6639|10
77
拜托版主能不能给个STM32的pwm捕获的例程? [复制链接]
                                 拜托版主能不能给个STM32的pwm捕获的例程?我整了很久了就是测不出来
此帖出自stm32/stm8论坛
                                 谢谢各位的提醒, 很抱歉我刚开始学习STM32不知道官网上有例程 我的问题好像解决了  详情 回复 发表于 2009-10-30 11:07
                                 STM32固件库中有PWM输入模式的例子。
此帖出自stm32/stm8论坛
82
                                 不好意思,没有找到
此帖出自stm32/stm8论坛
83
                                 没有找到固件库?还是没有找到例子?
此帖出自stm32/stm8论坛
                                 没找到例子
此帖出自stm32/stm8论坛
65
下面是我的程序,我要测量输入PWM的频率是50Hz,你看看有什么问题吗?
void tim2_config(void)
   TIM_DeInit(TIM2);
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
   TIM_BaseInitStructure.TIM_Period = 65535;       //ARR
   TIM_BaseInitStructure.TIM_Prescaler = 199;      //PSC
   TIM_BaseInitStructure.TIM_ClockDivision = 0;
   TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
   TIM_TimeBaseInit(TIM2, &TIM_BaseInitStructure);
   TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
   TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
   TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
   TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
   TIM_ICInitStructure.TIM_ICFilter = 0x0;
   TIM_PWMIConfig(TIM2, &TIM_ICInitStructure);
   TIM_SelectInputTrigger(TIM2, TIM_TS_TI2FP2);        /* Select the TIM2 Input Trigger: TI2FP2 */
   TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);                       //复位模式为从模式
   TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);          //使能主从模式
   TIM_Cmd(TIM2, ENABLE);                           //使能TIM2计数器
   TIM_ITConfig(TIM2, TIM_IT_CC2, ENABLE);          //使能CC2中断请求
void TIM2_IRQHandler(void)
  /* Clear TIM2 Capture compare interrupt pending bit */
  TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
  /* Get the Input Capture value */
  IC2Value = TIM_GetCapture2(TIM2);
* Function Name   : NVIC_Configuration
* Description        : Configures NVIC and Vector Table base location.
* Input                    : None
* Output                 : None
* Return                 : None
void NVIC_Configuration(void)
  // NVIC_InitTypeDef NVIC_InitStructure;
        #ifdef   VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
        NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
        #else   /* VECT_TAB_FLASH   */
/* Set the Vector Table base location at 0x08000000 */
        NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
        #endif
   /* Configure the NVIC Preemption Priority Bits */
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
   /* Enable the USART1 Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
此帖出自stm32/stm8论坛
88
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  /* TIM2 configuration: PWM Input mode ------------------------
     The external signal is connected to TIM2 CH2 pin (PA.01),
     The Rising edge is used as active edge,
     The TIM2 CCR2 is used to compute the frequency value
     The TIM2 CCR1 is used to compute the duty cycle value
  /* Select the slave Mode: Reset Mode */
  /* Enable the Master/Slave Mode */
  /* TIM enable counter */
  /* Enable the CC2 Interrupt Request */
  while (1);
这个是官方例子上的,没有进行Base的初始化
下面是中断处理函数
  if (IC2Value != 0)
    /* Duty cycle computation */
    DutyCycle = (TIM_GetCapture1(TIM2) * 100) / IC2Value;
    /* Frequency computation */
    Frequency = 72000000 / IC2Value;
  else
    DutyCycle = 0;
    Frequency = 0;
此帖出自stm32/stm8论坛
66
谢谢各位的回答
我的程序跟你的没什么区别,不知道为什么测的一直都是0
不知楼上的可不可以把官方的例子打包发一下?
此帖出自stm32/stm8论坛
官方例子下载处:
http://www.st.com/mcu/familiesdocs-110.html
此帖出自stm32/stm8论坛
楼主真是的,开口就要程序,STM32例程网上多着呢,自已就不勤快找一下,其实找资料的过程中也能有很多意外的收获的。
什么事情都找版主,版主都成大家保姆了,我想版主回答这样的问题会觉得很没意思。
此帖出自stm32/stm8论坛
75
谢谢各位的提醒,
我的问题好像解决了
此帖出自stm32/stm8论坛
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
