5844|6
2个SPI都用从模式,共用一个外部时钟源,能实现同步发送吗 [复制链接]
                                 2个SPI都用从模式,共用一个外部时钟源,发送同样的内容,使用DMA,我用示波器看了下,开始的时候2路波形是同步的,但是过了一段时间,SPI2的波形会比SPI1延后1个比特,而且时间越长,2路波形的相位差还会增大,不知道能否让这两路SPI一直同步?外部时钟是6MHz
此帖出自stm32/stm8论坛
                                 int main(void){  #ifdef DEBUG  debug();#endif  RCC_Configuration();  NVIC_Configuration();  GPIO_Configuration();  DMA_Configuration();  SPI_Configuration();  while (1)  {  }}其中SPI设置和DMA设置如下:void SPI_Configuration(void){  SPI_InitTypeDef SPI_InitStructure;  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;  SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;    SPI_Init(SPI1, &SPI_InitStructure);  SPI_Init(SPI2, &SPI_InitStructure);  SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);           SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);    SPI_Cmd(SPI1, ENABLE);   SPI_Cmd(SPI2, ENABLE);}void DMA_Configuration(void){  DMA_InitTypeDef DMA_InitStructure    ;  DMA_DeInit(DMA1_Channel3);  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI1_DR_Address;  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)buff;  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;         DMA_InitStructure.DMA_BufferSize = buffsize;  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  DMA_Init(DMA1_Channel3, &DMA_InitStructure);  DMA_DeInit(DMA1_Channel5);  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI2_DR_Address;  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)buff;  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;  DMA_InitStructure.DMA_BufferSize = buffsize;  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  DMA_InitStructure.DMA_Priority = DMA_Priority_High;  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  DMA_Init(DMA1_Channel5, &DMA_InitStructure);   DMA_Cmd(DMA1_Channel3, ENABLE);  DMA_Cmd(DMA1_Channel5, ENABLE);}信号线不到15cm,时钟信号是用另一个STM32的SPI产生的。今天测了下,用全双工模式还是会有不同步的情况,昨天只是巧合,跟双线单线无关。现在同步一般都能持续20分钟以上,如果程序没问题的话,可能真的是有某些干扰造成的   详情 回复 发表于 2008-11-26 15:32
一段时间是多长时间?
能大概说一下吗?
DMA触发是什么?TxE?
此帖出自stm32/stm8论坛
请楼主把外部时钟频率减到3MHz以下试试
此帖出自stm32/stm8论坛
88
能否贴出你的代码
你的程序中,当进行SPI通讯时Cortex-M3内核在进行什么操作?
另外能否贴出一张你用示波器截取的图片。
此帖出自stm32/stm8论坛
改了下SPI设置
改了下SPI设置,原来用的是SPI_Direction_1Line_Tx,现在改用SPI_Direction_2Lines_FullDuplex,目前2路SPI一直同步,没出现过相位差。
不过我搞不懂为什么单线只发送模式就不行
此帖出自stm32/stm8论坛
你的现象比较奇怪,请问你的SPI信号线又多长?会不会有干
我们计算过,即使时钟是6MHz甚至再快些,也不会来不及。
如果可能请把你的程序发出来。
此帖出自stm32/stm8论坛
87
程序如下
int main(void)
#ifdef DEBUG
  debug();
#endif
  while (1)
其中SPI设置和DMA设置如下:
此帖出自stm32/stm8论坛
