7559|21
83
发个图,求教最简单的AD例子 [复制链接]
   是否只要按合适的时间间隔,对ADON置1,就可完成AD?有何其他条件?
   向大家求教。
此帖出自stm32/stm8论坛
                                     详情 回复 发表于 2008-8-19 14:27
84
没有了。通常是查询EOC,等待转换完成。
此帖出自stm32/stm8论坛
我也是这么想的,但常死在“查询EOC”上,可怕。
此帖出自stm32/stm8论坛
不知为何,走一个单步,EOC就变为0了。
此帖出自stm32/stm8论坛
79
你可以作一个查询超时,超时即当失败处理,
稍后重来
此帖出自stm32/stm8论坛
奇怪的是有AD值,就是AD完成了,EOC却=0。
此帖出自stm32/stm8论坛
手册上说:读ADC->DR就会把该位清零了阿
Bit 1 EOC: End of conversion
This bit is set by hardware at the end of a group channel conversion (regular or injected). It is
cleared by software or by reading the ADC_DR.
0: Conversion is not complete
1: Conversion complete
此帖出自stm32/stm8论坛
楼主还是把你的程序贴出来看看吧,你是否在查询EOC=0前读过
                                 如果在查询EOC=0之前曾经读过DR寄存器,则可能会清楚EOC状态位。
此帖出自stm32/stm8论坛
77
程序就是香主的“ST的网站上有一篇关于STM32低功耗..”中的
   STM32F10x_LowPower_ANLowPower_ANPart3WFE_Stop_Flash
我跟贴过。
   我是用MCBSTM32KEIL评估板试的。
摘录如下:
void ADC_Configuration(void)
  /* Enable ADC1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* Set the ADC Clock Divider */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
  /* Reset variables */
  RegularConvData = 0;
  /* ADC1 Init */
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 Regular Channel Config */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_1Cycles5);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* ADC1 calibaration start */
  ADC_StartCalibration(ADC1);
  while(ADC_GetCalibrationStatus(ADC1));
  /* ADC1 regular Software Start Conv */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  /* Test EOC flag */
  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));------------A
  /* Read regular converted data and clear EOC Flag */
  RegularConvData = ADC_GetConversionValue(ADC1);
  ADC_Cmd(ADC1, DISABLE);
始终停在A处。
此帖出自stm32/stm8论坛
顺便把原跟贴重写。
 我已经头疼好久了。
   我用MCBSTM32KEIL评估板试的。
始终停在:
百思不解!
   好象只要是“不连续 不扫描 非外部触发”就不出EOC。
   求助!
 我现在认为Part3中的3个例子可能有错,要不就是我的软件有错。
此帖出自stm32/stm8论坛
禁止访问
提示: 作者被禁止或删除 内容自动屏蔽
82
谢谢。但奇怪,那是JTAG,不是一条路啊!遗憾。
此帖出自stm32/stm8论坛
78
调试器的寄存器窗口是通过JTAG刷新显示数据
JTAG是通过内部总线读出相应的寄存器,然后显示到你的屏幕上。
你看到的不是一条路,但芯片内部却是相同的路径。如果真的不是一条路,那么这个芯片就要多出很多仅供调试的内部数据通路,势必造成芯片的面积增大、成本上升。
此帖出自stm32/stm8论坛
82
事情可能比较复杂,我没有打开ADC的register window
  但打开了memory 窗口。
  再说是“停留在A处,下不来”,不是“在断点处看不到EOC=1”。
此帖出自stm32/stm8论坛
按lut1lut的说法,关了memory 窗口,也死。
此帖出自stm32/stm8论坛
79
如果memory窗口显示的区域涵盖了ADC的寄存器所在地址也会有
请先把所有的memory、register、watch窗口全部关上,再试试看。
另外,你说是“停留在A处,下不来”是如何判断的?单步?连续运行?还是设了调试断点?断点设在哪里?
此帖出自stm32/stm8论坛
75
所有的memory、register、watch窗口全部关上。
                                   仅1个断点在下一行。
此帖出自stm32/stm8论坛
54
今天下班了,人都走了,明天我们争取把这个问题搞清楚
                                 现象确实很奇怪。
此帖出自stm32/stm8论坛
lz用的哪个版本的芯片?
                                 Z版本的芯片,我这里试的,都好的。
此帖出自stm32/stm8论坛
A版本
此帖出自stm32/stm8论坛
