularConvertedValueTab;   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;   DMA_InitStructure.DMA_BufferSize = 32;   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;   DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;   DMA_InitStructure.DMA_Priority = DMA_Priority_High;   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;   DMA_Init(DMA1_Channel1, &DMA_InitStructure);      /* Enable DMA1 channel1 */   DMA_Cmd(DMA1_Channel1, ENABLE);   /* ADC1 configuration ------------------------------------------------------*/   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;   ADC_InitStructure.ADC_ScanConvMode = DISABLE;   ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;   ADC_InitStructure.ADC_NbrOfChannel = 1;   ADC_Init(ADC1, &ADC_InitStructure);   /* ADC1 regular channel14 configuration */   ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_13Cycles5);   /* Set injected sequencer length */   ADC_InjectedSequencerLengthConfig(ADC1, 1);   /* ADC1 injected channel Configuration */   ADC_InjectedChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_71Cycles5);   /* ADC1 injected external trigger configuration */   ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);   /* Enable automatic injected conversion start after regular one */   ADC_AutoInjectedConvCmd(ADC1, ENABLE);   /* Enable ADC1 DMA */   ADC_DMACmd(ADC1, ENABLE);   /* Enable ADC1 external trigger */   ADC_ExternalTrigConvCmd(ADC1, ENABLE);   /* Enable JEOC interupt */   ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);   /* Enable ADC1 */   ADC_Cmd(ADC1, ENABLE);   /* Enable ADC1 reset calibaration register */      ADC_ResetCalibration(ADC1);   /* Check the end of ADC1 reset calibration register */   while(ADC_GetResetCalibrationStatus(ADC1));   /* Start ADC1 calibaration */   ADC_StartCalibration(ADC1);   /* Check the end of ADC1 calibration */   while(ADC_GetCalibrationStatus(ADC1));   /* TIM1 counter enable */   TIM_Cmd(TIM1, ENABLE);   /* TIM1 main Output Enable */   TIM_CtrlPWMOutputs(TIM1, ENABLE);     /* Test on channel1 transfer complete flag */   while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));   /* Clear channel1 transfer complete flag */   DMA_ClearFlag(DMA1_FLAG_TC1);   /* TIM1 counter disable */   TIM_Cmd(TIM1, DISABLE);   while (1)   {   } } /**   * @brief  Configures the different system clocks.   * @param  None   * @retval None   */ void RCC_Configuration(void) { /* RCC system reset(for debug purpose) */   RCC_DeInit();   /* Enable HSE */   RCC_HSEConfig(RCC_HSE_ON);   /* Wait till HSE is ready */   HSEStartUpStatus = RCC_WaitForHSEStartUp();   if(HSEStartUpStatus == SUCCESS)   {     /* Enable Prefetch Buffer */     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);     /* Flash 2 wait state */     FLASH_SetLatency(FLASH_Latency_2);             /* HCLK = SYSCLK */     RCC_HCLKConfig(RCC_SYSCLK_Div1);        /* PCLK2 = HCLK */     RCC_PCLK2Config(RCC_HCLK_Div1);     /* PCLK1 = HCLK/2 */     RCC_PCLK1Config(RCC_HCLK_Div2);     /* ADCCLK = PCLK2/4 */     RCC_ADCCLKConfig(RCC_PCLK2_Div4);    #ifndef STM32F10X_CL       /* PLLCLK = 8MHz * 7 = 56 MHz */     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_7); #else     /* Configure PLLs *********************************************************/     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */     RCC_PREDIV2Config(RCC_PREDIV2_Div5);     RCC_PLL2Config(RCC_PLL2Mul_8);     /* Enable PLL2 */     RCC_PLL2Cmd(ENABLE);     /* Wait till PLL2 is ready */     while (RCC_GetFlagStatus(RCC_FLAG_PLL2RDY) == RESET)     {}     /* PLL configuration: PLLCLK = (PLL2 / 5) * 7 = 56 MHz */     RCC_PREDIV1Config(RCC_PREDIV1_Source_PLL2, RCC_PREDIV1_Div5);     RCC_PLLConfig(RCC_PLLSource_PREDIV1, RCC_PLLMul_7); #endif     /* Enable PLL */     RCC_PLLCmd(ENABLE);     /* Wait till PLL is ready */     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)     {     }     /* Select PLL as system clock source */     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);     /* Wait till PLL is used as system clock source */     while(RCC_GetSYSCLKSource() != 0x08)     {     }   }    /* Enable peripheral clocks --------------------------------------------------*/   /* Enable DMA1 clock */   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);   /* Enable GPIOA, GPIOC, ADC1 and TIM1 clock */   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC |                          RCC_APB2Periph_ADC1 | RCC_APB2Periph_TIM1, ENABLE); } /**   * @brief  Configures the different GPIO ports.   * @param  None   * @retval None   */ void GPIO_Configuration(void) {   GPIO_InitTypeDef GPIO_InitStructure;   /* Configure TIM1_CH1 (PA8) as alternate function push-pull */   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   GPIO_Init(GPIOA, &GPIO_InitStructure);   /* Configure PC.06 as output push-pull */   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   GPIO_Init(GPIOC, &GPIO_InitStructure);   /* Configure PC.01 and PC.04 (ADC Channel11 and Channel14) as analog input */   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;   GPIO_Init(GPIOC, &GPIO_InitStructure); } /**   * @brief  Configures NVIC and Vector Table base location.   * @param  None   * @retval None   */ void NVIC_Configuration(void) {   NVIC_InitTypeDef NVIC_InitStructure;   /* Enable ADC1_2 IRQChannel */   NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   NVIC_Init(&NVIC_InitStructure); }  详情 回复 发表于 2010-1-15 12:51
78
                                 用定时器是很容易实现等时采样,但是你始终没有关闭过A/D采样,也就是说一直在采样,定时器只是等时取值
此帖出自stm32/stm8论坛
定时19.531 us
st的定时可以达到这个精度否??
直接搞20us算了
此帖出自stm32/stm8论坛
59
不必使用定时中断,然后在中断中采样。
可以直接用定时器触发ADC转换,再由ADC触发DMA传送,在1024次传送完成时产生中断,一次性处理1024个采样结果。
楼主的要求是每20ms的一个周期中,均匀地采样1024次,如果使用72MHz的时钟,则设置定时器的定时周期为1406时钟周期,可以达到要求的精度;3楼多虑了,
此帖出自stm32/stm8论坛
66
才开始学习使用stm32 。 现在用stm32做项目   要用其来进行采样
  ad软件启动是不是ADC_SoftwareStartConvCmd(ADC1, ENABLE); 这个函数
针对四楼的香水城  道理明白但不晓得怎么来弄   望指教!QQ:783055156
此帖出自stm32/stm8论坛
STM32的固件库中有一个例子,你稍微修改一下就可以用:
STM32F10x_StdPeriph_Lib_V3.1.2\Project\STM32F10x_StdPeriph_Examples\ADC\TIMTrigger_AutoInjection
此帖出自stm32/stm8论坛
                                 由定时器触发A/D,虽然经常看到这种用法,但自己一直没这样用过
此帖出自stm32/stm8论坛
这个函数库我没有只有v2.0的库能否发个例子程序  给我  谢谢783055156@qq.com
此帖出自stm32/stm8论坛
59
                                 请自行在ST网站下载,网页地址在我的签名中。
此帖出自stm32/stm8论坛
                                 我也下下来学习下
此帖出自stm32/stm8论坛
82
我查看了几遍 库函数  和固件库手册 还是没有明白  ad软件启动的开关 是ADC_Cmd(adc1,enable)
还是ADC_SoftwareStartConvCmd(ADC1, enable);请指教
此帖出自stm32/stm8论坛
81
                                 我觉得用定时器触发A/D中断挺好的
此帖出自stm32/stm8论坛
                                 自己下载呗
此帖出自stm32/stm8论坛
81
  * @version V3.1.2
  * @date    09/28/2009
  * @copy
  * @param  None
  * @retval None
int main(void)
  /* Enable ADC1 */
  while (1)
  * @param  None
  * @retval None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
#else
    /* Enable PLL2 */
#endif
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
  * @param  None
  * @retval None
  * @param  None
  * @retval None
此帖出自stm32/stm8论坛
