4871|9
78
STM32串口收数后回发时出现问题 [复制链接]
while (1)
    if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
  GPIO_ResetBits(GPIOB, GPIO_Pin_9);
      j = USART_ReceiveData(USART3);
      while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
  GPIO_SetBits(GPIOB, GPIO_Pin_9);
  USART_SendData(USART3,j);
上面程序我是接收上位机发过来的一个字节,之后把这个字节发回到上位机,运行时我用串口大师发数,但是数不能正常发回,会周期性的每过大约3秒时自动向上位机发一个0,不知道是何原因。处理器是STM32VBT6.接口芯片是ADUM5401和SN75LBC184,ADUM5401是隔离用的,SN75LBC184是半又工的收发器。(GPIOB, GPIO_Pin_9)是控制收发方向的。
此帖出自stm32/stm8论坛
                                 不用中断,只在主程序中用查询方式接收后再发回到上位机,也不行,现象和用中断是一样的。只能收发一次,之后就不能收发了。请高手帮忙指点一下。先谢谢各位了。  详情 回复 发表于 2009-12-21 16:54
77
发数是没有问题的,应该是数据没有收到,什么原因呢?
  /* Configure USART3 Tx (PB10) as alternate function push-pull */
  //注意此引脚对应原理图中的网络"TXD2"
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* Configure USART3 Rx (PB11) as input floating */
   //注意此引脚对应原理图中的网络"RXD2"
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  USART_Init(USART3, &USART_InitStructure);
  USART_ClockInit(USART3, &USART_ClockInitStructure);
  //Enable the USART Receive interrupt: this interrupt is generated when the
  //USART1 receive data register is not empty
  USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
//USART_ITConfig(USART3, USART_IT_TXE, ENABLE);
//USART_ITConfig(USART3, USART_IT_TXE, DISABLE);
  /* Enable USART3 */
  USART_Cmd(USART3, ENABLE);
此帖出自stm32/stm8论坛
86
                                 硬件上作了些改动。现在用COMMET能收能发。用串口大师只能收发一次,之后就不行了。要再复位才能再收发一次。不知道是怎么回事。请高手指点一下。
此帖出自stm32/stm8论坛
83
                                 就是说只能跑一遍,肯定是程序死在哪了,我碰到过,你仿真查查
此帖出自stm32/stm8论坛
84
                                 仿真不了。我是用ISP下载的。
此帖出自stm32/stm8论坛
77
                                 哦,那就不好查了,只能认真看程序
此帖出自stm32/stm8论坛
59
                                 仿真不了,对于调试程序是很不方便
此帖出自stm32/stm8论坛
                                 是啊。是不方便,现在不知道程序死在哪儿了,感觉好像没死似的,因为我复位后第一次点发送能正确的返回正确的值,之后就不行了。但是之后每过大约2秒会自动向上位机发个0.
此帖出自stm32/stm8论坛
79
                                 是不是USART3的接收中断我只进了一次呢?好像网上也有人遇到过这样的问题,但不知道咋整好的。
此帖出自stm32/stm8论坛
54
此帖出自stm32/stm8论坛
【直播时间】5月28日(周三)上午10:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
