4600|6
66
STM8SI/O口中断有问题! [复制链接]
定义:GPIO_Init(PORT_D, GPIO_PIN_7, GPIO_MODE_IN_PU_IT);
EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOD, EXTI_SENSITIVITY_FALL_ONLY);
@near @interrupt void EXTI_PORTD_IRQHandler (void)中始终产生不了中断?
难道资料有误还是芯片有问题?
此帖出自stm32/stm8论坛
                                 PD7是TLI中断  详情 回复 发表于 2009-11-2 22:54
77
                                 用过STM8S105的中断,没问题。看一下反汇编及初始化完的寄存器
此帖出自stm32/stm8论坛
75
                                 中断向量地址填写了没?
此帖出自stm32/stm8论坛
75
中断向量地址:
(void @near (*)())0x8200,
  _stext, /* RESET */
  TRAP_IRQHandler, /* TRAP - Software interrupt */
  TLI_IRQHandler, /* irq0 - External Top Level interrupt (TLI) */
  AWU_IRQHandler, /* irq1 - Auto Wake Up from Halt interrupt */
  CLK_IRQHandler, /* irq2 - Clock Controller interrupt */
  EXTI_PORTA_IRQHandler, /* irq3 - External interrupt 0 (GPIOA) */
  EXTI_PORTB_IRQHandler, /* irq4 - External interrupt 1 (GPIOB) */
  EXTI_PORTC_IRQHandler, /* irq5 - External interrupt 2 (GPIOC) */
  EXTI_PORTD_IRQHandler, /* irq6 - External interrupt 3 (GPIOD) */
  EXTI_PORTE_IRQHandler, /* irq7 - External interrupt 4 (GPIOE) */
  CAN_RX_IRQHandler, /* irq8 - CAN Rx interrupt */
  CAN_TX_IRQHandler, /* irq9 - CAN Tx/ER/SC interrupt */
  SPI_IRQHandler, /* irq10 - SPI End of transfer interrupt */
  TIM1_UPD_OVF_TRG_BRK_IRQHandler, /* irq11 - TIM1 Update/Overflow/Trigger/Break interrupt */
  TIM1_CAP_COM_IRQHandler, /* irq12 - TIM1 Capture/Compare interrupt */
  TIM2_UPD_OVF_BRK_IRQHandler, /* irq13 - TIM2 Update/Overflow/Break interrupt  */
  TIM2_CAP_COM_IRQHandler, /* irq14 - TIM2 Capture/Compare interrupt */
  TIM3_UPD_OVF_BRK_IRQHandler, /* irq15 - TIM3 Update/Overflow/Break interrupt */
  TIM3_CAP_COM_IRQHandler, /* irq16 - TIM3 Capture/Compare interrupt */
  UART1_TX_IRQHandler, /* irq17 - UART1 Tx complete interrupt */
  UART1_RX_IRQHandler, /* irq18 - UART1 Rx interrupt */
  I2C_IRQHandler, /* irq19 - I2C interrupt */
  UART2_TX_IRQHandler, /* irq20 - UART2/UART3 Tx interrupt */
  UART2_RX_IRQHandler, /* irq21 - UART2/UART3 Rx interrupt */
  ADC2_IRQHandler, /* irq22 - ADC1/ADC2 end of conversion interrupt */
  TIM4_UPD_OVF_IRQHandler, /* irq23 - TIM4 Update/Overflow interrupt */
  EEPROM_EEC_IRQHandler, /* irq24 - FLASH interrupt */
  NonHandledInterrupt, /* irq25 - Reserved */
  NonHandledInterrupt, /* irq26 - Reserved */
  NonHandledInterrupt, /* irq27 - Reserved */
  NonHandledInterrupt, /* irq28 - Reserved */
  NonHandledInterrupt, /* irq29 - Reserved */
这个还有问题吗?
此帖出自stm32/stm8论坛
                                 怎么没人回复?
此帖出自stm32/stm8论坛
                                 解决了,问题的PD7是没有中断的,只有TIME1的中断
此帖出自stm32/stm8论坛
84
                                 PD7是TLI中断
此帖出自stm32/stm8论坛
