4334|8
61
香主,关注一下SPIDMA方式的问题 [复制链接]
香主你好:
我做SPI DMA接收的试验,使用ST的例程。操作没有问题。
可是不能实现循环接收,例程是发送一次,而后查询标志,就结束了。
如何实现不断查询标志的接收啊,也就是接收循环起来!!!万分感谢。
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* DMA1 channel4 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel4);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI2_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI2_Buffer_Rx;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = BufferSize;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel4, &DMA_InitStructure);
  /* SPI1 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* SPI2 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Rx;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  SPI_Init(SPI2, &SPI_InitStructure);
  /* Enable SPI1 NSS output for master mode */
  SPI_SSOutputCmd(SPI1, ENABLE);
  /* Enable SPI2 Rx request */
  SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
  /* Enable SPI2 */
  SPI_Cmd(SPI2, ENABLE);
  /* Enable SPI1 */
  SPI_Cmd(SPI1, ENABLE);
  /* Enable DMA1 Channel4 */
  DMA_Cmd(DMA1_Channel4, ENABLE);
  /* Transfer procedure */
  while (TxIdx < BufferSize)
    /* Wait for SPI1 Tx buffer empty */
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
    /* Send SPI1 data */
    SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx++]);
  /* Wait for DMA1 channel4 transfer complete */
  while (!DMA_GetFlagStatus(DMA1_FLAG_TC4));
  /* Check the corectness of written data */
  TransferStatus = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
  /* TransferStatus = PASSED, if the transmitted and received data
     are equal */
  /* TransferStatus = FAILED, if the transmitted and received data
     are different */
  while (1)
此帖出自stm32/stm8论坛
                                 如果你会直接对寄存器操作,则可以按照我在7楼说的办法:重新设置地址寄存器和数据长度寄存器。   详情 回复 发表于 2008-7-17 21:59
84
也就是把这部分做成循环
     are equal */
     are different */
此帖出自stm32/stm8论坛
75
STM32还在摸索之中,可是任务不等人啊
此帖出自stm32/stm8论坛
67
当然是从新设置Buffer和DMA的各项参数
此帖出自stm32/stm8论坛
89
能否具体点啊。。大侠
while(1)
此帖出自stm32/stm8论坛
67
等候中
步骤是这样:初始化SPI2->初始化DMA5->启动DMA5->判断DMA5_FLAG_TC5看是否传输完成。再次启动DMA5.......
问题是这样的:第一次DMA传输没有问题。但之后的DMA传输没有进行。我修改成每次DMA传输前都要初始化一遍DMA寄存器就可以了。
请问:是否可以不用每次都初始化DMA呢?是否只要设置DMA的某个寄存器就可以进行下一次的DMA传输?
此帖出自stm32/stm8论坛
你至少应该重新设置地址寄存器和数据长度寄存器
                                 它们在DMA操作时是会变的。
此帖出自stm32/stm8论坛
87
现在的问题是有时收到的数据全为0,只有复位才能正常!!
此帖出自stm32/stm8论坛
79
6楼的重新初始化是对的
此帖出自stm32/stm8论坛
