8775|8
86
SCB->HFSR的32个位都代表什么意义?怎么没找到说明呢? [复制链接]
此帖出自stm32/stm8论坛
在core_cm3.h中有定义 typedef struct {   __I  uint32_t CPUID;                   /*!< Offset: 0x000 (R/ )  CPUID Base Register                                   */   __IO uint32_t ICSR;                    /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register                  */   __IO uint32_t VTOR;                    /*!< Offset: 0x008 (R/W)  Vector Table Offset Register                          */   __IO uint32_t AIRCR;                   /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register      */   __IO uint32_t SCR;                     /*!< Offset: 0x010 (R/W)  System Control Register                               */   __IO uint32_t CCR;                     /*!< Offset: 0x014 (R/W)  Configuration Control Register                        */   __IO uint8_t  SHP[12];                 /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */   __IO uint32_t SHCSR;                   /*!< Offset: 0x024 (R/W)  System Handler Control and State Register             */   __IO uint32_t CFSR;                    /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register                    */   __IO uint32_t HFSR;                    /*!< Offset: 0x02C (R/W)  HardFault Status Register                             */   __IO uint32_t DFSR;                    /*!< Offset: 0x030 (R/W)  Debug Fault Status Register                           */   __IO uint32_t MMFAR;                   /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register                      */   __IO uint32_t BFAR;                    /*!< Offset: 0x038 (R/W)  BusFault Address Register                             */   __IO uint32_t AFSR;                    /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register                       */   __I  uint32_t PFR[2];                  /*!< Offset: 0x040 (R/ )  Processor Feature Register                            */   __I  uint32_t DFR;                     /*!< Offset: 0x048 (R/ )  Debug Feature Register                                */   __I  uint32_t ADR;                     /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register                            */   __I  uint32_t MMFR[4];                 /*!< Offset: 0x050 (R/ )  Memory Model Feature Register                         */   __I  uint32_t ISAR[5];                 /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register                   */        uint32_t RESERVED0[5];   __IO uint32_t CPACR;                   /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register                   */ } SCB_Type;   详情 回复 发表于 2015-6-16 18:13
STM32中用到的Cortex-M3寄存器说明
里面并没有详细的说明阿
此帖出自stm32/stm8论坛
81
HFSR = Hard Fault Status Register
                                 关于这个寄存器的说明请参考Cortex-M3的手册。
此帖出自stm32/stm8论坛
64
要是STM32手册中包含进来就好了
                                 要是STM32手册中包含进来就好了,不用来回折腾了.
此帖出自stm32/stm8论坛
67
哈哈,STM32的技术参考手册现在有681页,Cortex-M3手册有410页
1000多页的手册,太庞大了吧。
你见过哪个51的单片机包含了8051的完整手册?
如果包含了Cortex-M3手册,是否也要包含UART、USB、SPI、I2C等的手册呢?
此帖出自stm32/stm8论坛
81
Cortex-M3 已经将一些外围(除CPU外)标准化了,如NVIC。
因此具体芯片实现厂商只对Cortex-M3已标准化以外的部分进行补充,所以要学Cortex-M3,有关它的技术手册(TRM)是必须仔细看的。有关STM32除STM32的技术参考手册外,还必须关注具体IC的数据手册。
此帖出自stm32/stm8论坛
56
找到原因了
                                 memcpy过了头,这个CM3也能检查出来错误,强。。。
此帖出自stm32/stm8论坛
253
在core_cm3.h中有定义
typedef struct
} SCB_Type;
此帖出自stm32/stm8论坛
